E36 (1991 - 1999)
Hey this is for any of you that during various occasions have had to take the cooling fan out from the front of your inline-6 e36 to make room or change the waterpump, but can't find a simple way to stop the damn waterpump pulley from rotating with the fan bolt. I looked on various forums and in manuals for how to take out the fan clutch and they all want people to either buy some special tool or tried difficult balancing acts as they try to wedge some kind of ultra thin bike wrench between the bolts on the waterpump pulley to counter-torque it. For a task as simple and as essential(given our engine's tiny living space) as removing the cooling fan from the front thats all quite unneccessary and complicated if you ask me. Besides its hard to find a wrench or other metal thing thin enough to fit in such a small gap(thats why they had to make a special tool i guess).
What I did will I was trying to refurbish my cooling system was I took the accessory belt, relieved the tension and unwrapped it from the other pulleys, but kept it wrapped arround the water pump pulley, which is the one that rotates with the fan clutch. I kept it wrapped around the pulley firmly to stop the pulley from rotating and just torqued the big bolt to the right and voila, easy as ****. no tools neccessary other than a good sized adjustable wrench (capable of 31-32mm). The accessory belt provides ample grip to keep the pulley from rotating. Of course i was replacing both the pulley and the belt as well, but the force required shouldn't be enough to break or damage anything as the belt grips onto the pulley quite easily, and my belt was quite worn. Idk if anyone has already done this or if its just common knowledge at this point, but when i was looking up articles on removing the fan clutch, i didn't come across anything this simple, even the guys at pelican parts were saying the only practical way to remove the fan clutch is to use the special tool(and they've figured out how to do a lot of **** without special BMW tools), and i did not feel like waiting for days to order a special part just to remove a damn fan since all my other parts came in already, and i was pretty frustrated that i would have to order another special part and wait even longer when i have been on a time crunch to atleast finish the cooling system before my classes start. So one day I thought about using a rubber grip to hold the pulley with my hand while i torque, then i thought, "**** why not just use the accessorry belt? its designed to grip on the pulleys without slipping anyways" If it sounds like im being a bit pompous its because i am a little bit. It might be a simple thing that I figured out, but so much of my project was being halted because of this stupid fan clutch and not having the time to order another "special tool" because of all the other **** i have to do to my car. so for any of you newbies that are left scratching your head whenever your haynes/bentley/chilton manual tells you to remove the cooling fan for every simple task this should help you out |
I always just leave the belt tight over the pulleys and tensioner then use a 32mm service wrench and give it a whack with a 24oz. hammer. Worked on every car so far (6 and counting). By the way, you can buy the whole set of service wrenches at Harbor Freight for less than $30 when they're on sale. They are indispensable for suspension work. Good investment.
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! |
I do as Ken does, don't touch the belts at all before removal and give the 32mm a good whack. Voila, that's it.
If you just try to pull, you can just spin the engine. Sent from my Galaxy Tab using BimmerApp
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium // ![]() E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. . |
"It doesn't do any good for me to know more than you if you aren't going to listen to me" |
Wait for a sale or use a coupon: http://www.harborfreight.com/15-piec...set-93668.html I paid $29.99 for mine. Use them ALL the time.
![]() Thanks for the link Ken!
Northern Tool does have the 32mm individually for $9 though....
That's the same one I linked, Don. The "list" price is $44.99, but it always sells for less than that. Typical HF hanky-panky with the price listing, they frequently run a "sale" on them for $34.99 and list the 'regular' price as $54.99 (SAVE $20!), but if you're patient they run them about twice a year at $29.99.
I have severely beat on mine for two years and haven't broken one yet. I mean, really abused them. Frankly I was surprised. When you put 290 pounds on the end of a 3' cheater pipe and bounce on it, and nothing breaks but the grip of the bolt on the nut, that's good stuff.
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! Last edited by hornhospital; 01-16-2013 at 01:48 PM. |
Sorry OP, I jacked this thread. I will go back to HF this weekend and see what I can find. They had a tent sale or something last weekend, nothing good though. Thanks Ken and Don, I have options and alternatives now.
I was really looking for the set I got a year or so ago. It's a set of combination wrenches that has the same as this set that goes from 8mm to 32mm that I got at HF for $22.
Wrench and whack. Sometime even with channel locks works. Or a wedge between the belt and pully if it turns. Fortuniately, never needed more.
Channel Locks, grip, rubber mallet strike, done. Done in no time.
Wonder how replacing the cloth strap on a strap wrench with a length of an old belt would work on this and other applications ?
Cheap Trick |
What's wrong with the belt already on it?
The Evolution of a Lady Quote:
Member of the Non-M Bumper By Choice Club![]() |
I actually had a few strap wrenches that were made with a thick rubber strap. They were a little unwieldy though and I never cared for them, so I'm not convinced it would work on this. Again, just a quick whack with the mallet. There's no problem with that and it's dead simple. Sent from my LG Revolution 4G using BimmerApp
Just thought strap wrench with old belt ould provide better grip with leverage of the wrench if nut was really tight. Never tried just hiting the wrench with a mallet - will try next time. However when tightening I would feel more secure holding the pully than whacking it back tight. I did make a holding tool out of some scrap steel using a blown water pump to get the shape and holes right. Works a bit better than levering a screw driver across the bolts.
Cheap Trick |
Steve Calypso Red 1992 525i with 170K miles 1991 735i - Sold 1992 525i - Sold 1995 325is - Sold 2000 528i - Sold
That's the purpose of the left hand thread's BUT, you still need to make certain it's tight or you may go through 2 new fans in 3 days like I did. I'd replaced my fan because it chucked a couple of blades and when I put it back on I relied on the friction of the belts to hold the nut while I tightened it. This is a bit extreme but a couple days later during hot weather and after sitting in a drive through line for a while, probably long enough for the viscous clutch to kick in and be spinning the fan, I needed to pull out into traffic. It was a 6 lane road and I had to really get on the throttle to get across the first three lanes then back down to a stop to wait for an opening in the direction I needed to go. Apparently the quick acceleration with the viscous clutch engaged followed by the hard deceleration left enough inertia in the fan that it loosened the nut and spun out and off the water pump. Fortunately it only damaged the fan shroud and didn't puncture the radiator! Sooooo......my advice and now my practice is I give the wrench a couple whacks with the hammer to tighten the nut and finish off the job.
Yes rotation direction "tends to'' tighten it but being an old belt and suspenders guy for this type of thing I use the words "tends to" rather than - will definitly will keep it tight and act accordingly. I believe Chrysler cars in years past had left hand threads on their lug nuts for the same idea but they still told you to snug them up. How do the rest of you feel about how much to tighten the fan nut ?
Cheap Trick |
![]() This is what the Bentley says.
To actually use a torque wrench you would need a 32mm crows foot. However lacking that you could just put a nut & bolt in a vice or what ever and torque it to the specified torque a few times to get the feel for it and then torque the fan nut with a plain wrench to the same pull feeling. Should be pretty close and for sure a heck of a lot closer than a wack with a mallet, especially if no type of holding tool is used.
Cheap Trick |
