F30 / F31 / F32 / F33 (2012 - current)
The sixth generation 3 series, chassis code F30. 2013 model year 328i and 335i sedans now in production. Read the F30 frequently asked question thread for all your basic question and dive into all the details in the ultimate F30 information thread. |
Engine breaking?
I'm no engineer (obviously) but just wanted to ask if this is right.
I noticed when I'm in Drive and braking my rpm goes down then up and then down then up. It seems like it's down shifting while stopping. I would have thought that this would waste more gas. I'm just curious if anyone can explain why this is and why it would be more gas efficient? Or it's not gas efficient but help stop faster? Sent from my SCH-I535 using Bimmer App |
The transmission downshifts while braking so that it's in the right gear when you accelerate again. Pretty standard.
Downshifting helps reduce brake wear and as pointed out above puts your trans in the correct gear for moving out again. |
MY2013 328i, N26 / 300 / 4CG / KCDF / 2DW / 205 / ZDH / 302 / 3DZ / 403 / 494 |
My last car was 12 years old before I got this so haven't notice this type of things. Also, would this be bad for your transmission? I'm sure BMW has thought of everything and I'm sure it's ok but I'm just curious. My understanding is that if you have manual transmission and engine breaking would be bad on transmission. But then again this could be decade old fact. Sent from my SCH-I535 using Bimmer App |
Downshifting a manual will not wear out the clutch or other components if done properly. |
Engine braking serves two purposes: to start off in the correct gear (not as likely since if you accelerate, it will downshift anyways) and most importantly, generate enough vacuum to apply braking pressure. You do need high RPMs to get good vacuum, but if RPMs are very low, you will get limited braking power. Notice your RPMs are not "true" engine braking and stays under 1500 rpm with each downshift. (in real engine braking, you will be hitting 2k+ with each downshift) Fuel is cut off under no load with RPMs are above a set threshold. The injectors will kick in under that threshold. You can see this by revving the engine and then, as the RPMs drop, you see a slight bounce 1k. Its not BMW specific, pretty much all cars do this nowadays.
Ordered 4/20/2011 - Delivered 4/20/2011 ![]() Has a little bit of this, some of that - a happy camper. |
http://www.bmwusa.com/Standard/Conte...and_specs.aspx
Kenneth P. Gray 2013 - 328i xDrive Sport, Imperial Blue/Everest Grey Dakota Leather ![]() 2010 Cadillac SRX Performance, Platinum Ice/Ebony (Wife's drive) ![]() 2013 328i xDrive / 8-Speed / Imperial Blue / Everest Grey / Sport Package / Premium Package / Tech Package / Heated Seats Last edited by kpgray; 01-30-2013 at 09:39 AM. |
Thanks for all your input on this.
They do make sense. Like I said, I'm sure smart BMW engineer thought of everything in making an ultimate driving machine. It's nice to kind of understand some of them. Sent from my SCH-I535 using Bimmer App |
