Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 02-07-2013, 11:43 AM
Sammye30 Sammye30 is offline
Mein Auto: Bmw e30 320
Lightbulb 320 coupe, HELP i need new engine but which one
Hello there, two days ago i bought the car of my dreams a red 320 coupe with m20 1983
I loved the car n i wish i bought it a long time ago, anyways my engine is almost dead so i dont know what to do!!! I bought the car to have fun with it like drifting, as a third car in my house
The question is, i want a bigger engine but which one?? If i put 2.8 do i have to change the gear box and a lot of things like the radiator??? I dont have much money now to change everything but in the same time rebuilding fixing my engine will cost the same as buying a new one
So what engine should i buy guys!!!! 2.3???2.5?? 2.8?? 3.5???
Any ideas???
Old 02-07-2013, 02:35 PM
downhiller's Avatar
livin large
do the m50 swap. theres plenty of write ups plus there alot of aftermarket parts to help boost power
Old 02-07-2013, 08:05 PM
What should i change if i put M50
Do i have to change everything???
Old 02-07-2013, 09:26 PM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
ECU, harness and engine. Yup, all of it.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 02-07-2013, 09:33 PM
Titan_Omega Titan_Omega is offline
Mein Auto: 1986 E30 325 M20B27
My suggestion if your on a budget you can get a M20B25 for relatively cheap with the harness and ECU and transmission if you so chose. But if you want to save and get some real power in that get a 24v swap like a M5X/S5X.
The M20B25 is a relatively easy swap, and you get 140 hp not a massive amount but its better than a broken car.
The E30 is the single greatest BMW in my mind.
Old 02-07-2013, 11:25 PM
BMWFatherFigure's Avatar
Old School
Be prepared for the electrical nightmare, especially if some 'genius' PO has 'repaired' the existing loom.
Current:
Previous:
Old 02-28-2013, 06:51 AM
Thanks guys for the reply, i fixed my engine and but a 2.3 crankshaft with pistons, i had 125 n now 150 i guess, i didnt cost me a lot but it took me a long time to collect the parts because they are rare, anyways im happy with what i did for now but next change ( which is not far away) im gonna put m50 for sure, a lot of parts and cheaper
Old 02-28-2013, 09:14 AM
Newman271's Avatar
Newman271 Newman271 is offline
That Guy
Mein Auto: 85' 335i
M30B35 swap.. under 800 bucks for swap, doubles horsepower and increases torque. And a stock one with good tires can hit 13's. Im in the middle of the swap now and it's going very nicely.
1985 335i
Black on Black coupe 5spd
Tokico lowering springs, KYB struts and shocks, BavAuto strut bars, SPC adjustable camber plates, Ireland Engineering rear toe and camber kit, Sparco buckets, Rota Torque 16x7 fronts 17x9.5 rear, Hella headlamps with HID conversion, all red taillights, MSD coil,M30B35 swap
http://www.bimmerfest.com/forums/sho...36#post7573736
M20B27 for sale in Cincinnati
Old 03-01-2013, 02:02 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
The issues I have with a M30B35 swap is that you are replacing a prehistoric motor with another prehistoric unit and
performance parts were limited for these motors the last time I looked.
I turbocharged some of these and suffered getting parts. This was whilst living in so-called civilisation (Europe).
This motor is not much cheaper here than a more moden one with single Vanos. The latter having lower mileage.
Or am I blowing hot air
Don't take life too seriously; no one gets out alive !
Old 03-01-2013, 07:28 AM
Newman271's Avatar
That Guy
Mein Auto: 85' 335i
Yeah its a motor of the same era.. But a easier swap. Compared to other swaps, this is the best bang for the buck. I've located everything I need for my motor to turbo it, found it all with two websites. The M30B35 with a Turner chip can put down 260hp and 245ft. lbs of torque not bad for a stock all motor setup. And if you wanna go further Miller makes a awesome maf conversion kit that'll yield even better results.
With a good tune, skimmed head and thinner head gasket with a slight port job, not sure why you wouldn't see close to 290hp.
1985 335i
Old 03-01-2013, 12:27 PM
_Ethrty-Andy_'s Avatar
_Ethrty-Andy_ _Ethrty-Andy_ is online now
E34 Converted E30 Fanatic
there are people that love the M30 swap and others that hate it. yes, its a lot more power and a lot easier than an M50 swap, for both maintenence and doing the actual swap. but its also a lot heavier.
im more in the M50 camp, but i have seen some pretty quick M30 builds. i have a mate that has an M30E30 race car
Old 03-01-2013, 01:04 PM
Newman271's Avatar
That Guy
Mein Auto: 85' 335i
M30 is only 16 pounds heavier... hardly enough to make a difference.
M30
Straight 6 cylinder SOHC 12V. Big Six. 1973-1993. 143kg 315lbs
Used in E12 525/528, E28 525i, E23 725i, 2800CS, E28 528i, E23 728i, 3.0CS/i/L, 3.0Si, E12 530i, E23 730i, 3.3Li, 633, 732i, 733i, 535i, 635i, 735i, E12 M535
2.5i (150bhp), 2.8i (184bhp), 3.0 (185-208bhp), 3.3 (200-206bhp), 3.5 (218bhp) 225 ft. lbs.
M50/M50TU
Straight 6 DOHC 24V/Straight 6 DOHC 24V with Single VANOS. 1989-1998. 136kg 299lbs
Used in E36 320i/325i, E34/39 520i/525i, Variation of this was used in the Early US E36 M3
2.0 (150bhp), 2.5 (192bhp), 3.0 (240bhp) 181 ft. lbs.
a do it yourself fresh, clean, and reliable M50 swap can be done for $3000
same thing for a M30 lookin at about $1500
Thats why I said for the cost difference and the little bit of difference in performance, M30 was a no brainer for me atleast.
1985 335i
Old 03-02-2013, 10:42 AM
shredderak shredderak is offline
Mein Auto: e30 & e39
what about an m52 swap is that going to be much different that a m50?
Old 03-04-2013, 09:49 AM
Newman271's Avatar
That Guy
Mein Auto: 85' 335i
M52B28--- 2,793 cc (170 cu in) 142 kW (190 hp) @ 5300 280 N·m (210 lb·ft) @ 3950 6500 1995 84 mm (3.3 in) 84 mm (3.3 in) 10.2:1
More torque but less horses.. Thats why I liked the M30B35, It's a good blend of power. But It's your choice, just don't swap a nissan 4 cylinder in it please. LOL
1985 335i
Old 03-04-2013, 10:39 AM
But then your left with an older engine. I do like the numbers the m30 reads out on paper but what if I had a m52 with a s52 camshaft?
e30, engine, m20, m20 engine swap
