Old 12-30-2012, 03:36 PM
thecushion thecushion is offline
Mein Auto: 02 540i,09 X5d
Battery died now wont idle on its own
Hello all,So my 02 540 was running great for all the holiday shopping. Parked it 2 days and came back to a dead battery. Trickle charged it over night and it cranks right up but dies if you dont have foot on gas peddle. Even when car is warmed all the way up she still dies. No check engine light on. After a few dies and restarts I now know I need a new battery as it ran dead again. Could the battery be the problem? I searched a bit but did not find an answer. You guys are always great!! Would someone please throw me bone? Thanks for any help anyone has to offer.
Old 12-30-2012, 04:06 PM
edjack edjack is online now
Mein Auto: '97 540i 6 speed
What's the overnight battery voltage? If less than 12.5, it may be dying. When the engine is running at about 1000 RPM, the voltage s/b about 14.
Measure and report back.
Old 12-30-2012, 04:18 PM
Car off 12.5 volt, Running @1000 RPM 14.2 volt--Or would you like the voltage after sitting over night as well?
Old 12-30-2012, 04:46 PM
edwin28 edwin28 is offline
Send a message via MSN to edwin28
Mein Auto: 5401 Sport
looks like you might need a new alternator... it's going on and off on you its trowing those symptoms its about to die on you... it still works but on high RPM's. and not charging enough the battery and causing the car to turn off on you... if you have a Voltage meter on you check the alternator directly see how much voltage it reads it will help you alot if you really need and aternator or a battery..... hope this helps
2000 540i Sport Black/Black, Matte Black Grill, Powerflex Bushings, Tranny/Diff with Royal Purple, Black Valve Covers, Z3/// Short Shifter,
Old 12-30-2012, 05:02 PM
JimLev JimLev is offline
Mein Auto: 540/6, Tribeca
If the alternator is outputting 14.2 volts he doesn't need an alternator.
What does the battery voltage read when the engine is at idle?
Old 12-30-2012, 06:19 PM
That is my main problem,the engine will not idle on its own. I have to keep my foot on gas peddle to keep her running.
It seems for sure I need a new battery,but that being said will that fix my idle problem?
I plan to buy a new a battery in the morning.
Old 12-30-2012, 06:34 PM
Have you checked the intake boot for cracks between the MAF and the throttle body?
The MAF could be bad if you don't have any leaks.
The alternator output will vary depending on the RPM, the state of charge of the battery, and the load placed on the charging system.
If you were reading 14 volts it sounds like your alternator is working OK.
Old 12-30-2012, 05:08 PM
Exacly. But sometimes it will trick you. It will read 14v and at some point it will read less than 12v. Not quoting no one just showing few of my experiences I've had. And with BMW if it doesn't read 11v up it will go off on you.
Old 12-30-2012, 06:13 PM
I hope its not Alt,as I replaced that 2 years ago/15K miles...
Also another detail I left out is..A couple days before this all started the tilt wheel lost its memory and had to be set back in place on start up.
BTW thx for all that is trying to help me.
Old 12-30-2012, 07:59 PM
OK here is a little update..
Not sure if this is the fix but called my buddy and he came over. Looked at the signs and said yes for sure I will need a new battery and my idle problem could be water in the fuel. I had a little under 1/4 tank of gas. We sat in the car a bit with my foot on gas to keep it running. After 20-30 minutes it would idle on its own. At that point He followed me to Shell for a full tank of V Power. Ran great there and back. Started and ran fine once home but battery barley started engine. I will report back tomorrow after I replace with new battery.
Old 12-31-2012, 11:07 AM
Update
I put a new battery in today and everything is perfect. I guess not having a good battery will cause idle issues. Thank you very much for all that helped me. BTW the battery that was in there was BMW and build date was July 08 and shipped date was Sep 2008.
Happy New Years!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
