Old 12-28-2012, 01:24 PM
TannerT TannerT is offline
Mein Auto: 03 330ci 3pdl 89 325i
Da eff?
So I took off out of my grandparents driveway and down the side road, no problems. Took off on the highway and felt like I was down a cylinder very jerky and rough acceleration sounded like I was down one or two. So I pull over and shut it off go up front and inspect to make sure the maf didn't work its way off or god knows what else. Nothing a sheriff pulled up and asked me if I could limp it up to town 2 miles so I wouldn't be on the side of the rode started it back up and it was fine. Drove 30 miles like normal. Waiting to watch the hobbit so if you guys could shed some light so I know what to look for afterward.
Sent from my PantechP9060 using Bimmer App
[SIGPIC]s[/SIGPIC]Formula SAE "Speed is Sexy"
Old 12-28-2012, 01:33 PM
llando88 llando88 is offline
Mein Auto: Ram 2500 4x4
Sketchy plug coils?
BTW We saw The Hobbit in 3D on the 25th, Excellent.
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.”
- J.C. Watts Jr.
Old 12-28-2012, 03:31 PM
halltristan's Avatar
Bimmer Enthusiast
Mein Auto: 325i and X3
Originally Posted by MMME30W View Post
Sketchy plug coils?
not likely. Check fluids, go to an auto parts store to scan codes and report back.
Member No. 470379
Old 12-28-2012, 05:03 PM
I will run to an autozone in the
Morning. Driving again no problems. One of the plug coils has some browning on it
Old 12-28-2012, 05:31 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Seen stuff like this a few times over the years including on my old 323. Hard to diagnose till you get codes. Personally, when things like this happen I just wait till it craps out again and throws a code. But if you really want to go "huntin" for the problem here are the common things to check.
1. Fuel pump. Rent a fuel pressure gauge and test at the access port on the fuel rail.
2. Coil packs and boots. Test them for spark by removing one at a time and arc it to a screwdriver or something. Be careful! 3. Get a scanner that shows what your 02 sensor voltage and if they are within spec
4. Check spark plugs. Are they oily, black, white? They'll tell you how your engine is running
Those are some easy and cheap ways to get started
Sent from my One X using Bimmer App
Old 12-28-2012, 06:20 PM
Well 3 can go off the list. I can check 4 in the morning. I will check one and two when I get back to MO
Old 01-19-2013, 09:50 PM
Just to close the threat problem never returned. writing it off as it being 10 below at the time.
Old 01-20-2013, 05:50 AM
GCoop's Avatar
GCoop GCoop is offline
Mein Auto: 2004 325xi
Well if it was -10 then my money is on a little bit of water (turned to ice) in the fuel/tank caused a fuel pressure drop because it congregated somewhere in the system. Probably the filter.
Either that or the old girl said -10 he be crazy to take me out in this. Ill scare him a little.
