Old 01-18-2013, 03:56 PM
kpex76 kpex76 is offline
Mein Auto: 02 530i sport
Angry post cat O2 sensor
Hello everyone. I've been trying to replace the two post cat O2 sensors.
I know where they are located but where is the connector for the two sensors?
Does anyone have a DIY for the two post cat O2 sensors?
BTW, mine is a 2001 530i.
Thanks a bunch!
Kevin
Old 01-18-2013, 04:11 PM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
Why do you change them? Did you get a post cat inneficiency code?
The post cat sensors should connect on the left side of the engine (driver's side) - opposite of the pre-cat sensors (mirrored, but on the other side of the engine).
You will need to have the car jacked up safely on stands, then once the old ones are out, you will need to fish the electrical cable & connector with a string or a wire. You might want to observe the original routing.
Old 01-18-2013, 06:00 PM
Thanks for that info Doru.
I will try that next weekend.
Old 01-22-2013, 09:28 AM
tdbtexas tdbtexas is offline
Mein Auto: BMW 530i 2004
help help please
BMW 530I 2004 error code P0057 HO2S heater control circuit low --> O2 sensor bank 2 sensor 2
Please help, what is part number or pre or post Cat sensor ?
thanks
Old 01-22-2013, 10:05 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
You need to post this on the E60 forum.
Old 01-22-2013, 10:17 AM
Fudman's Avatar
Fudman Fudman is offline
As Doru said, Why? The post cat O2 sensors are rarely replaced. Most folks just ignore them as their function is sort of useless. Put the money elsewhere.
