7 Series - E38 (1995 - 2001)
soft close trunk issues
i have a 2001 740il that the trunk appears to be dead. The button wont open it either. I have to use the key. The sunroof is doing strange things too. All the fuses check out. Is this a GM or other module problem?
Re:
Try re-programing your key.......
Fast enough for me
Check for damaged earths and plugs.
Check the rubber grommet at the hinges... The wires fatigue after time and break or short circuit
Are the earths for the soft close and roof motor both in the boot (sorry Trunk)? It could be the common point.
It takes five minutes to test, so, I'd first physically check the trunk / boot wire harness:
- How not to repair your bimmer trunk wiring loom (1) [ how to do it right (1) ]
Sort of like I said, wires, earth points and connectors. Repair wires with solder joints and shrink sleeve.
E38 soft close
Thanks for the advise, it works. I had a battery go dead and of course had the trunk opened to make the change, but now we are back in action.
