Old 01-22-2013, 07:11 AM
Complete list of all o-rings (by size & by part number) to buy when ordering parts
I was ordering oil filters today when I realized I should have a ready-made list of o-rings by part number to get while I'm already ordering other stuff (not just for oil changes but for all maintenance jobs).
It was untimely, while on the phone, coming up with the part numbers on the fly for optonal o-rings, so, I belatedly realized that it would have been useful to have a ready-made list all the o-rings we might wish to keep in mind to get the 'next' time we're already buying parts.
Here's my starter list below - but the point of this thread is for others to ADD other necessary maintenance o-rings (& rubber o-ring-like gaskets) for adding to existing orders and to keep in stock in the garage.
NOTE: Please make sure the part number and the size & quantity needed is listed!
  • Two small o-rings on the bottom of the oil filter stem
  • Two small o-rings at the top of the oil dipstick,
    • 11431717666, 9mm ID x2.2mm Thick (Quantity=2) $0.73 each
  • Large o-ring on oil filter cap (usually comes with the oil filter)
  • Large o-ring at the bottom of the dipstick guide tube
    • 11431740045, 19.5mm ID x3mm Thick (Quantity=1) $1.81 each
  • Power steering cap o-ring
  • Lower radiator hose coolant temperature sensor o-ring (p/n is for the air temperature sensor in the intake manifold)
    • 13621743299, 8mm ID x 3mm Thick (Quantity=1) $1.25 each
  • Oil filter housing oddly shaped gasket
  • DISA o-ring gasket
EDIT:
By way of example, here are current prices from 4wheelsautoparts (which I assume are typical out there):
- 2 x Oil Filter Stem Seal, Lower (11427549573) = $3.64 ($1.82 each)
- 2 x Oil Dipstick Seal, Upper (11431717666) = $1.30 ($0.65 each)
- 1 x Oil Filter Kit, including O-ring, copper seal, and Mann filter (11427512300) = $4.60
- 1 x Oil Dipstick Seal, Bottom (11431740045) = $0.56
- 1 x Oil Drain Plug Bolt (11131273093) = $1.74
- 1 x Power Steering Reservoir Gasket Ring (32411128333) = $1.49
ID:	358748   Click image for larger version
ID:	358752   Click image for larger version
ID:	358753   Click image for larger version
ID:	358755   Click image for larger version
Old 01-22-2013, 08:10 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
Injector O-ring lower (Injector-to-engine) p/n 13641437486
Injector O-ring upper (Injector-to-fuel rail) p/n 13641437487
Old 01-22-2013, 08:12 AM
doru's Avatar
CPS to engine O-ring p/n 12141748398 (Item #9)
CPS O-ring (Intake & exhaust) p/n 12141748398 (Item #6)
Old 01-22-2013, 08:30 AM
doru's Avatar
WP O-ring p/n 11511711484
Water inlet/outlet pipe O-ring p/n 11531435808 (Item #7)
Distribution piece O-rings p/n 11617502761
ICV grommet (big soft "O-ring") p/n 11611437453
DISA valve O-ring - check German Auto Solutions (Gary)
Old 01-23-2013, 09:39 AM
EDIT: I just realized that all the confusion may be due to the fact that one of these "CPS" above may actually be a CKP (crankshaft) while the other two are CPS (camshaft)!
Interestingly, here is a picture of a reputed CPS o-ring gone bad just now reported today:
These photos from this thread show the M54 intake CPS & exhaust CPS locations:
A good picture of the CPS o-ring is in this thread:
ID:	358881   Click image for larger version
ID:	358882   Click image for larger version
ID:	358883   Click image for larger version
ID:	358886   Click image for larger version
Old 01-23-2013, 10:26 AM
EDIT: I'm very confused. I think one of these CPS's must actually be a CKP. Right?
Having had no experience with the camshaft position sensor (aka CPS) or the crankshaft position sensor (aka CKP), I'm a little confused about how many CPS o-rings are needed, as three seem to be listed - but they're all the same part number???
