X3 E83 (2004 - 2010)
2007 X3 rear springs
I see several posts about broken rear springs. Both my rear springs are broken, one just the end piece but another one is broke in 3 places. I don't want to lower the car any more using the Eibach springs like some have done. I would like a beefier spring so it doesnt happen again. The dealer wants $170 per spring. Found a company on ebay selling a new set for $169 which is 1/2 the price with free shipping, Made by Lesjofors??
Any suggestions where to buy or is there a better, stronger replacement spring. I carry quite a bit of weight in my trunk at all times and have had problems with rear tire wear...assume now it was caused by the broken springs |
Genuine BMW replacement springs for 148 at Tischer BMW.
This is where I buy all of my replacement parts if I want to stay with original. http://www.trademotion.com/parts/200...iagram=1935620
I would go with the eBay over the OEM, which you know will eventually break again anyway.
Might be the rear suspension design itself, but not a convincing case for insisting on exactly the same spring to replace a broken one. I would be more comfortable with an alternate one as long as the maker has a good track record. http://www.lesjoforsab.com/news/news...=211&sprakid=2 Don't know if the O.E. ones were Stumpp or not, but if they were it looks like they came out of a Slovakian plant. The Lesjofors ones could be from several countries, including China as always seems to be the case now. But worth a gamble I would say. |
I would stay away from eBay.
I am wondering what the part number is and if they are interchangable with any other models.
![]() #465420 National Capital Chapter My Progress Thread 2000 323Ci | TiAg | Gray | ZSP | ZPP | AFE | UUC | Eisenmann | Koni | ACS Type III | Coby Wheel | 330 Brake Swap w/ BMW Performance Rotors 2006 X3 3.0i M-Sport | Silver Grey | Terracotta | Navigation | Premium Pkg | Cold Weather Pkg | AFE | |
http://www.realoem.com/bmw/select.do
Real OEM to look up part numbers to compare.
i did this but the part number never comes up, it says ask your dealership
I believe the part number is 42-084-50
Can't be, need more numbers. Dont you need 11 digits?
^or don't gamble and get the OEM one, do it right the first time will save you money later one. Maybe Tischer (link mlukas provided) will have a warranty on them??
So 'doing it right' is using an OEM part which is known to fail?
Unless you can find one that is known NOT to fail and has backing I would still go with OEM. Like I said, maybe Tischer will give a warranty with it. Or just upgrade to Eibach springs
From Tischers website:
"All Genuine BMW parts/accessories we sell carry a 2 year - unlimited mileage warranty valid at ANY BMW dealership within the US. No warranty applies to any part(s) shipped or taken outside the US. The warranty MUST be done on a repair order and diagnosed by a BMW technician through your local BMW dealership's service dept. This means unless you're local, you must go to your local BMW dealership and have the warranty issue resolved. Make sure you hold onto your original sales receipt we enclose with every shipment, or contact us at gethelp@getbmwparts.com with your order # for a replacement invoice - you'll need it to get a BMW parts warranty done at your local BMW dealership." Although I will say I went with Eibach Pro Kit springs because they were less expensive and I wanted to replace all four at the same time. And Eibach has a 1 million mile warranty.
Both rear springs broke on my 2007 model. If I had known that Lesjofors made springs, I would have chosen those instead of OEM. IMO a reputable company with good products.
Bought the lesjofors, $169 for pair, half the cost of dealer, free shipping and received in 2 days, they are made in Sweden
Let us know how they hold up
The ends are thicker than the original so I'm hoping they are stronger
As the broken rear spring problem seems to affect all X3 model years, and other BMW models too, it is good that those possibly stronger Swedish Lesjofors are an option to O.E.
Was wondering if there is a best practice method of replacing them and came across a 3-series video that shows a way to avoid the crowbar method members here have used. Makes use of the car's scissors jack to create space between the upper and lower mounts so the spring can easily be slid out and replaced. Not sure if the X3 has the same areas where you could locate the jack base and the cradle, but looks less nerve-wracking than levering a spring out. Any thoughts? |
I used a 4 ton Puller from Harbor Freight to spread it but the same idea as the video. Was a piece of cake to change. Was able to do it myself in no time
I read that Z4 owners who have to do theirs can just have a helper stand on the hub to get the necessary separation for spring removal. That might work for the X3 as well, although a helper over 200 lbs. could be necessary. |
rear springs
Hey, I just replaced my rear brakes and noticed that both my rear springs are broken. Just a small piece is broken off. How dangerous is this? How long is it safe to drive before replacing?
Depends...mine are broken in exactly the same way and I've probably been driving on them for at least 20k km (didn't even realize anything was broken until I put the winters on and saw the pieces).
I already have the replacements but it's just too damn cold outside to put them in. ![]() |
Which replacements did you go with?
#25
There is pretty much zero aftermarket options available in Canada, so I ended up getting a pair of stock ones (very low mileage) for $50. I figured, for this money I can afford to replace them every couple of years. :-)
