Old 01-25-2013, 01:47 AM
See-5 See-5 is offline
Mein Auto: E66 750li
BMW E66 problem when refueling
Hi
I had this problem for over a year now
skip to ( 1:05 )
When refueling the filler thingy clicks at a random tank level ( mostly less than a half ) while it normally should only clicks if the tank is fully filled
And therefore as you can see it takes 4 minutes to refill the tank 0_0
What do you think is the issue ?
the computer gives this fault code :
2A13 DMTL Leak Diagnosis pump, activation
Thank you
Old 01-25-2013, 01:54 AM
Is this the solution http://www.bimmerfest.com/forums/sho...d.php?t=555805
Old 01-27-2013, 04:23 AM
up
Old 01-27-2013, 07:13 AM
gmcclintock's Avatar
gmcclintock gmcclintock is offline
Maintainin'
Mein Auto: 2006 750Li
Yes I think that thread is the solution, I had the same problem a while back and I had the vent valve replaced and never had that issue since. You might want to show that video to your SA and he/she will tell you exactly what is causing the problem.
<div align=center>
85 Honda Accord(Sold), 93 Lexus GS 300(Gave to lil Bro), 96 Lexus LS 400(Sold)
03 BMW 525i(Traded/Sold), 09 BMW 750Li, 07 BMW 530i, 04 Pontiac Grand AM (Daily Driver), 08 Ford Focus (Wife's Daily Driver)
Old 01-27-2013, 12:13 PM
Thx !
Old 01-28-2013, 08:11 AM
So it isn't the Vapor canister ?
It costs 407 $ :\
Old 10-23-2014, 06:01 PM
cl1987 cl1987 is offline
Mein Auto: 750i
It costs 407 $ :\
Where is this hose on a bimmer 07 750i. I think i need to clean mine out.
Old 01-22-2015, 02:14 PM
You can find the carbon filter inside the rear right fender . Just open the fender cover after taking out the wheel and you will see it at the top .
Old 01-28-2013, 10:36 AM
this part is what the fault codes described !
http://www.eeuroparts.com/Parts/2934...p-16137193479/
I must check with the workshop to ensure though
Old 01-22-2015, 02:12 PM
Its been three years now and I am still having this problem !
I replaced the carbon filter and the leak diagnostic pump once and the problem came back on after two months.
I use 95 octane premium gas only.
Next week the mechanic will open the car's computers to investigate this !
Old 10-23-2014, 10:37 AM
meangreen94z meangreen94z is offline
Mein Auto: 2004 BMW 745i sport
It sounds like you top your tank off. When the pump clicks once, that's it. If you top your tank off fuel will spill into the canister and saturate the charcoal filter and ruin your DMTL pump. You won't be able to pump fuel normally and it will set a fault sometimes for the pump.
Old 01-22-2015, 02:10 PM
I have never did that for your info . Even if I did so I don't think it should be that bad
