Old 01-10-2013, 11:03 AM
megaorgun megaorgun is offline
Mein Auto: E39 525 TDS
e39 fitting fogs one connector
Hi i have an e39 with no fogs as standard i am fitting an m-tech bumper and i can only find one on passenger side(euro rhd).
Where is the drivers side? if i have none can i wire 2 fogs from one cable.
Old 01-10-2013, 06:04 PM
barneyhyphen barneyhyphen is offline
Mein Auto: 2000 323i sedan
Assuming you're talking about the wire/plug that you can find on just the Pass' side? Nnot sure you should wire both fogs in to just the one wire/plug as you may be overloading the wire/fuse.
All I would say is that, if there's a wire in there for the pass' side, there is surely one tucked away in there for the driv' side. They MAY just wire one side on the rear of the car, for what they call in England "high intensity" rear (fog) lights but never have I seen just one side lit on the front.
Keep looking, it's in there somewhere! Good luck, please let us know how you get on.
BH
Old 01-11-2013, 07:40 AM
Hi well the cable that runs from lights is going to what i reckon is the horn, i noticed another cable branching from that which is tucked behind pipes and the fog connector if it is would be too big to pull through unless bumper is off which it will be.
Q: is the fog on this side wrapped with the horn for tidiness?
Old 01-11-2013, 11:40 AM
Don't know the answer but will check on mine when I get a chance.
Old 01-15-2013, 06:05 PM
any luck?
Old 01-16-2013, 11:35 AM
Not yet, sorry. Cold and real wet here right now so could possibly be the weekend before I get to it.
BH
