E34 (1989 - 1995)
Old 02-06-2013, 04:23 PM
CJ74753 CJ74753 is offline
Location: High Point / Thomasville area of North Carolina
Mein Auto: 91 BMW 525i
Question Throwout bearing just went out. How difficult is it to replace?
Well my throwout bearing has been whining for a little less then a week and it just went out completely. Won't go into gear while started, can put it in gear push clutch in and start it but after a few seconds the clutch grabs and stalls. How difficult of a job is this? What all should I replace?
Old 02-06-2013, 06:23 PM
cutter67 cutter67 is offline
Mein Auto: 530,m6,633
You will have to drop transmission. Change everyting the clutch pressure plant throw out bearing and have flywheel refaced
Old 02-06-2013, 06:35 PM
BMWFatherFigure's Avatar
Old School
If you have a hydraulic clutch refurbish the master and slave cylinders too.
Current:
E38 Parts Car
Previous:
Old 02-06-2013, 08:45 PM
My car has 220k miles on it give or take..what absolutely needs replacing? I see Pelican Parts has a clutch kit with
Three piece Sachs clutch kit
New bolts for flywheel* and clutch pressure plate
New exhaust gaskets
New crankshaft rear seal (aka flywheel seal)*
New transmission Input Shaft seal
New pilot bearing
New release bearing spring clip
New clutch pivot pin
New selector rod seal
New slave cylinder
Is any of this overkill? The $430 price tag makes me cringe though considering I just dropped $95 to tow it home. Think I read that I'll also need a clutch alignment tool and a pilot bearing puller is that all?
EDIT: Is this the correct parts? http://www.rockauto.com/catalog/more...733&cc=1434736 looks like its the clutch, pressure plate, line up tool and TOB.
Old 02-07-2013, 12:03 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
people are saying to change the clutch and pressure plate and resurfacing the flywheel because of where you are. its a time consuming procedure to drop the transmission, so it makes sence to replace the clutch and pressure plate while you are in there.
Theoretically, the throwout bearing should have been replaced the last time it had a clutch change, so it failing could be a sign that it is on its way out. or prehaps the last person to service it didnt change the bearing.
E30 above Sold
Last updated 2nd January 2014
Old 02-07-2013, 06:01 AM
Well I think the TOB went out due to my wife not removing her foot off the clutch and I'm not all sure what the original owner had serviced. What all should I replace? I know the clutch, pressure plate, TOB, and the pilot bearing are top on that list.
Old 02-19-2013, 08:07 AM
upallnight upallnight is offline
Mein Auto: BMW, Lotus, Porsche
Could also means that the person like to ride the clutch while he is waiting at a light.
Old 02-19-2013, 08:09 AM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
Funny story. My dad picked up a jetta TDI 6-spd last week. we we're driving around and he's sitting at a red light, clutch on ground, car in gear. Car has 94 miles on it.. had to give him a talking to after that
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 02-07-2013, 06:02 AM
New exhaust gaskets
New pilot bearing
New slave cylinder
the truth be told yes everything on the list should be changed if you want to do the job right but if funds are tight then just replace what shows wear or are high wear items. new flwheel and clutch bolts put at the bottom of list as the pivot pin just check for wear. seals the same thing if they are not leaking you can chance it same as the slave cylinder. you will have to make a judgement call.
post pics of the parts and i am sure you will get feedback on them
Old 02-07-2013, 06:27 AM
Okay well hopefully I'll get off work early today and can start tearing it apart and will try to post pictures. What all should I snap pics of? Thanks again
Old 02-07-2013, 06:50 AM
take pictures of everything the whole ordeal i always like looking at pics
Old 02-07-2013, 07:06 AM
Old School
1) Take pictures of everything so you can see where it goes back. 2) Trade wife for a model with more car sympathy.
Current:
E38 Parts Car
Previous:
Old 02-07-2013, 09:55 AM
Monsignor's Avatar
Mein Auto: Sig
Originally Posted by BMWFatherFigure View Post
1) Take pictures of everything so you can see where it goes back. 2) Trade wife for a model with more car sympathy. 3) Take pictures of new model wife
fixed.
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 02-07-2013, 01:21 PM
Is this piece by the driveshaft
supposed to look like this? About to try to remove the exhaust, and just noticed this.
Old 02-07-2013, 01:26 PM
no the cracks are bad didnt see them till i enlarged picture time to replace dampner..... i have my popcorn ready this is going to get interesting
Old 02-07-2013, 01:29 PM
Out of curiosity how much does the e34s transmission weigh? Just curious since I don't have a transmission jack
Old 02-07-2013, 01:32 PM
you will need a friend then for sure. you do have a hyd floorjack right..
Old 02-07-2013, 01:45 PM
Nope...a guy at work said he could probably get me a tranny jack..so this entire exhaust has to be pulled right?
Old 02-07-2013, 01:50 PM
one lesson i have learned over the years of doing work like this is remove things that are in your way completely some will say that you can wire tie things up out of your way but they have a way of getting in the way. when you are trying to put the transmission back you will like having plenty of room.
Old 02-07-2013, 01:59 PM
also i guess you are doing this on your back with floor stands get the car as high as you can and level
Old 02-07-2013, 02:34 PM
Monsignor's Avatar
Mein Auto: Sig
transmission is really heavy. You need to be careful with it. I would never try to "catch" it. Had a buddy who crushed some fingers with a diff. Scares the ever loving sh!t out of me....
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 02-07-2013, 03:07 PM
That's right...Well guess that means I'm in for another set of jack stands. I dislike these exhaust bolts I got all of them broke loose except 2 of them holding the 2 pieces of exhaust together ...gonna get a grinder and get those 2.
Old 02-07-2013, 03:41 PM
You will most likely really hate the bellhousing bolts
Old 02-07-2013, 07:59 PM
Well I got the exhaust off and decided to call it a night..found a few things looks like something has rubbed on the drive shaft at some point, I'm guessing from the looks of it the drive shaft got pushed up or something . Tranny bushings look beyond shot, and my rear end seems to be leaking. Also found out why my CEL kept coming on about the O2 sensor, insulator on the wire is off in spots where the exhaust got rammed into the tree stump, it bent the exhaust and pulled the wire out of where it was secured. This just keeps on getting more and more costly What is the difference in the 2 different flywheel seal? One has a tension spring and the other has a piece of plastic in it or so it appears..which is better? Any idea whats causing the rear end to leak? Another project for me
ID:	361308   Click image for larger version
ID:	361309   Click image for larger version
ID:	361310   Click image for larger version
Old 02-09-2013, 03:48 PM
..........I'm having a blast with these. I got 5 out...these things take a lot of torque to remove
