Old 01-16-2013, 12:09 PM
necero necero is offline
Mein Auto: 2000 BMW 540i
Service Engine Light - Code P1175
Hi Guys
Trying to get ideas of what might be wrong with my car. 2000 540i/6 with ~126k miles. Short story is my check engine light came on. Took it to the local auto place and the code came up as P1175 (fuel trim adaptation additive bank 2 malfunction. Explanation: large vacuum leak on engine).
What's happening is for the first few minutes after a cold start my idle is pretty rough. Every once in a while when the car is moving and I take out out of gear and don't have the clutch pressed the revs will drop to 0 and the engine will die. The problems go away as soon as the temperature gets to the normal running temp.
I have searched around and everything I have found shows that P1175 is accompanied by P1174. I have yet to find anything that shows only P1175 being thrown, which is my case. From reading around it seems it could be anything from the MAF sensor to gaskets/o2 sensors.
I recently replaced the alternator (for the second time, first replacement alternator went bad) a week ago or so and am wondering if the vacuum leak could have been caused by anything I may have taken off and not put back properly (specifically the air filter housing). My dad also decided he wanted to clean my MAF sensor just before I did the alternator. I am curious as to if there is the possibility of that being cleaned or re-installed improperly which could be causing the problem.
tl;dr - CEL throwing code P1175 only. Any help or ideas would be greatly appreciated. Thanks!
Old 01-16-2013, 12:43 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
How many miles on the pre-cat O2 sensors? If original, you're overdue for replacements.
You could also take it to a shop for a smoke test.
Old 01-16-2013, 12:46 PM
I assume they are the originals, but am not positive. I have all of the service history so I could go digging and find out.
Old 01-16-2013, 06:08 PM
DHoang's Avatar
DHoang DHoang is offline
Gearhead
Mein Auto: '98 528i, '82 323i
That p code by itself is pointing to your air mass sensor, likely contaminated. You are dead on in suspecting that your dad may have done more damage than good.
http://www.bimmerfest.com/forums/picture.php?albumid=4132&pictureid=24642
Old 01-17-2013, 07:52 AM
Yeah, I'm hoping it's just that. Do you think just cleaning it would solve the problem or is a new one in order? Is there any way to test and see if that's the issue? I think I remember reading in other places that people unplugged the MAF sensor temporarily and the rough idle stopped which meant it was an issue there.
Either way I think I'm going to replace my pre cat O2 sensors, seems like something that needs to be done eventually anyway.
Old 01-17-2013, 08:01 AM
I typed /MAF F3 in the bestlinks, and these came up which may help:
- Mass air flow sensor (MAF) & idle control valve (ICV) require periodic cleaning (1) (2) & buying a replacement MAF cheaper than the BMW MAF (RangeRover MAF) (VW MAF) (Hyundai MAF) & cleaning the throttle body (1)
