Old 12-30-2012, 09:29 PM
blakedanatural blakedanatural is offline
Mein Auto: 2005 645 ci convertible
Blank Screen
Hello All,
After driving all day I went back out for one more errand and the dash was blank. I turned the car off and restarted and the BMW insigna lit up but then the display went blank. No navi,radio or anything. I drive control justs spins around without the little stops in between. ( I hope I explained that right)
Anyway it sounds electronic. As always any help with be greatly appreciated before I make a appointment with the stealership. Going to check my extended warranty to see if any electronic malfunction is covered.
Thank you,
Blake
Old 12-30-2012, 11:14 PM
greco2000's Avatar
greco2000 greco2000 is offline
Mein Auto: 2008 650i LCI
Do a search. There is a way to reset your idrive. Something about holding down both eject buttons or something like that...
2012 BMW M6 CONVERTIBLE
Old 12-31-2012, 03:53 AM
Mulchman's Avatar
Mulchman Mulchman is offline
Mein Auto: '07 650i
Hold down both eject buttons (CD/DVD) and push the volume/mute button.
'07 650i Coupe - Black Sapphire Metallic
M6 bumpers, skirts & wheels
BMW M Cross Spoke Composite 101 Rims 20"
HUD, Comfort Access
Old 01-03-2013, 07:26 AM
All-Or-Nothing's Avatar
All-Or-Nothing All-Or-Nothing is offline
Woo Hoo FREE Donuts
Mein Auto: 2004 645Ci Convertible
I never hold both eject buttons. I only hold the CD eject button and the power/mute button down until the CD ejects and the screen goes blank. Let go and the CD goes back in and iDrive reboots.
Old 12-31-2012, 05:04 PM
Hello Guys,
Talked to a tech and he says it could be the DVD DRIVE. Any comments
Old 01-01-2013, 12:42 PM
TxTaz's Avatar
TxTaz TxTaz is offline
Mein Auto: 2010 650i Coupe
Originally Posted by blakedanatural View Post
Hello Guys,
Uhmmm yeah...NO! When the IDrive just spins it means no power to the car radio modules.
The IDrive reboot would not work if you don't have any power. It is a soft re-boot. (Meaning software)
Does the car start? Gauges move on the dash? Any noise from the CD or DVD drives?
If the cars runs and gauges work, your CCC is probably good.
- Check fuses, there are post about where they are located on the board.
- Next check the car radio system with a scanner to see if there are faults.
- Last (if it were me) pull the center console, screen and under the glove box. Check for power to the modules. If I remember, the radio module is a part of the CD/DVD.
Be careful, the orange cables are fiber and break easily.
Good luck,
Taz
Taz...
2010 E63 Black sapphire metallic
“Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
Old 01-01-2013, 03:00 PM
TxTaz,
Well I just did the soft reset. Everything looked like it was in running order. The idrive spinned when the screen was blank. Yes the car always started and ran like normal but the dash had went blank. All the other guages was working normal and was illuminated clearly. I am going to wait a couple of hours and go out there and start the car again. I don't want pull anything out cause I don't want to mess up those fiber cables you mentioned. I will keep you informed because I have a appointment with the dealer on Thursday. Hopefully things will correct itself before then.
Blake
Old 01-02-2013, 04:54 PM
msa9167's Avatar
msa9167 msa9167 is offline
Mein Auto: 2009 BMW 650I
Had the same problem on my 05 a month after the warranty went out. It was the CCC Car Communication Computer. BMW fixed it under warranty as a good will fix. Had to pay $100, but it was better then the $800 if BMW wouldn't help me put.
Also there is a fuse that's behind the CCC u should check also.
Old 01-02-2013, 07:14 PM
Wow! I hope my extended warranty covers me too if thats the problem. My appointment is tomorrow at 3pm. I talked to a indy tech and he mentioned that sometimes the module in the trunk gets wet. That may cause that problem too or moisture inside the console over the radio may get wet. Who knows but Ill find out tomorrow.
Old 01-02-2013, 07:19 PM
MSA9167,
Where is the CCC located at? Is in the trunk?
Old 01-02-2013, 07:28 PM
Yorgi's Avatar
Yorgi Yorgi is offline
MSA9167,
It's under the DVD drive.
Here is a pic. The DVD drive can be ordered separately.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 01-02-2013, 08:01 PM
Regmatc's Avatar
Regmatc Regmatc is offline
Mein Auto: 05' 645
Mine does that periodically too, but usually resets within 15 minute s of driving....just thought this was a normal electronic quirk with the 6er.
Sent from my SPH-L710 using Bimmer App
Regmatc
Old 01-02-2013, 08:42 PM
Thanks Yorgi!
Old 01-02-2013, 08:44 PM
The dealership is giving me a 2012 535 for a loaner. !
Old 01-03-2013, 01:27 AM
msa9167's Avatar
It`s the cd/dvd drive that is in the middle of the dash. The last picture shows the yellow fuse that may have burn out.
Sent from my ASUS Transformer Pad TF300T using Bimmer App
ID:	355742   Click image for larger version
ID:	355743   Click image for larger version
ID:	355744   Click image for larger version
Old 01-06-2013, 02:42 PM
Hello all,
Sorry for the late reply but I also had a failed CCC. It was covered with the extended warranty and I had to pay 100.00 for the deductible. The actual charge was 1040.00. So my warranty came thru for once without the hassle. I tell you one thing I am so glad I invested in the extended warranty.
Old 01-06-2013, 03:11 PM
colink colink is offline
Hello all,
Which warranty company and level of coverage?
It's good to hear when they step up.
Old 01-06-2013, 05:15 PM
CoLink,
GE Auto Warranty Services with the 4 star plus coverage. 100.00 deductible
