Old 12-31-2012, 05:56 PM
aioros aioros is offline
aioros
Mein Auto: 99 528i auto m-sport susp
Question Front wheel spin
If you lift your car, put it on jack stands and try to spin the wheels:
a-they will spin freely, hardly any noise
b-they will be hard to spin, make a grinding noise
Mine do 'b'
while driving and coming near a stop, I let it cruse until I have to brake, but i hear this grinding noise like if it's braking before i step on the brake pedal.
Any ideas why?
Old 12-31-2012, 07:25 PM
vavet5308 vavet5308 is offline
NADAVAN
Mein Auto: 2002 525it
Maybe a stuck brake caliper?
Perhaps a brake line with a bit of trash in it, not allowing the pressure to release, or releasing slowly?
Old 12-31-2012, 08:33 PM
Topaz540i's Avatar
Topaz540i Topaz540i is offline
Agnostic Priest
Mein Auto: 2001 540i/6
Could be gravel caught between the dustshield and back side of the rotor
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Bc-r coilovers w/ swift springs
Akebono=suck
ss braided brake lines
coming soon:
Jb lwfw
Old 12-31-2012, 08:34 PM
Topaz540i's Avatar
Agnostic Priest
How scored are your rotors?
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Akebono=suck
coming soon:
Jb lwfw
Old 12-31-2012, 10:04 PM
Silverlight95 Silverlight95 is offline
Mein Auto: 2001 540i sport
I would check all of your brake pads to see if any 1 has more wear than the others. It can be a stuck caliper as mentioned above, but because of the grinding noise, I definitely would say it is a rock stuck between the rotor and dust shields.
Old 01-01-2013, 09:56 PM
aioros
The rotors look normal. I didn't see any rocks stuck in there. So most likely its a stuck caliper (in both front wheels btw) or the rotors are warped
Sent from my SAMSUNG-SGH-I747 using Bimmer App
Old 01-01-2013, 10:39 PM
gomolka30 gomolka30 is offline
Mein Auto: 2001 530i
It could also be a bad wheel bearing. Check the brakes first though.
You could remove the brake pads and put the caliper back without any pads, and try spinning the wheel again. If the problem persists, then it is most likely a wheel bearing. If the problem went away, then it is most likely a stuck caliper or a brake line issue.
Old 01-02-2013, 04:10 AM
Makomagnet Makomagnet is offline
Mein Auto: 2001 525
+1 bearings or caliper
Old 01-02-2013, 09:06 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
Probably time to re-build the brake calipers.
Had the same problem, and also a shimmy at +/- 70 mph. New rubber seals + cleaning the piston calipers (which started to corrode at the outer part) fixed it. You might want to do rears as well, because if the front rubber boot for calipers are in poor shape, the rears are not far behind. And rears a PITA compared to the fronts.
Old 01-02-2013, 02:16 PM
cn90 cn90 is offline
It has been almost 2 years since I did my 6 brake hoses and caliper rebuild, things run smoothly.
It is easier than people think.
Here is the DIY again:
DIY: 1998 BMW 528i Brake Hydraulic System Overhaul (Brake Hoses, Caliper Seals/Dust Boots)
http://www.bimmerfest.com/forums/sho...d.php?t=538290
Also, while the caliper is out, you can spin the bearing by hand to check its condition.
