Old 01-26-2013, 03:22 PM
navyjetmech navyjetmech is offline
Mein Auto: Harley/Z4 3.0/Ram 1500
Issues with my Navigation
2003 BMW Z4 with DSP and NAV
The attached picture is the message I get on the NAV screen. First off I installed a soundplicity Iphone Integration kit by BSW. I did not use the DSP adapter I plugged in the 6 pin and 3 pin cables and the Iphone plays music just fine in the CDC mode. SOUNDS AWESOME. I noticed on the NAV screen after install the message you see. From what I can see I have satellites available. The last time I used the NAV it worked fine I could not tell you if this message was on the screen before I installed the kit, but i did disconnect the kit and still received the same message. I am waiting for BSW to call me to explain to me what purpose the DSP adapter serves and if not installing it affects my NAV. Has anyone had this message/issue and what do I need to do to fix it. I have already disconnected the battery and still have the same message. Thanks in advance for your help.
Old 01-27-2013, 09:25 AM
tonywintn tonywintn is offline
Drivin' the dream
Mein Auto: 2005 BMW X5 & 2007 Z4 si
I see that only when on a secondary road that is not fully implemented in the map disk. Drive out to a main road and see if the message goes away.
2007 3.0si w/Sport Pkg, Navi, Leather, Strut brace, garage door opener and delete airbag warnings on sun visors
Old 01-27-2013, 10:19 AM
Thanks for the reply! That was the problem. Time for an updated version I think.
