Old 12-28-2012, 10:32 AM
gs1397 gs1397 is offline
Mein Auto: 2011 MB C300
Engine Warmup
Hey Guys,
Just a curious observation. I have a 13 X3 28i with just shy of 5K miles. It is wonderful. I recently noticed that it takes what seems to be a long time for the engine to warm up. I thought maybe this was just my car with the low miles, but last week I had a 12 328 loaner that exhibited the same characteristics. My C300 doesn't take anytime for the engine to warmup.
Just curious if this is normal to this engine.
GC
Old 12-28-2012, 05:02 PM
AzNMpower32's Avatar
Tar Heel Faithful
The temperature is for oil temperature which takes substantially longer for every vehicle. Most vehicles have a coolant temperature gauge; most modern BMWs with the electric water pump (pretty much all N-series engines like the N20) warm up very quickly.
Old 12-28-2012, 06:25 PM
noka noka is offline
Mein Auto: 2013 x35i M-Sport
Originally Posted by gs1397 View Post
...My C300 doesn't take anytime for the engine to warmup. ...
My C300 is warm in about 5-min of driving. I also keep it on "auto" climate control all the time and it works great in all seasons. I hope the X3 is similar and that I don't miss that.
2013 x35i (Space Gray, MSport, CW/CWII, DHP, Premium, Premium Sound, Technology, BMW-Apps)
Retired:'09 C300 4Matic, '09 GTI, '06 750i, '05 C55, '04 R32, '03 M5, '02 GTI, 01 M5, '00 M-Coupe, '00 540i/6, '99 M3 Coupe, '98 M3 Coupe, '96 328i, ..., '86 4000CS Quattro, ... too many to list
Old 01-26-2013, 05:34 PM
Update: X3 warms up pretty fast also. (Still getting used to no coolant temp gauge but oil temp gauge instead). Only thing is that my MB adjusted the fan speed automatically on "auto" climate control setting, whereas the X3 does not appear to do that and operates at whatever speed you set it to, even in "auto" setting. Note to self: Do some searching and RTFM to see if there are any hints about it .
Old 09-15-2013, 05:01 PM
Drewsky's Avatar
Drewsky Drewsky is offline
Mein Auto: '14 X3 35i-M Space Grey
No, it does do it. If you set the climate control to "auto" it controls the fan, but you still have a "base" speed you can run it at. On hot days down here in FL, when I first start it up the fan is running quite hard to cool the interior down, but once it has, the fan speed backs off.
Old 01-26-2013, 06:38 PM
raleedy's Avatar
raleedy raleedy is offline
Mein Auto: 2016 228i 6-speed
Not only does the oil have more thermal inertia than the coolant, it lives in a cooler part of the engine -- the block and the sump -- for the most part, and not up where the fires are. Added to that is that the lower limit of the oil temp gauge is at 160 Fahrenheit. That's hot enough to produce third-degree burns, before the needle even moves off the peg. By that time, the coolant has long since reached normal operating temp.
Old 09-15-2013, 04:39 PM
thelegend42 thelegend42 is offline
Mein Auto: 2014 X3 35i
Thank you for clarifying the temp gauge, AzNMpower32. I took my 14 X3 35i to the dealer because it takes so long to warm up, unlike the Jeep I drove before or the wife's Acura. Two miles (about 5 min) into my commute and I leave the neighborhood and need to merge onto a 55 zone. I want to use those 300 hp. But it will have barely budged from 140 deg. The owner's manual calls that a cold engine and says to "drive at moderate engine and vehicle speeds."
The dealer, by the way, blew me off, apparently all they do is check the computer diagnostics and if there are no alarms, they assume all is well.
Old 09-16-2013, 09:09 AM
Teemo Panda's Avatar
Teemo Panda Teemo Panda is offline
Bimmefest Plasti-Dip Guru
Mein Auto: E53, E46-M3, E70, F25-X3
Engine Warmup
Lol, u have a 13 and have 5k. My 13 F25 has 20k on the clock and low temp is very normal.
