E60 (2004 - 2010)
Old 01-30-2013, 03:58 PM
themust themust is offline
Mein Auto: 2008 535i, manual blk/blk
Tire replacement?
Hey guys. Would like your quick thoughts on the following dillemma: Finally getting the Walnut Blast for the carbon deposits covered by BMW. Need a new battery $500? Really? Say there's 2 hours of work reprogramming the electronics. Also, and this is the big dillemma, My front tires are "cupped" and giving quite a bit of noise at freeways speeds. Annoying but not the end of the world. Continental DWs with 35000 miles and plenty of tread left (6mm). Replacing the rears as they are "toast." I hate to replace perfectly fine tires because of the noise. Any thoughts here or on the other items would be welcomed.
Old 01-30-2013, 04:11 PM
Oceans10's Avatar
Oceans10 Oceans10 is offline
Mein Auto: BMW 535i + 535XI wagon
Registering the battery takes 2 minutes. $500 is a rip off. Buy an Exide battery and have an indie register it for a $20 tip or something.
Styling: M5 body kit, M5 trunk spoiler, LED Angel Eyes, HID fogs, LED side markers, Jehnert Flatline speakers, Mobridge M1000 DA2 prepro, Zapco Z8 DSP, Zapco Z-150.6 amp, iDock on dash
Performance: JB4/G5 ISO flashed on Cobb, Meth Injection, AR Downpipes, ER FMIC and Charge Pipe, DCI, Walbro LPFP, RB turbos. H&R Sport springs/Koni FSD shocks.
Old 01-30-2013, 04:22 PM
Was just told by the dealer that the advice by BMW to replace battery was based on age, not cranking power. Clock losing time was about the Intelligent Battery Sensor. So keeping the battery but they want $450 for the IBS. Told them that that should be covered under CPO and will hear back on that shortly. Otherwise, I can live with resetting my clock periodically. Thanks for the quick response.
Old 01-30-2013, 06:28 PM
mostroad mostroad is offline
Mein Auto: 535xit
I replaced my 2008 535xi lead acid battery with an AGM from AutoZone
And reprogramed and registered it with NCS Expert and INPA. Took all of 10 minutes.
I see you're in the Bay Area. I'm in Marin. -- If you want to swing by with your new battery, I'll program and register it for you.
H8 AGM from Autozone:
http://www.autozone.com/autozone/par...er=319459_0_0_
If you want to stick with Lead Acid, so you don;t have to reprogram, but just have to register, you go with the 95r size:
http://www.autozone.com/autozone/par...ntifier=820339
Old 01-30-2013, 08:26 PM
Oceans10's Avatar
IBS is covered by warranty, I believe.
Old 01-31-2013, 06:53 AM
Jay Arras's Avatar
Jay Arras Jay Arras is offline
Mein Auto: 2007 530xi 6 speed manual
Hey Peder! What indie do you use?
Jay
Old 01-31-2013, 08:55 AM
Thanks for all of the responses. Yes, the dealer in Sac got the IBS covered by BMW CPO. So holding off on the Battery for now.
Old 01-31-2013, 03:08 PM
Phoenix1 Phoenix1 is offline
Sleeper Wagon
Mein Auto: 2008 E61
Get 4 new non run flat tires at Tire Rack and sell the 2 good ones on EBay. Make sure you get new tires pressure balanced and the alignment checked. Can do it at Tire Rack recommended installer, BMW Dealer will charge ~$200 for alignment and $150+ for install.
2008 E61/Monaco Blue/Natural Brown/Premium/Sport/Logic 7/Sirius/Escort 9500ci, Conti DWS. Build Date 1/08. HPFP replaced 6/10 and 4/11 Fuel Injectors replaced 3/11. Battery replaced 5/11 (warranty), sunroof seal replaced 10/11 free under SIB 540409. Pads and rotors replaced 11/11 under maintenance. Carbon buidlup on valves cleaned under maintenance 11/11. 59K miles. Original owner. BMWCCA Member. Route 66 Easy Street Warranty.
Old 01-31-2013, 03:11 PM
Sleeper Wagon
Mein Auto: 2008 E61
BTW - "Perfectly fine" DWS with 6mm left? I have those tires and you must be close to the wear bars...
Old 01-31-2013, 06:20 PM
racooper3 racooper3 is offline
BMW Master Wannabe
Mein Auto: 2005 BMW 545i
Hence the road noise. ;-)
Sent from my DROID RAZR HD using Bimmer App