  • 11 Engine > 11 15 Cylinder Head > Cylinder Head Vanos
    • # 06 Intake CPS O-ring 17mm ID x 3mm thick 12141748398 $1.20 <=== am I right that these are for the camshaft
    • # 06 Exhaust CPS O-ring 17mm ID x 3mm thick 12141748398 $1.20 <=== am I right that these are for the camshaft
  • 11 Engine > 11 10 Engine Housing > Engine Block Mounting Parts
    • # 09 CKP to engine O-ring 17mm ID X 3mm thick 12141748398 $1.20 <=== am I right that these are for the crankshaft
ID:	358900   Click image for larger version
ID:	358901   Click image for larger version
Last edited by bluebee; 01-23-2013 at 10:59 AM. Reason: Added diagram for clarity of the question.
Old 01-23-2013, 01:55 PM
For the record, this entire thread is on the M54 engine DISA o-ring, for folks coming here the first time.
The conclusion is to use a #139 Viton O-Ring.
The reason is shown below:
Old 01-22-2013, 09:12 AM
crazy4trains's Avatar
crazy4trains crazy4trains is offline
Mein Auto: 2002 530i Sport
[*] Power steering cap o-ring
If anybody can tell me how to get the PS reservoir O-ring installed, that would be great. I cannot get it to stretch enough to sit, and stay, in the recess. And yes, the old O-ring has been removed.
Thanks!!!
2002 530i
Old 01-22-2013, 09:35 AM
This isn't really the thread for that; the right thread for that would be found by typing /power steering F3 in the bestlinks, which comes up with this:
- How to remove and replace the power steering cap o-ring (1) (2)
Old 01-22-2013, 12:10 PM
Fudman's Avatar
Fudman Fudman is offline
Interesting thread. I have ignored (or more to the point, been ignorant of) these o-rings completely. Are there any recommended change intervals for these o-rings from any reputable source? I don't remember seeing any guidance in Bentley's. And I hate looking through the TIS. Mine are all probably original. Another thing(s) to replace...
Old 01-22-2013, 12:20 PM
doru's Avatar
I know last summer when I changed the O-rings on the distribution piece, they were hard as rock. Literally. The new ones are a tad softer - they are hard to replace.
They do deteriorate in time, sometimes it's a leak (like the oil leak by the CPS). Sometimes it's vacuum leak (DISA). BTW, Gary's O-rings work well, BUT: make sure you lube them lightly, then when you re-install the DISA, be VERY GENTLE in pressing it in. You have to actually rotate it back and forth and press it very gingerly in. Otherwise, the new O-ring will shear. Ask me how i know.
The PS O-ring, once you start seeing ATF on the canister - it's a dead givaway. I always thought it's soiled because of the vent hole. I was wrong. Since I change that sucker, I never had a drop of the red stuff staining the canister.
Old 01-22-2013, 02:20 PM
According to RDL in post #118 here, the BMW TIS recommends the two little o-rings on the bottom of the oil-filter-housing stem to be replaced at EVERY oil change!
- How NOT to change your oil!
I doubt anyone does it that frequently
- but it's apparently in that TIS.
All I have is this screenshot ... so if you have the TIS - let us know what it actually says.
Old 01-30-2013, 12:50 PM
Is this the DIY thread for those o-rings:
> E39 (1997 - 2003) > Injectors replacement and/or servicing DIY
Old 01-22-2013, 05:27 PM
The O-ring I bought appears to be too small and I can't get it to stay in the miniscule recess. Such a simple thing but very frustrating.
It's too cold right now to mess with any further so I'll try again later.
2002 530i
Old 01-23-2013, 03:10 PM
champaign777's Avatar
i am too lazy to replace large o-ring on oil filter with every oil change
normally it lasts forever ( if you dont screw it ) , never oil leak from it
Old 01-23-2013, 05:49 PM
Steve530 Steve530 is offline
Mein Auto: 2001 530i
I searched realoem for O-ring. The search returned a list parts with the term "ring" in the description. I edited the list to include only the descriptions with the term "O-ring". Hope this helps.
