Old 01-08-2013, 03:05 PM
loso81 loso81 is offline
Mein Auto: 335i
sport suspension
My 09 335i came with 17's on it, should i keep that size wheel on it or go bigger? Also, my car has the sports package and i think the car would look better if it was lowered a lil bit, if i lower the car would it affect my sports suspension?
Old 01-08-2013, 05:18 PM
R608 R608 is offline
Mein Auto: '11 328i M-Sport (6MT)
Personally I think 17" wheels look just about right on our cars. 18's are okay, but that's about as far as my taste goes. I also think the ride hight with sport suspension is just about perfect, and even had someone ask if my car was lowered because they liked how it sat. "Nope. That's stock."
I guess it depends on what you like the looks of and how much you're willing to put up with to get those looks. Larger wheels will mean harsher ride and higher likelihood of bending a wheel, which I've found easy enough with 17's. Tires will cost more as well. As for the suspension, if you lower it, you're replacing components (at least springs) with different ones so, yes, that affects the suspension. How it's affected will depend upon the replacement components you choose. FWIW, these cars already sit quite low, and I've scraped my air dam a couple of times in spite of being careful. If you have to use the car in snow, ground clearance is your friend there too, so make sure you consider the trade-offs before changing it.
Old 01-08-2013, 05:26 PM
Mein Auto: 335i
Lightbulb Xdrive
yea i figured that if i lowered it, i would definitely have to get replacement parts, and the car has xdrive so i guess it would be in my best interest to keep it the way it is, have u done any other upgrades to your car. I was thinking about getting the jb4, do u know anything about it. Thanks for the response, i appreciate it. Im a bmw noob just trying to get educated on the "ultimate driving machine"
Old 01-08-2013, 05:41 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Originally Posted by loso81 View Post
...the car has xdrive so i guess it would be in my best interest to keep it the way it is, ...
If the car is an xDrive model it does not have the sport suspension. There is only one suspension setup for xDrive. The sports package on these cars is mostly cosmetic (seats, wheels, etc.) with a few minor performance upgrades (oil cooler, increased top-speed limiter) if all the right option boxes were checked.
Lowering an xDrive suspension, if you are too aggressive about it, may accelerate wear of the front axles' CV joints. Just something to keep in mind because replacing the axles isn't exactly cheap.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Sorry, mine is non-turbo and bone stock when it comes to the mechanicals so while I watch with some interest to see what others do to their cars, I can't offer first-hand experience in that department.
I didn't realize your car was AWD. Not sure if it's a coupe or sedan, but I think in either case the suspension is the same with or without sport package. Your interest in lowering it is starting to make more sense suddenly. The trade-offs remain the same, but you probably have a little more room for improvement than you would if you had a RWD with sport suspension. Give it a little time and perhaps others will be able to offer some recommendations for you to consider.
EDIT: Or they'll beat me to it and reply while I'm composing my message.
Old 01-08-2013, 05:48 PM
Mein Auto: 335i
yea its a coupe, i was given advice that the xi would be better than rwd because taking off doesn't give alot of wheel spin. ok now i understand what the sport package is. So the sport package has nothing to do with suspension. gotcha
Old 01-08-2013, 05:44 PM
1985mb's Avatar
1985mb 1985mb is offline
N54
Mein Auto: E60 535i M-sport
The rule of thumb is that you should use springs and shocks/dampers that are matched to work well together, or get coilovers (which are sorta all-in-one).
Current: E60 535i M-sport
Prev: E90 330i, E93 335i, W212 E350 Bluetec
Old 01-08-2013, 05:32 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
You're sure? Comes w/18" wheels + little lower
Read up on alignment re: lowering your ride; tire wear
Old 01-10-2013, 10:44 AM
sonitm sonitm is offline
Mein Auto: 2011 323i 6sp
The sport suspension is already lower than the regular suspension by 1.5 inches or so. Depending ont he roads in your area, an 18 in setup might be a bit harsh on your back. 17 and sport susp. is plenty in my oipinion. But before you make a change, test a car with that setup and see what you think. Also consider that daily driving is different than track days.
Old 01-10-2013, 11:15 AM
1985mb's Avatar
N54
Yes, that is true for the X-Drive cars (but not for RWD).
The OP has a US-spec X-Drive which does not have the sport suspension.
