Old 12-29-2012, 08:18 AM
jjbaldas jjbaldas is offline
Mein Auto: 323Ci
VANOS sealing compound
I will doing my VANOS O-ring seals repair/upgrade and have a question on what sealing compound to use. The service manual states that one should apply a thin coat of 3-bond 1209 or equivalent sealing compound to head face and VANOS unit surfaces. I am not familiar with 3-bond so I was wondering what folks have been using for this job. Thanks.
Old 12-29-2012, 04:17 PM
G. P. Burdell's Avatar
G. P. Burdell G. P. Burdell is offline
Rambling Wreck
Mein Auto: E46
I used Permatex Ultra Copper, which is also used in the Beisan Systems procedure:
http://www.beisansystems.com/procedu..._procedure.htm
Old 12-29-2012, 04:39 PM
Mein Auto: 323Ci
Thanks, I will be using Permatex Ultra Copper for the points identified for the valve cover gasket install. I was not sure if is also used for the VANOS metal gasket to head mating.
Old 12-29-2012, 09:30 PM
Mein Auto: '04 330Ci 6-speed
Basically you're looking for a high temperature sealant which also says sensor safe on the container.
