Clutch Pedal Squeaky - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 01-26-2013, 08:26 PM
Dave 330i's Avatar
Dave 330i Dave 330i is offline
The King of Common Sense
Mein Auto:
Sounds like the pedal pivot area, spring? needs a little lubrication. It squeaks upon release of the pedal. I blindly sprayed WD-40 up the pedal, but I could not see where the WD-40 landed.
Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid. Albert Einstein
Swim upstream. Go the other way. Ignore the conventional wisdom. If everybody is doing it one way, there’s a good chance you can find your niche by going exactly in the opposite direction", Sam Walton.
Old 01-27-2013, 06:37 AM
elhombre's Avatar
elhombre elhombre is offline
Mein Auto: 2003 325i, '99 e36 328is
There's a white nylon/plastic bushing around the clutch pedal pivot pin. If you remove the plastic cover above the pedals to expose the pedal pivot points, use the wand that comes with the WD40 to direct the spray onto the pivot point. Work the pedal while spraying it. Put some rags on the floor to catch the drips. It's a little messy and may take a couple of applications but eventually it will quiet down. I plan to replace the bushing when it's clutch time in a few thousand mi
Old 01-27-2013, 10:54 AM
Dave 330i's Avatar
Mein Auto:
Thanks, I'll try that, maybe later, but first more blind spraying with a rag to catch the drips.
