E36 (1991 - 1999)
Old 01-07-2013, 04:21 PM
agonzalez8565 agonzalez8565 is offline
Mein Auto: 1997 BMW 318i
1997 318i wont start
Hey guys! First time on here and I could really use some help with my BMW. I few days ago I was driving my 1997 318i sedan on the freeway and my car began to make a clicking noise as I pressed the gas pedal. The noise would become louder as the vehicle sped up then lower as the gears shifted. Engine light also came on. I quickly saw an Autozone stopped and figured it was an oil issue. I check the dip stick and I was slightly low, so i purchased a quart and added 0w-40 mobil 1 synthetic oil (probably should have been 5w-30). Now the noise still continued and I was almost home so decided to make the trek their. On the way the engine stopped running and had to tow the car home. Now the engine wont start and before I take it to a mechanic and get robbed of my money I'd like to hear you guy's opinion.
Old 01-07-2013, 04:26 PM
TRaV MaNN's Avatar
TRaV MaNN TRaV MaNN is offline
Somebody stop me....
Mein Auto: EW/// 86
See what the check engine light says. It's the best start you can make
You can’t spend all your time worrying about where your next Twinkie is going to come from, so follow rule #32 and Enjoy The Little Things.
Old 01-07-2013, 04:41 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
1. Nothing wrong with 0 W40 whatsoever.
2. What was the oil level when you got home?
3. Did the car by chance overheat at all?
4. What is the coolant level?
5. Did the temperature gauge move even a little past the 12 o'clock position?
6. What noises does the car make when you turn the key now?
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 01-07-2013, 05:15 PM
1. Great!
2. Oil level was fine when I got home.
3. Car did not over heat.
4. Coolant level was a little low. I added water when I first heard engine ticking.
5. It was more near the 11 o'clock position. It was a cool night
6. The engine cranks and you can hear a slow repetitive ticking as the engine is cranking, but wont start.
Old 01-07-2013, 05:18 PM
Also the yellow and red inspection light comes..
Old 01-07-2013, 05:39 PM
hornhospital's Avatar
D'oh, You Kids!
Does the ticking sound like it's coming from the drivers or passengers side of the engine, or maybe the front?
Quotes to live by:
BMW-CCA #441426
Old 01-07-2013, 05:50 PM
jonesin's Avatar
The Canadian Prick.
Sounds like a weak battery/alternator, but I don't know know what would have caused the initial ticking...
Old 01-07-2013, 06:45 PM
Coming from the passenger side of the engine.
Old 01-07-2013, 07:14 PM
D'oh, You Kids!
Possibly a plug loose in the head. That would explain the "ticking".
Quotes to live by:
BMW-CCA #441426
Old 01-07-2013, 07:41 PM
E36 Phantom's Avatar
I Am The Machine
Sounds like some people I deal with at work.....
Sent from my Galaxy Tab using BimmerApp
// Chad //
// 1999 Chevy Tahoe //
You're a derbanana
Old 01-07-2013, 09:43 PM
D'oh, You Kids!
Quotes to live by:
BMW-CCA #441426
Old 01-09-2013, 04:42 PM
Had time to work on it today. Ran a diagnostics and code P0335 came up crankshaft position sensor failure. Removed the crankshaft and tested it with a multimeter and read like .134 ohms. So looks like a bad sensor. Ordering the part soon and hope to get things rolling all over again.
Old 01-11-2013, 10:29 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
The crankshaft should not have such a high resistance. It's made of high quality steel. Should easily be in the microOhms.
Also, how did you remove it so quickly? I heard it's quite a bear of a job.
GGC BMW CCA #443004
Join the BMW CCA!
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual FS
Old 01-11-2013, 10:53 AM
D'oh, You Kids!
Removing the crank and cam position sensors is simple. Lot of crap to get off to access them, but nothing to it once you get there. On the four cylinders the hardest part is getting to the connections under the upper intake manifold. Easiest to just take the upper manifold off and set it aside with everything still connected to it.
Crank position sensor should be 1280 ohms, + or - 10%
Quotes to live by:
BMW-CCA #441426
Old 01-13-2013, 06:54 AM
erkkinen erkkinen is offline
Mein Auto: 318
Petrie, am I the only one who got this? I do a lot of electronics repair, so the vision of someone yanking a crank to put an ohmmeter on it just cracks me up
Old 01-13-2013, 01:03 PM
petriej's Avatar
Most of the time I try to pick nits and be funny. Glad someone got it!
GGC BMW CCA #443004
Join the BMW CCA!
Old 01-11-2013, 10:56 AM
petriej's Avatar
Oh definitely. The sensors are made to be replaced easily.
GGC BMW CCA #443004
Join the BMW CCA!
Old 01-11-2013, 10:58 AM
D'oh, You Kids!
I think he meant he tested the crank position sensor, not the crank!
Quotes to live by:
BMW-CCA #441426
Old 01-11-2013, 10:59 AM
petriej's Avatar
That makes much more sense.
GGC BMW CCA #443004
Join the BMW CCA!
1997 318i, engine won't start, help advice needed, ticking noise
