Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M Series > E90/E92/E93 M3 (2008+)
The latest and greatest V8 powered M3!
Old 02-03-2013, 06:21 PM
Jaysea7 Jaysea7 is offline
Mein Auto: 2011 M3 coupe
Question Oil Blowby from Filler Cap
I noticed some oil streaks around the oil filler cap. Is this normal?
Old 02-07-2013, 09:06 AM
TeaRex714's Avatar
TeaRex714 TeaRex714 is offline
Mein Auto: 2008 E90 M3
I just discovered Monday that mine has started doing that! It hasn't before now, so I don't think it's normal. A new cap is about $20; I might just replace mine in case it's the seal getting stiff or something.
2008 M3 Sedan Alpine White / Fox Red
Old 02-07-2013, 12:08 PM
thekurgan's Avatar
thekurgan thekurgan is offline
Bad Lieutenant
Mein Auto: S65B40 Powered
This is a known issue. There was a part change on the cap after '10 I believe. One key thing is to keep the cap rubber ring clean as well as the mating surface. Make sure neither surface is dry, or the rubber will bunch up. You can also gently bend the fasteners to make a tighter seal.
08 E90M3 6MT Alpinweiss/Schwartz
Old 02-07-2013, 03:33 PM
Thank you for the tip.
I'll have a look tonight.
Jaysea7
