X5 E53 (1999 - 2006)
The X5 SAV Forum |
radio fuse
what fuse(s) do I need for the radio in my 2002 X5.. not working ?
If you mean the fuse that is located in the electrical harness on the radio itself...it is a 10 amp fuse. For example, I'm referring to the reddish fuse in the pic below on the back side of an in-dash CD43 CD/radio unit...the same applies to the CD53/C43/BM53 units.
If you are referring to a fuse elsewhere...then look for the fuse index in both the front & rear locations which will have the fuses listed alphabetically along with its fuse nbr...also with a fuse box illustration that shows the fuse nbrs place within the fuse box as well as its amperage. ![]() (rear fuses behind right side cargo panel) ![]() ![]()
Q {BMW CCA Member #191509} 2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 97 740iL (Arctic Silver) 3/97 mfg date (SOLD) 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White) 91 735iL (Schwarz Black) <<~>> 85 325e (Bronzit) Last edited by QSilver7; 01-11-2013 at 01:57 PM. |
Hi Qsilver,
If you open the glove box and look in and up you will see a cover, on the back of the cove should be a lable identifying which fuse is for where and what amperage. Cheers |
Q {BMW CCA Member #191509} 2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 97 740iL (Arctic Silver) 3/97 mfg date (SOLD) 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White) 91 735iL (Schwarz Black) <<~>> 85 325e (Bronzit) Last edited by QSilver7; 01-12-2013 at 12:46 PM. |
