6 Series
Old 02-03-2013, 10:24 AM
davidrhenley davidrhenley is offline
DanielIslandDave
Mein Auto: 2007 BMW 650i
2007 650i Engine Coolant Leaking?
I first noticed in December 2012 that my coolant level was low because the warning light came on. Long story short I added 1/2 gallon of distilled water and the light has stayed off since.
Today I decided to check the level and the stick that bobs up in the water was not sticking out. So I added most of the remaining gallon of water to completely fill up the coolant tank.
I have to take it to be serviced for brake fluid so I guess I can ask about it then.
In the meantime, any ideas on what could be happening?
I don't know that much about cars so anything I could say that would keep me from getting completely taken advantage of would be helpful since I'm taking it to the dealership ('cause they give me a loaner car and I'm a single guy without another ride).
Old 02-04-2013, 11:21 AM
07 E63650i's Avatar
07 E63650i 07 E63650i is offline
Living in Fast Forward
Mein Auto: 2007 E63 650i
Oh no. You may have the dreaded coolant pipe leak that has plagued the N62 engine. Do a search on this topic as it can be a main factor for such a large loss of coolant.
Once a 6'er, always a 6'er.
Old 02-04-2013, 11:58 AM
andrewpk andrewpk is online now
Mein Auto: 2005 645 Ci
Check for leaks around your coolant expansion tank. That's typically the must likely source.
I just replaced mine over the weekend. It finally sprung a real leak after dripping slowly for a month.
Old 02-05-2013, 02:33 AM
bimmerzone's Avatar
bimmerzone bimmerzone is offline
Supporting Vendor
Mein Auto: E63 650i
Could be a simple leak from a hose, or the tanks.... or as bad as the transfer pipe, i would get it checked out, good luck!
| Bimmerzone.com | 1-800-357-7797 | info@bimmerzone.com | 831 Lincoln Ave, Suite 3, West Chester PA 19380 |
Video about Bimmerzone: http://www.youtube.com/watch?v=me5pjPS88Bw
We are proud to be Authorized Dealers for: Sprint Booster, Peake Research, Eisenmann Exhaust, Hartge, RPI Exhaust, AutoEnginuity, Bentley Publishers, Zymol, P21S, PowerFlex USA, Brembo GT, KW, Hawk and much more!!
Old 02-05-2013, 06:58 AM
tampamark tampamark is online now
Mein Auto: 2006 650 convertible!!!
You need to check a couple of places, some have been listed, but there is one not mentioned and is a common leak point. And a minor fix!
On the passenger side of the engine at the front, there is a lower radiator hose, in it is a sensor. The O-Ring fails and it could be leaking from there. The fact that yours is not coming out rapidly lends itself to a smaller leak point. If you take it to the dealer they will replace the entire hose and sensor for several hundred. But you can just buy an O-Ring from Home Depot and fix yourself.
http://www.bimmerfest.com/forums/sho...d.php?t=578644
Old 02-05-2013, 08:02 PM
HerbP HerbP is offline
If you are losing coolant, the expansion is most likely going to fail shortly! I would suggest changing the expansion tank, the bleed line, & the 0-ring for the coolant sensor. They can all be done within a hour. Overkill maybe, but the expansion tank will fail soon.
Good Luck!
Old 02-09-2013, 06:54 PM
Nitrogen Nitrogen is online now
Mein Auto: BMW 650i Convertible
While I was replacing my heater control valve I found this.
Sorry pics are low quality it was dark and I used my phone. Look at the shimmering areas that is coolant leaking. I have been topping off every 2 weeks.
I took apart my fire wall cover and this is the back side of the engine.
This is the back of intake manifold. You think the curse has hit ?
I hear it leaks from the front more often but how often from the rear?
Sent Via iPhone using BimmerApp
Old 02-09-2013, 11:15 PM
07 E63650i's Avatar
Attachment 361601
Attachment 361600
Oh no, say it ain't so!
