Where to measure battery voltage on X5? - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 01-14-2013, 08:11 PM
bimmerworld bimmerworld is offline
Mein Auto: X5 2005 Sport
Seems like an odd question but where should I use my multimeter when measuring the voltage of my battery? I tried the jumper locations under the hood and was about to fry my multimeter. I got a spark and the multimeter cables were hot. Should I go through the hassle of removing the spare tire in the trunk and directly use the battery outlets there? Thanks for any advice.
BMW X5 2005 Sport E53 M62
4.4i V8 DOHC 32V AWD
Old 01-15-2013, 09:05 AM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E60, E71, E92
NO!
I never had spark (rush current) testing voltage at charging terminal in engine bay.
You have either bad voltmeter or not in volt-measuring setting (my guess would be in current measurement setting), got it checked.
PS: volt-meter has high impedance so virtually no current flowing between measurement leads. amp-meter on the other hand, has low impedance in between leads.
Old 01-15-2013, 03:46 PM
My bad, you are right. My multimeter was on the amp side, rather than the volt side. Measured battery without sparks now :-) Thanks for the input!
