E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
crank crank crank no start helppp!
whats up. so it drove well forever, an lately(for a week) its been taking a while to start. an now it just wont start.
i replaced fuel filter an nothing an it has proper fuel presure. replaced valve cover since the oil well were full of oil. could that of hurt something? what sld i do next? please help! |
When you turn the key what sound(s) do you hear?
Fuel pump? Engine turning over? Starter engaging? Starter clicking repeatedly? Starter just clicking once? No sound at all?
“No cop born isn't a sucker for a finely-executed hispeed Controlled Drift all the way around one of those cloverleaf interchanges. Few people understand the psychology of a traffic cop. A normal speeder will panic and pull over to the side when he sees the big red light and start begging for mercy. This is wrong. Contemptuous to the cop-heart. When running along about a hundred and you find a redflashing CHPtracker on your trail you accelerate.” - Hunter S. Thompson, |
the engine will turn over buhb wont start. an yeah the fuel pumps coming on i replaced the relay just to be shure
First off, check your battery terminals for corrosion and tightness.
Then I'd test your battery, fuel pressure (you can by a fuel pressure gauge from Harbor Freight for ~$20), then we'll get into testing for spark.
ive tryed two different batterys (stole the battery frm my jeep
)an cleaned terminals, allready tested fuel pressure an replaced fuel filter :/
Crank or cam position sensor. It's not firing the plugs or the injectors or both.
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! |
Do u think it could be the mass air sensor?
Unplug it and find out.
GGC BMW CCA #443004 Join the BMW CCA! 2005 X5 4.8is Le Mans/Black/6spd Steptragic ![]() 1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual ------------------------------------------------------------------- 1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012 2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011 |
unplugged it anstill didnt wanna start just turning over an not firing how do i read the check engine light ?
OBD2 cars, go to Advanced Auto and rent the scanner. Bring it home, plug it in, turn key into the on (don't start) position, scan. Sounds like a Crank Position Sensor or Crankshaft Position Sensor. But I am just a keyboard mechanic. |
i have an obd1 reader that ived used in my jeep an mustang, buh i cant figure out where to plug it in at. i saw a round plug in spot under the hood is that it? where can i get the adapter
an again thanks for all ur help guys! |
I don't know if all OBD1 scanners are universal.
where is the crank or crankshaft sensor located how do i replace it?
Well, might wanna check the camshaft position sensor as well. Here are vids:
Camshaft position Sensor Crankshaft Position Sensor (If you have a lift, it will make life easier). |
so i replaced the crankshaft sensor an now it runs!! yay!!! buh it will idle normal then it will start to die then rev up an start to die an rev up
what could cause that |
Vacuum leaks. Dirty MAF, Dirty ICV.
How do i clean those? Like will carb cleaner work
Absolutely NOT for the MAF!!!!!
Use an electrical contact cleaner for the MAF, (Or specific MAF cleaner). aYnd you can use Carb cleaner on the ICV.
