Old 12-31-2012, 04:17 AM
muddhorn muddhorn is offline
Mein Auto: 93 328is
service engine. light
2000, 740il, 90 thousand miles. Great car but taken by used BMW car dealer in Philadelphia. Service engine light had been TAPED over. Car had great power, smooth idle. Never new or felt car was running. My problem is now won't pass NJ INSPECTION. Dealer suggest pulling heads with clean and rebuild. Need HELP!!!!!!. ANy suggestion for a fix or repairs. South Jersey ares. Codes are secondary air pump. Dealer ran diagnosis and came back , port in the heads are clogged not enough air flow in cylinders.
Old 12-31-2012, 12:13 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Start with reading/scanning the codes. That's the whole purpose of the OBD III mandate...to simplify the ability to diagnose the electronic emissions to help with clean air.
There's o need to start throwing money at things without first scanning your car to see which sensors registered the fault. From there you'll be aware what area to look...sometimes you have to look upstream of the sensor...and sometimes the issue is directly related to the sensor that faulted.
If you don't have an OBD III scanner, in most states places like Autozone will read the codes for free. Once you have the DTC (diagnostic trouble code) your just a few keystrokes a way from finding the area. There's so much info on the Internet about OBD III codes...you can type "BMW OBDII xxxxx" (where x=the DTC 5 digit code) into a google search box and find info,reason,& solution for the code. You can also search here or post the DTC "P" code here for help.
Q {BMW CCA Member #191509}
(SOLD)
