hex bolt holding on rotor stuck
Hey all. I am trying to change out the rear bearing on my 325 and the hex bolt holding on the rotor is not budging. Any ideas on getting it off without damaging. Thanks all.
I typed /rotor F3 in the bestlinks and came up with this which may help:
- How to remove stuck rusted-on brake rotors (1) & how to remove a stuck 6mm brake rotor set screw (1)
Regardless of the method, the PB blaster soak makes all the difference! |
2004 BMW 330ci Silvergray Sport Package, Cold Package, Xenon Headlamps, Premium Package, 6 Speed Manual, Build Date 9/03 Sold - 2003 325i Sedan Japanrot 5 Speed 8k Xenon Headlamps Build Date 11/02 |
FYI if anyone ever has the chance to get their hands on some Kroil do it. Soaking with that magical substance has enabled me to get away with not using a blowtorch more times than I can remember. It's expensive and hard to come by but worth it.
And keep in mind if you break it off, it is a 'convenience' item. You can run without it with no problem. The wheel bolts are really what holds the rotor in place.