Here's the list:
Part 12141748398 (O-ring) found in: Engine Block Mounting Parts
Part 11361703713 (O-ring) found in: Cylinder Head Vanos
Part 12141748398 (O-ring) found in: Cylinder Head Vanos
Part 11511711484 (O-ring) found in: Waterpump - Thermostat
Part 11431717666 (O-ring) found in: OIL PAN/OIL LEVEL INDICATOR
Part 11431740045 (O-ring) found in: OIL PAN/OIL LEVEL INDICATOR
Part 11421741000 (O-ring) found in: Lubrication system-Oil filter
Part 11421744001 (O-ring) found in: Lubrication system-Oil filter
Part 11427549573 (O-ring) found in: Lubrication system-Oil filter
Part 11531435808 (O-ring) found in: Cooling System Water Hoses
Part 11417507429 (O-ring) found in: Lubrication system/Oil pump with drive
Part 11411722837 (O-ring) found in: Lubrication system/Oil pump with drive
Part 13621743299 (O-ring) found in: Intake manifold system
Part 11617502761 (O-ring) found in: Intake manifold system
Part 12141748398 (O-ring) found in: Sensors
Part 13711720540 (O-ring) found in: Intake muffler
Part 13641437487 (O-ring) found in: VALVES/PIPES OF FUEL INJECTION SYSTEM
Part 13641437486 (O-ring) found in: VALVES/PIPES OF FUEL INJECTION SYSTEM
Part 13531720251 (O-ring) found in: Fuel filter, pressure regulator
Part 13531720252 (O-ring) found in: Fuel filter, pressure regulator
Part 17211742636 (O-ring) found in: TRANSMISSION OIL COOLING
Part 24201423387 (O-ring) found in: A5S325Z lubrication system
Part 24311422806 (O-ring) found in: A5S325Z lubrication system
Part 24201217321 (O-ring) found in: A5S325Z Output
Part 24341421736 (O-ring) found in: A5S325Z wiring/oil filt./pulse generator
Part 24101423176 (O-ring set) found in: A5S360R/390R ctrl unit with mount.parts
Part 32321094182 (O-ring) found in: STEERING LOCK/IGNITION SWITCH
Part 17211742636 (O-ring) found in: HYDRO STEERING-OIL PIPES
Part 33117525064 (Screw plug with O-ring) found in: Final drive, gasket set
Part 34311165092 (BRAKE MASTER CYLINDER O-RING) found in: BRAKE MASTER CYLINDER/EXPANSION TANK
Part 34311165092 (BRAKE MASTER CYLINDER O-RING) found in: Power brake unit depression
Part 64118385686 (O-ring set) found in: HEATER RADIATOR AIR CONDITIONING
EDIT: added files, remove .pdf.
Steve
2001 530i/5 S+P CDV delete/Akebono ceramic pads
M5 SSK/RedLine MTL/M5 rear sway bar/Bilstein HD
OSRAM CBI
BMWCCA Member #337964
Old 01-25-2013, 02:54 PM
Originally Posted by Steve530 View Post
Here's the list:
Thanks for that list.
It would be nice if a supplier puts together a kit for our E39s.
I can see them making a profit because, in bulk, the o-rings are pennies, whereas they can charge us a buck or so, and the kits won't take a lot of room on the shelf, and can be easily adapted for other vehicles.
By way of update, my rubber "kit" arrived today, complete with a few extra sets of the hard-to-find 441 (61610154441) wiper blade inserts and a spare oil bolt & crush washer, in addition to the list of o-rings earlier discussed in this thread, each in their own labeled baggy.
Old 01-25-2013, 05:24 PM
Looks like you got a new HID lamp, too.
I've attached the list I posted above, supplemented with parts listed as gasket seals and sorted by application. It's a PDF file. If anyone needs the spreadsheet, PM me.
Steve
OSRAM CBI
Old 01-25-2013, 08:37 PM
Wow. Very nice. This is a complete 'kit' for a supplier to create for us, since most of our o-rings are a decade old by now. We could then put the kit on our garage shelf, and, whenever we're taking apart something nearby, we'd have the handy o-ring to replace.
For example, when doing the CCV, we could do the CKP and CPS o-rings, in addition to the lower dipstick tube o-ring.
You're observant! I sat down to open the box that came in the mail, and as I laid everything out to compare to the invoice, I snapped the photo, so I hadn't thought of mentioning the bulb.
I bought the bulb because my low beam indicated it was out. Funny thing - the moment I pulled the old bulb out, it lit right up in my hands.
So now I have an extra H7 bulb, just in case, to stock along with my o-rings.
Oh well, it will eventually get used (as long as I don't lose it, which I am wont to do).
Hmmmm...
Maybe we can open a separate thread, that references this thread for o-rings, that lists all the "stuff" that we can stock to put on the shelf - that our ten year old bimmers are gonna eventually need.
EDIT: I opened this thread for all "stuff" that we probably should stock in our garage:
- Complete list of E39 stuff (parts, tools, fluids) to stock for handy eventual use
Old 01-27-2013, 05:32 PM
Updated post #18.
