Old 12-30-2012, 03:31 PM
mikepariva mikepariva is offline
Mein Auto: BMW 520i
Speedometer stopped working for BMW 520i 2001
Speedometer stopped working for BMW 520i 2001 reg
Old 12-31-2012, 07:00 AM
tim330i's Avatar
tim330i tim330i is offline
Administrator
Mein Auto: Ti Silver 03 M3
Welcome to Bimmerfest. I moved your post over to the E39 forum, which is the chassis code for your BMW. Take a look around this forum for speedo issues or one of our members will reply with some ideas on what might be the issue.
Good luck,
Tim
The 2014 F32 4 Series Coupe Concept
BMW F32 4 Series Coupe on sale summer 2013
Old 12-31-2012, 07:40 AM
johnstern's Avatar
johnstern johnstern is offline
Mein Auto: 2000 BMW 528iT/5, S/C
The LR ABS wheel speed sensor provides the input signal to the speedo. Could be a failed sensor or a bad ABS Control unit. Could also be the speedo head which would be a very different problem-not the usual fault.
If you go to the Wiki section of this forum (top tool bar at the far right) and go to the ABS Control Unit section, you will find Bluebee's "place to start" thread which will help with your diagnosis.
Old 01-01-2013, 04:10 AM
You can learn how to test the wheel speed sensors here:
- E39 ABS DIY
