What color is this? Oil level sensor or oil pressure sensor? - Bimmerfest - BMW Forums
Old 01-20-2013, 11:16 PM
shroomer shroomer is offline
Mein Auto: 2001 BMW 330i
I am colorblind and I have no idea if this is red or yellow. I need to know if I need to replace the oil level sensor or the oil pressure sensor. From what I understand, if the light is red, I need to replace the pressure sensor. If the light is yellow, I need to replace the level sensor. That is, as long as my engine is ok. Also, the actual oil level is fine.
Any constructive input would be appreciated.
Name:	BMW light.jpg
Old 01-20-2013, 11:21 PM
GLOK1132 GLOK1132 is offline
Mein Auto: 2002 325i
take a picture and post it. Then we can help you out accordingly.
It would help if I attached a pic. Duh.
Name:	BMW light.jpg
Old 01-21-2013, 03:24 AM
Mein Auto: ///M
first thing u need to do is check the readings on the oil dipstick and fill it if it requires some.
- if u get this yellow light for 20-25 seconds as soon as u start your car and goes away then u have a bad oil level sensor.
- if the light comes on as soon as u turn off ur car or randomly when u'r driving, then u r missing at least 1 quart of oil
Old 01-21-2013, 04:08 AM
SeaRay SeaRay is offline
Mein Auto: 2002 330i
It's yellow. Mine does the same as stated above. Comes on for approx 20 sec at startup, then goes out.
Old 01-21-2013, 06:02 AM
Dave 330i's Avatar
Dave 330i Dave 330i is offline
The King of Common Sense
Mein Auto:
Am I correct to say that (old) oil can icon is always amber, and never red? I have this issue maybe one can diagnose for me. 10-15 seconds AFTER the engine has started, whether if it is cold or warm, the oil icon comes on (amber color), then it goes off approximately 20 seconds later. I know I do not have an engine lubrication problem. I believe it is a sensor problem. How easy is it to replace this sensor? If the sensor is not reliable to predict a lubrication problem, what good is the sensor?
Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid. Albert Einstein
Swim upstream. Go the other way. Ignore the conventional wisdom. If everybody is doing it one way, there’s a good chance you can find your niche by going exactly in the opposite direction", Sam Walton.
Old 01-21-2013, 07:15 AM
joegr joegr is offline
Originally Posted by Dave 330i View Post
Am I correct to say that (old) oil can icon is always amber, and never red? ...
This very same icon does come on red if there is no oil pressure.
Old 01-21-2013, 07:53 AM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
Worst. design. ever! Something this important should have a warning sound and bright flashing light attached to it, like the low fuel light. Something you can see and hear from space would be good.
I see mine (yellow) almost every time I arrive home. I drive up a steep hill, then a steep driveway and park in the garage. Light is on after I shut down... I wait a few minutes, check the level, and it's usually OK. My car does use some oil so I just keep an eye on it.
I usually don't see the light when I'm roaming around the flat areas outside of where I live.
Jeff R.
Old 01-21-2013, 08:17 AM
1972ford's Avatar
1972ford 1972ford is offline
Function over fashion
Mein Auto: 325xiT
... topped only by the absence of a dipstick...
Old 01-21-2013, 04:34 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Which means you have a bad oil level sensor.
Old 01-21-2013, 06:39 AM
1972ford's Avatar
Mein Auto: 325xiT
Dave, it sounds like you're in the same boat as the OP, with a bad oil level sensor. It seems that the computer can tell when the sensor is giving bad readings and it lets you know it's failing / failed. It's super easy to change... when you're doing an oil change, being that it's in the bottom of the oil pan. Let's just pretend that BMW didn't decide to remove the dipstick and use ONLY the sensor in the next-gen engines. In my wife's car, there's a little plastic access panel for the oil drain plug, and one for the oil level sensor. Tell you anything??
Old 01-21-2013, 08:06 PM
Dave 330i's Avatar
Mein Auto:
Fortunately, the 330i belly pan does not extend back to the oil plug, so when I change the oil I do not have to remove any plastic covers. Where is the sensor? I never noticed one because it never occur to me to look for it when I change the oil.
Old 01-21-2013, 08:31 PM
gtb gtb is offline
Mein Auto: 325ci e46
Smile common sense
Thankyou kind sir, regrettably, common sense is not so.
Old 01-21-2013, 06:26 PM
gtb gtb is offline
yes, indeed sir