Steve
OSRAM CBI
Old 06-27-2014, 12:58 PM
Flybot's Avatar
Flybot Flybot is offline
Mein Auto: '98 528
Interesting thread. In all my years of wrenching on cars I have NEVER ordered parts by part number. Every time I just give the parts guy make, model, year and engine size and he does the rest. If there is any question, the VIN number resolves it. In the case of a standard washer, o ring, nut or bolt you can eaither measure the required size yourself or take it in and the parts guy matches it. Never had an issue with on line orders eaither. That's what part stores are for.
When someone says "What year is your Bimmer?", I say "What part".
Old 06-27-2014, 10:11 PM
O-rings are a bit different, because I can't imagine calling up a BMW parts guy, and then having *him* source them for you, one by one over the phone. They'd kill you if you asked for the fifty cent o-ring here, and the twenty-cent o-ring there and the ten cent o-ring there, etc. After an hour on the phone, he'd have an order totaling about ten bucks!
Plus, we all know the propensity of BMW to use the wrong material for the o-rings.
So, it makes sense to know the SIZE of the o-ring, and then order from an o-ring supplier, the best materials, at the list of sizes here.
It just takes collecting the sizes together into a single list, which, if we work together, we can do.
Someone might even make money collecting a set of the o-rings needed, and selling them as a set.
I've even thought of that myself, but I don't know if it would be worth the effort.
Old 07-02-2014, 09:04 AM
There is a good discussion of whether it's the o-ring or the q-tip which stops the misting (personally, I find it to be the o-ring) and how long that o-ring lasts, over here, today:
> E39 (1997 - 2003) > Power steering reservoir
Originally Posted by danlau View Post
Hi, I have a 2003 BMW 525i, and I notice that there is a small leak of power steering fluid. It seems to come from the ventilation hole on the cap of the reservoir. I wonder if I need a new reservoir.
See also:
- Glovebox printouts for emergency use (1) and how to save $ money to qualify for free shipping on UPS/DHL/USPS/FedEx by stocking O-rings & gaskets & bulbs & vacuum hoses & fuses & wiper blade inserts & belts & bearings & oil filters & cabin air filters & engine air filters & fluids in your garage whenever ordering from the recommended parts suppliers.
Old 07-21-2014, 11:14 AM
It should be noted that the canonical thread for the E39 VANOS o-rings size (only!) is here:
> E39 (1997 - 2003) > Would the next person who takes apart their VANOS please measure the o-rings?
  • ? #03, O-ring for Vanos Solenoid Switch, 21.0 x 2.5 mm, (Q=? per camshaft) BMW P/N 11361703713 ?
  • ? #10, O-ring for Vanos Blind Plugs (small), ? x ? (Q=1 per camshaft) BMW P/N 11361433513 ?
  • ? ##, O-ring for Vanos Piston (large), 23.52 x 178.0 mm (Q=1 per camshaft) BMW P/N 11361318788 ?
  • ? ##, O-ring for Vanos Piston (small), 14.5 x 1.8mm (Q=1 per camshaft) BMW P/N 11361403191 ?
See also:
> E46 (1999 - 2006) > VANOS seals dimensions
ID:	456084   Click image for larger version
ID:	456088   Click image for larger version
ID:	456089   Click image for larger version
ID:	456099   Click image for larger version
ID:	456100   Click image for larger version
ID:	456101   Click image for larger version
ID:	456102   Click image for larger version
Old 08-06-2014, 06:25 PM
For those who want to remove the waterpump, for whatever reason, and put it back, this thread shows that we need to figure out the gasket size:
> E39 (1997 - 2003) > Water pump gasket?
Originally Posted by ninetyseven1 View Post
Does anyone know if they make a rubber water pump gasket for our 540i's? This is the second time I have installed the new water pump and it still leaks. I used the paper gasket that came with it and a light bead of the orange hi temp RTV on both sides, let it sit for like 15 minutes and then installed the pump, tightened up the bolts , waited again a few minutes and then torqued them. Why the hell does this thing leak?? Is there a good factory gasket out there that requires no RTV?
I don't remember putting any goop on mine (here's a picture before putting my water pump back on):
But, what we're talking about is obtaining the size for this o-ring shown below:
o ring, o-ring, oil change, oring, parts ordering
