OEM dealer coolant
Anyone have any idea what is different about this besides the color? I am wondering if it is phosphate free or has some other kind of additives to prevent corrosion/cavitation or premature corrosion of the hoses. I was looking for the msds sheet for it or even the chemicals listed, but no luck. I was wondering if it was the standard ethylene glycol base etc. any help or redirection would be I help. Thanks guys.
-Tony |
My jug of it doesn't say anything about phosphate free. Ethylene glycol based.
I'm interested in seeing what people have to say as well. I personally notice that BMW coolant leaves more of a residue than traditional green stuff If spilt. Honda coolant did it too, they both smell different to me as well. All useless information ha |
At least you were of some help and company
. I have been using the Green colored antifreeze found at most parts stores and haven't had any problems. I just want to know if the dealer coolant is best for my engine or if using parts store coolant is ok.
-Tony |
On my Honda, it seemed like it was forbidden by other forum members to use auto store stuff. I have yet to
hear anyone swear by it here. They are both ethylene glycol based. |
That is what I heard too! That is why I was asking and wondering if it has IAT, OAT, or HOAT on it also.
-Tony |
Other types of coolant are compatible. See this for details:
http://www.bimmerfest.com/forums/sho...38&postcount=1 |
Lets save the research time and effort. Buy 1 gallon of BMW concentrated antifreeze and a gallon of distilled water. Mixed them together to make 2 gallons of read-to-use antifreeze. Cost about $26, so $13/gallon. Same price as other pre-mix antifreeze from auto part stores. Why not use the legitimate one that is made for bimmers?
![]() 01 Anthracite 525i Sport, with 01 E53 3.0 and 91 Z32TT |
- Fundamental BMW decision-making religious camps (1) & motor oil Petrolism (1), coolant decisions (1), & gasoline dogma (1) So, my recommendation is to start here, by understanding fluids used by most here: - Glovebox printout: BMW E39 fluid summary printout for your glovebox (1) Specifically for coolants: - Coolant: Coolant, for engine, automatic transmission, power steering, and AC evaporator cooling (1) & bleeding (1) (2) (3) or refilling DIYs (1) Here's a starter quote: Quote:
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! |
Bluebee, you are the man! Thanks for the links and quote. I will get to reading. As for initial thoughts, I want quality stuff, but if my green ethylene glycol stuff does the "same job," then I don't mind. I will look into this. Thanks again!
-Tony |
If you can sit for an hour, this is interesting (albeit a schill):
I like your thinking
. Why put a ford part on a BMW when you can use the quality BMW piece that will last and be designed for the particular car?
-Tony |
Assuming similar engines and similar expected use, antifreeze for one engine would be the same as antifreeze for the next similar engine - no matter who makes that antifreeze. Of course, any SPECIFIC antifreeze will have its own chemical makeup - and THAT is worth discussing - but - whether Ford makes it (or specifies it) versus whether BMW makes it (or specifies it) is, to me, absolutely meaningless as a comparison. The only difference between Ford and BMW is the M A R K E T I N G. If you fall sway to marketing, then, by all means, only buy the blue stuff. If you want chemistry, then first read all that is in the links I provided. Take specific note that the water we analyzed from NY and from where I live (San Jose) easily meets BMW specifications - so you can save that distilled water for the battery (where it actually matters more).
I will bookmark that for when I get off work blue. I use the same stuff fyi
-Tony |
I'm not sure I I misunderstood your text or visa versa, but I was agreeing with you. I sometime do not explain things very well and makes no sense to others. Glad for the clarity.
-Tony |
If, after reading those threads, you _still_ have questions, then it would likely be best to ask in those threads, since that's where we keep all the information together. Do that (asking in those canonical threads), and the advantage is we can point the NEXT person to the answers you obtained. It's how the forum works best! ![]()
It seems to me that we can use any brand/type of antifreeze we want as nearly every modern coolant on the market is approved (by their manufacturer) for use in these engines, protects for 5yrs 150k miles and will outlast our radiators, expansion tanks, and water pumps that need replacement about every 100k miles.
Note: Bluebee, I can't thank you enough for all the fantastic links to prior posts covering so many areas. The amount of time, effort, and comprehensive information you've compiled and contributed to this site is impressive! Last edited by Ltmax; 02-02-2013 at 09:18 AM. |
