Old 01-12-2013, 06:32 AM
radarguy radarguy is offline
Mein Auto: 2016 A6; 2015 X5 35ix
F10 ambient light functions.
I found these ambient light functions in the F30 cheat sheet. Are there similar ones for the F10?
Ambiente_Helligkeit (brightness)
Ambiente_Nachfuehrung (independent from cluster brightness)
HELLIGKEIT_AMBILIGHT (ambient slider)
Old 01-12-2013, 06:30 PM
miotoo miotoo is offline
Mein Auto: F10 520d
If I recall correctly, changing the values on my F10 didnt have any effect..the last one added a control slider in idrive but it wasnt doing anything.
F10 520d Deep Sea Blue 11.04.2011/16:24
Retrofitted:
5DF Active Cruise Control with Stop & Go incl. Collision Warning with Brake Function /ver. 1
2TB DEC Switch for Normal / Sport / Sport+ Writeup: http://www.bimmerfest.com/forums/sho...d.php?t=685869
8TH SLI Speed Limit Info / KAFAS 1
5AD LDW Lane Departure Warning / KAFAS 1
319 Universal Garage Door Opener
6WA Instrument Cluster with Extended Contents
Old 01-13-2013, 10:28 AM
Good info, thanks.
Old 03-24-2013, 09:09 PM
intex98 intex98 is offline
Mein Auto: 2011 535i
Anyone know if it's possible to increase the brightness of the ambient lighting?
2011 535i (8/11 production)
Space Gray, Black Dakota/Aluminum, Premium 1&2 Pkgs, Sports Pkg, SAT, Dynamic Handling Pkg, Convenience Pkg, BMW Apps
2007 335i Coupe (sold 9/11)
Titanium Silver/Black Leather/Aluminum Trim, Auto, Paddles, Premium, Sport, Navigation, RTTI, Comfort Access, PDC, Rear Sunshade
2003 X5 3.0i (sold 11/06)
Titanium Silver/Black Leather/Dark Wood Trim, Auto, Premium, Sport, Navigation, Rear Climate
Old 03-26-2013, 11:16 AM
ilhan1103 ilhan1103 is offline
Mein Auto: f30 318d
There is one I've found but others have reported it not working. Feel free to try on yours.
I can't recall the exact code but it's in the f30 sheet
Old 09-05-2015, 09:23 AM
sam-and-dori sam-and-dori is offline
Mein Auto: 535i
Changing CS_AMB_MIN_BRIGHTNESS to 50 made my ambient lights MUCH brighter. I also tried changing CS_AMB_MAX_OFFSET from 70 to 80, but it didn't seem to make a difference.
Old 09-05-2015, 05:57 PM
mitakam mitakam is offline
Mein Auto: F10 530d M-Sport
Hi, is the much brighter you mean about the max brightness with iDrive slider and Instrument cluster brightness wheel all the way up? Because if it is brighter than that I have heard there was some problems with the light strips overheating and melting components.
Old 10-20-2015, 09:43 PM
txoid txoid is offline
Mein Auto: f10
So i just changed a few of these setting tonight and noticed a little difference with the brightness (A little brighter). Below are the setting I set them to.
CS_AMB_BRIGHTNESS (left at 100% (werte 64))
set to: initwert
Changed werte to 32 (50%)
CS_AMB_MAX_OFFSET
set to: initwert
Changed werte to 10
The ambient lighting still dims with the cluster dimmer but at high setting it seams to be brighter. I'm not sure what the offset is doing because i don't know what PWM stands for. I'll try some other settings this weekend.
Old 10-11-2016, 10:27 AM
AntDX316's Avatar
AntDX316 AntDX316 is offline
Mein Auto: 2013 750i xDrive
set to: initwert
CS_AMB_MAX_OFFSET
set to: initwert
Changed werte to 10
Pulse Width Modulation
2013 750i xDrive
Old 10-13-2016, 04:34 PM
kajer kajer is offline
Mein Auto: 2012 535i 6MT M-Sport
set to: initwert
CS_AMB_MAX_OFFSET
set to: initwert
Changed werte to 10
Along these lines, do you think it's possible to code minimum and maximum brightness for the gauge cluster / internal button locater lighting?
I would like my dimmer wheel to go to 0% if possibe to black out the gauges at night. Much like the "night panel" function of the old SAABs
Old 10-13-2016, 05:28 PM
AntDX316's Avatar
I never messed with those kinds of codings. I think overdriving LEDs will make them burnout. It might be a hassle replacing those LEDs considering it could be attached to bigger parts. Replacement would require a bigger part replacement.
Also if the bulb is sent too low power it would flicker or not even turn on I think without a PWM modification.
2013 750i xDrive
Old 10-14-2016, 09:01 AM
I agree on the overdriven LEDs, primary reason most LEDs die.
As far under powering, depends on the driver circuit. I might try to find some codings for the minimum brightness of the gauge cluster. During those dark nights out in the desert, the minimum panel brightness is too bright. The best I can do is to turn off the CIC display. It helps, but not as much as further dimming would.
I'll see what I can find and report back.
Old 10-14-2016, 02:37 PM
AntDX316's Avatar
I saw what the "foot well" lights look like and they seemed to be soldered on. I gave up trying to solder anything that small.
2013 750i xDrive
ambient light, coding
