Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 01-04-2013, 05:24 PM
xochtheroach xochtheroach is offline
Mein Auto: 88 BMW 325i convert
Unhappy Manual transmission issue
i bought my beemer from a guy. Recently had trouble shifting into 3rd gear. Drained oil out of tranny and almost nothing came out but just a little charcoal colored sludge. and refilled gear oil. and now i am having trouble shifting into 1st, 2nd, and 3rd. Not sure if i should rebuild transmission or change out clutch first. Help pleaseeee
Old 01-04-2013, 05:39 PM
noxxyman2408 noxxyman2408 is offline
Mein Auto: Bicycle
Take it to your nearest dealer to see what they can diagnose the problem as? If not, then I dunno man!
If you can't do it, DON'T TRY IT!!!
Old 01-04-2013, 05:57 PM
First time's Avatar
First time First time is offline
INSANELY UNPREDICTABLE!
Mein Auto: 1984 318i
Have you tried to rebleed the slave cylinder? If not try that first before you go tearing into a clutch job.
Old 01-04-2013, 08:52 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
assuming your car is a manual right?
manual transmissions are pretty well bullet proof, you can do a lot too them and they wont give. the BMW autos arent half that robust.
Old 01-05-2013, 03:19 PM
downhiller's Avatar
livin large
syncros are shot. rebuild is needed. anytime you have manual tranny fluid that color it is always a sign to get it rebuilt.
Old 01-09-2013, 03:10 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
The problem only appeared once you replaced the fluid ?
I would be prepared to bet on you putting in unsuitable fluid
Don't take life too seriously; no one gets out alive !
Old 01-09-2013, 11:38 PM
Billwill Billwill is offline
Mein Auto: BMW E30 318i 1991
This is possible but I have seen reports of some owners filling their manual transmissions with ATF fluid and claiming it gives them smoother changes.
I stick to the recommended gearbox oil...75W-80 I believe.
Old 01-10-2013, 08:33 PM
downhiller's Avatar
livin large
some of the bmw 5spd trannies take atf fluid.
Old 01-09-2013, 10:03 AM
Newman271's Avatar
Newman271 Newman271 is offline
That Guy
Mein Auto: 85' 335i
I would say your synchro's are done. I had the same problem.. I found one on craigslist for a hundred bucks. 25k on a craigslist transmission and still shifts great no grinds. Sometimes you get lucky.
1985 335i
Black on Black coupe 5spd
Tokico lowering springs, KYB struts and shocks, BavAuto strut bars, SPC adjustable camber plates, Ireland Engineering rear toe and camber kit, Sparco buckets, Rota Torque 16x7 fronts 17x9.5 rear, Hella headlamps with HID conversion, all red taillights, MSD coil,M30B35 swap, Mustang GT Injectors, Port/Polish
Old 01-11-2013, 12:06 PM
BmwMan92's Avatar
BmwMan92 BmwMan92 is offline
I <3 my E34
Send a message via Skype™ to BmwMan92
Mein Auto: 1985 318i// 1988 325e
I did my whole swap for $275
Brandon
http://www.facebook.com/brandon.m.fore
Originally Posted by v8bimmer View Post
I just dont see any other logical way around this problem.
BmwMan92's Avatar
I <3 my E34
I would go with getting a new trans before rebuild
Brandon
3rd, gear, manual transmission, shifting, sludge
