Old 01-25-2013, 08:21 PM
bmwswag bmwswag is offline
Mein Auto: 328i xDrive
Headlight Washer Won't Retract
I have a 2011 BMW 328 iXdrive. My headlight washers won't retract.
It's been really cold here in NYC (below freezing). Could this have anything to do with it? The last time I pulled the lever to clean my windshield, I probably ran out of fluid.
Any help is appreciated?
Order : 6/28/2011 Delivery : 8/13/2011
2011 BMW 328i xDrive
Black Sapphire Metallic | Leather Dakota Gray | Convenience | Premium | Navigation | Harmon Kardon | Heated Seats | iPod/USB
If you ain't gonna ride fly, then you might as well hate
Old 01-25-2013, 08:23 PM
-=Hot|Ice=-'s Avatar
-=Hot|Ice=- -=Hot|Ice=- is offline
Been there, Done that.
Mein Auto: Does it matter?
Not the cold. I had the same problem on my 2008 328xi coupe the first week I had it. The motor needs to be replaced because it has become weak. Time for a visit to the dealership.
Originally Posted by CaptainAudio
In the words of one of Bimmerfest's greatest minds:"Been there, done that"
Originally Posted by boltjaM3s View Post
Half the fun of succeeding in life is fighting the fight and making it.
Old 01-31-2013, 10:34 PM
ptrcd003 ptrcd003 is offline
Mein Auto: 328i LCI
This makes no sense. The motor pushes the washer out, a spring retracts it back in. His was stuck in the open position - what would the motor have to do with this?
Old 04-28-2013, 09:04 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Checking Bentley, as far as I can tell, headlight washers deploy as a plunger forced out by washer fluid pressure. If the pump is weak, there you are - can be a motor but is more likely degraded pump operation - seals etc. Headlight washers are a diff system than windshield washers though they may share fluid in the reservior.
But if a retractable washer's sticky, poss a plunger seal condition, it can not deploy well or may not retract. Temperature will def have an effect, warmer temps allowing a more flexible seal.
Obviously, ice is an issue.
Note: Headlight washer jets are replaceable, not a diff job.
Old 04-29-2013, 08:41 AM
Mein Auto: 328i LCI
Yes, but he had mentioned that his are getting stuck in the open position. Thus, the motor is doing its job of pushing them out with pressure - the retraction, as far as I can tell, has nothing to do with the motor.
Old 04-29-2013, 08:47 AM
Go to paragraph #2 my post above.
Old 04-29-2013, 09:16 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is online now
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
There is no motor in the washer assemblies. The washers are extended by hydraulic pressure from the washer fluid pump and retracted by an internal spring. I replaced/serviced a few of these--they were prone to leaks on the E46--and it's a pretty simple and elegant little mechanism.
They can get hung up for the reasons Cal noted. Lubrication is not normally required but there are always exceptions. OP probably developed a bit of ice, or maybe salt buildup, in a critical spot that later resolved itself.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 01-31-2013, 01:52 PM
Temperatures picked up and the headlight washer retracted back. Now it works again. I didn't even do anything =)
Old 01-31-2013, 10:15 PM
TXFred TXFred is offline
Mein Auto: 2008 335i Convertible
That's a clear sign that the mechanism needs to be lubricated.
Any idiot can be fast in a straight line. The corners are what separates the drivers from the commuters.
Old 01-08-2017, 01:03 PM
tahmadoff tahmadoff is online now
Mein Auto: bmw 550i 08
Don't know if your still on this site but this happened to me last night and this morning it is freezing nyc storm as you should know is this the reason why it happened
Sent from my iPhone using Bimmerfest mobile app
Old 04-28-2013, 05:49 PM
Wyatt Earp Wyatt Earp is offline
Mein Auto: 328xi
Mine are doing the same thing, going out but not retracting, did you solve this issue on your car?
Thanks.
Old 04-28-2013, 05:51 PM
crose6994 crose6994 is offline
Mein Auto: 2008 328xi
same here, it did it alot worse in the winter compared to now. it goes in a little bit now
Old 08-12-2013, 05:47 PM
tinbender tinbender is offline
Mein Auto: 2010 328idrive
headlight washer
where is nozzle for headlight washer located do anybody have picture of it?
Old 08-12-2013, 09:11 PM
fdriller9 fdriller9 is offline
Mein Auto: '06 AW 330xi
It's right in front and below of the headlight. If you have a small "door" under your headlight, you have headlight washers.
If your car was equipped from the factory with xenons, you have headlight washers.
| LCI Msport Conversion | Exotic Tuning Front Lip | H&R Coilovers | M3 Subframe Bushings | Custom Polyurethane Shore A90 Tension Strut Bushings | E93 M3 23.6mm Rear Sway Bar | UUC Front Sway Bar | Custom Heim Joint Rear Control Arms | Apex ARC-8 | Dunlop Direzza ZII Star Spec | Modified Dinan Cold Air Intake | aFe Oiled Drop-in Filter | Custom Hand-Made LED Angel Eyes | Alpine MRP-M500 | Custom LED Reverse Lights | OEM Blacklines | BMW Performance Trunk Spoiler |
Old 01-08-2017, 01:01 PM
This happened to mine any idea
