Best diagnostic/coding tools? - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 01-09-2013, 09:38 PM
lgr122 lgr122 is offline
Mein Auto: '04 e46 Touring M-Sport
Question Best diagnostic/coding tools?
What kind hardware/software would be best to get for e46?
First purpose would be to read codes, but i think i don't want to buy something which can only read codes, i want to be able to recode stuff also.
Can these easily remap ECU? Some software updates available?
I'm not sure if I'm going to, but i want to get something good which can go all the way.
Can there be some good program for laptop? (BMW Carsoft?)
What kind cables and plugs are needed?
Any other good stuff out there?
Old 01-09-2013, 11:47 PM
heztheone heztheone is offline
Mein Auto: ///M
search for "BMW Scanner 1.4.0"
Give a man a fish and you feed him for a day. Give a man a Chef and he feeds him for a lifetime
Old 01-10-2013, 01:21 AM
That looks good, might get one of those...
How about anything for remapping ECU?
Might be too much for me to handle, but there's some upgrade kit, camshaft and bit other stuff, and it says that ECU should be remapped for best result.
Mechanical parts i can handle myself, but how about that software part?
Old 01-10-2013, 02:01 AM
Mein Auto: ///M
i'm not sure u can remap the ECU for better performance (to provide +15hp for example) this is a very good tool to scan for codes, reset codes and do the fun stuff like turning the fog lights with high beams and so on... contact them for more info
Old 01-10-2013, 02:13 AM
Ofcourse coding alone can't give more power, but i'm curious about options.
Or... does that ECU just learn on it's own when i just bolt on mechanical parts?
Anyway Carsoft 6.5 sounds interesting as well.
Anyone who have used that?
Old 01-10-2013, 08:05 PM
Noone uses Carsoft 6.5? Everyone has BMW Scanner 1.4.0?
If that's so, then i believe i got my answer.
Old 02-01-2013, 12:47 PM
Fishful Thinking Fishful Thinking is offline
Mein Auto: '04 325ci
Have you indeed accessed and programmed the LCM? I cannot access it on mine. I'd love to play with the light settings.
Old 02-03-2013, 09:41 PM
Mein Auto: ///M
no i didn't get the BMW Scanner, but i googled alot about it and appears u could do that.
that's why i wanted to be sure from someone who got it (lgr122) that he can do that for certain...
Old 01-10-2013, 10:08 PM
Mein Auto: '04 330Ci 6-speed
Cams is nasty stuff on the e46
Are you sure u can do it?
Old 01-10-2013, 10:42 PM
Thinking about it, but it's not on top of the list.
Shocks and clutch are next to buy.
I think i could deal with camshaft, but i know opening up engine is always bit risky so should think everything through very well before starting.
I'm fine with mechanical parts, just electronics/software part always makes me wonder.
What if it just doesn't want to run with wrong part???
Anyway i'm running M43 engine in mine which is bit more simple about those.
Generally I have more ideas than money.
Old 01-11-2013, 01:33 AM
Mein Auto: ///M
don't we all
Old 01-11-2013, 06:00 AM
From the bestlinks:
Making sense of the most often recommended BMW diagnostic tools & cable interfaces (1) & BMW factory & dealer programming, coding, and diagnostic software such as INPA, EDIABAS, NCS Expert, DIS, EasyDIS, Progman (1) (2) (3) (4) (5) (6) (7) (8) (9) & related BMW diagnostic-tool forums (1) (2) (3) (4) (5)
Old 01-15-2013, 10:09 AM
Ordered that BMW Scanner 1.4.0. hope it comes soon.
And i guess i should get laptop also.
Wife has one, but maybe i shouldn't expect to use that one for this purpose.
Old 01-31-2013, 05:00 AM
Mein Auto: ///M
did u get that scanner yet? what are the options you were able to do besides checking for codes?
Old 01-31-2013, 07:35 AM
I got scanner couple days ago yes, but didn't quite install and get to it yet.
Wife has Windows 7 in her computer, and this one has XP, but this one is not portable... so thinking about what's smartest way to deal with it.
Might even get some old second hand laptop just for scanner use, they are quite cheap.
Old 01-31-2013, 09:34 PM
Mein Auto: ///M
no need, simply install Windows XP on a virtual PC (lots of info on google how to use a Virtual PC) on ur wife's laptop and u'll b good to go. u'll do all ur work from the virtual PC.
Old 02-01-2013, 06:29 AM
Ok, so will do that way then, but not sure when i have time to play with it.
Got stuck in snow wednesday night and toasted my clutch in process of getting out of there.
Well... that clutch wasn't very good anymore anyway, car still moves somewhat, and i already got those clutch parts... but it kind of jumped bit in priority.
Old 02-01-2013, 07:26 AM
GCoop's Avatar
GCoop GCoop is offline
Mein Auto: 2004 325xi
I use the BMW factory tools. INPA, DIS, WinKFP, NCS, SSS/Progman. They are out there in the wild and can be obtained easily. (Well, at least they were 3 years ago. now )
I have been able to do anything I have needed to do so far. Reading and clearing codes, Reading BMW factory codes that a reg hand held reader will not show, Programming car key memory options, Alarm retrofit coding.
All the information you would ever need in order to do this is on one of the other forums in the coding and diagnostic section. Worth considering i think.
Old 02-08-2013, 02:24 AM
Minor set back, her laptop can't have virtual PC.
(Atleast not without paying more money, which i'm not going to.)
Will see if could borrow another laptop just for testing scanner bit, but now i'm again thinking of getting some old laptop just for scanner. Some mates are giving away those almost free once in a while, and running XP (or even Win98) would be enough, doesn't need much power for that use.
Old 02-08-2013, 02:49 AM
Mein Auto: ///M
installing a virtual PC is like updating ur windows, it's always for free
simply google it, their are plenty of how-to's
Old 01-31-2013, 09:59 AM
SJBimmer's Avatar
SJBimmer SJBimmer is offline
Living Life At The Beach
http://www.bmwcoding.com/
Old 02-01-2013, 08:03 AM
TannerT TannerT is offline
Mein Auto: 03 330ci 3pdl 89 325i
Plus 9 million
Sent from my PantechP9060 using Bimmer App
[SIGPIC]s[/SIGPIC]Formula SAE "Speed is Sexy"
Old 03-18-2013, 07:49 AM
Thirdy Thirdy is offline
Mein Auto: E70Diesel, E46
I have been using DIS for diagnosis. I like the way it tells you what is wrong with the car and also how to fix it(test plan) not just some codes that you still need to decipher. And for coding I use NCSExpert. Im running my DIS on a windows 7 laptop and NCSExpert on an XP
Sent from my SAMSUNG-SGH-I717 using Bimmer App
Old 03-18-2013, 08:41 AM
What kind coding does that NCSExpert allow?
I'll see what this BMWScanner can do, but i'm open for more good ideas.
Old 11-27-2013, 08:22 PM
thesithlord thesithlord is offline
Mein Auto: 2004 bmw 330ci
I am looking for an INPA cable for my 2004 330Ci (E46) to use with INPA software. Does anyone know which cable should I buy from either eBay or Amazon that will work with my car? so many out there and it's very confusing. A link to the cable is very helpful.
