Old 12-28-2012, 04:11 PM
mr_bean mr_bean is offline
Mein Auto: 2000 328i
TPMS Sensor Question
I installed the snow tires from my E46 today and needless to say the TPMS did not like the fact that the wheels no longer have sensors in them. Can I retrofit new sensors into these old rims or do a need a particular set of rims that are designed to accept TPMS sensors?
Old 12-28-2012, 05:20 PM
ctuna ctuna is online now
Mein Auto: 325xi wagon
Check tire rack they sell them for 50 each.
Also are you sure they have them as they didn't start using the kind that go
in wheels on the e90 till model year 07 .
It.s possible if you have the rotational type sensors built into the anti lock brake
system all you need to do it run the recalibration procedure on the tire set installed.
Do you really mean e46 this it the e9x board.
Old 12-28-2012, 06:18 PM
SuperTerp SuperTerp is offline
Mein Auto: m4now M5M3 550 760 335RIP
Did you let the car sit overnight and then reset it? I just put new tires on and it wouldn't reset multiple times the day they went on, but the next morning after a few minutes in reset it fixed itself right up.
Old 12-28-2012, 06:34 PM
Zooks527's Avatar
Zooks527 Zooks527 is online now
Winding up the M235xi
Mein Auto: 2015 M235xi / 2005 Tacoma
You can fit TPMS sensors in standard wheels. As CTuna says, they're $50 each at TireRack.
Some '07 plus '06 and prior use the ABS sensors for the tire pressure function, and while the system needs to be reset when new wheels are placed on them, they don't need sensors in the wheels themselves,so that's a no-cost fix. Some '07 and all later use active sensors that need to be mounted in the wheels, figure $200 for the sensors and another $100 to install/balance.
Edit: Fixed per kMorgan
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/ BimmerTech amp, Enh. BT
Ordered 3/12/15, Off the line 4/7/15, Delivered 5/14/15
Prior 40 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92
Old 12-29-2012, 07:21 AM
Mein Auto: 1997 528i
'06 and prior use the ABS sensors for the tire pressure function, and while the system needs to be reset when new wheels are placed on them, they don't need sensors in the wheels themselves,so that's a no-cost fix. '07 and later use active sensors that need to be mounted in the wheels, figure $200 for the sensors and another $100 to install/balance.
My 07 335i still uses the ABS for TPMS so I don't have sensors in the wheels. Still have to reset when changing to snow tires. Not sure why but it usually complains.
OP did you have to use spacers on the front with the e46 Wheels? I have a set of e46 (Style 119) that I have run on my e90 and the fronts looked so close to the strut that I got some spacers. The offest is 34 for my e90 wheels and 47 for the e46 wheels. Both sets are 17x8.
94 318I (Daughter's car), 96 740IL(current project), 97 528I(DD), 07 335I(Son's car)
Old 12-29-2012, 08:50 AM
Zooks527's Avatar
The rolling diameter on the snow tires is likely different from your other tires, even if they're the same size. Differences in tread wear and overall design often make enough of a change to trigger it.
I've fixed my post above for the years in question. The change to active TPMS took place some time in 2007, but it may have been spread across the production line.
The cat on your hood gives me the willies. Back in the day, a neighbor's cat apparently took to sleeping under my Vette's hood for the warmth, until it got its tail caught in the fan one cold morning when I fired it up.
Old 12-30-2012, 06:06 AM
The E82 uses 47mm offset just like the E46, so this wasn't an issue for me.
Your dash display wouldn't indicate "inactive" unless you had the 'direct' type TPMS, so your snow wheels are 'sans' TPMS. Now an expensive proposition to dismount the tires, install the TPMS, remount and rebalance them!
My brother's has a close friend that works in a repair shop. I can likely get the installation done for nothing. Just have to shell out ~$200 for the sensors.
Old 12-30-2012, 06:14 AM
luigi524td luigi524td is offline
Mein Auto: '13 535xDrive; '98 Z3 2.8
Options for TPMS
If you shop a bit (on-line) you might find them for fewer $$s.
Check the BMW forums too. One caution about buying used ones is the batteries are said to have a useful life of 5-10 years and they are NOT replaceable. Most TPMS for the year of your BMW are interchangeable. Check parts #s here: http://www.realoem.com/bmw/
They have been made by BEHR for BMW. If they are used you might have to buy a stem kit (about $7) if they were not removed carefully.
My opinions are free - you'll get exactly what you pay for!
Current: 2013 535xDrive | 2013 X1 MSport | 1998 Z3 2.8
Past: 2007 530xi | 2001 740i | 1998 740i | 1994 740i | 1986 524TD
"Seek and ye shall find" ... start with your owner's manual!
Click on the MrRebates logo/link below for cash back savings at on-line stores like Tirerack!
Mr. Rebates
Old 12-30-2012, 11:11 PM
pointandgo's Avatar
Well, the OTHER ISSUE is that his TPMS must be of a compatible frequency to his car's receiver...there have been changes from BMW, but I don't have the dates of those changes at hand. The Tire Rack would know based on the OP's year/make/model.
I'm still wondering if it's worth it to dismount the tires, install the TPMS, remount the tires, rebalance the tires...BIG BUCKS...perhaps MORE than buying the Conti Comfortkit!!
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 12-29-2012, 06:45 AM
The car in question is actually an '09 E82. I figured I pose the question here since this forum has about 10 times the traffic.
I know I have sensors in the wheels because I have the funny looking valve stems and resetting the system is futile, it only says "inactive."
Thanks for the info!
Old 12-29-2012, 10:22 PM
pointandgo's Avatar
Your choices are: do the dismount/install/remount/balance, or go through the Winter with the annoying "inactive" icon showing. The Conti Comfortkit (goo/air compressor kit) would probably be cheaper.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
Member: BMW CCA
Old 12-30-2012, 08:18 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
There is strength in numbers.
True, isn't it? Weighed mightily in my buying decision - chose a 3 over more exotic offers owing to its massive number of tinkerers, quality aftermarket suppliers, and huge DIY knowledge base....
