Is dual exhaust possible on 1998 323ic? - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 02-14-2013, 08:12 PM
agoliver2 agoliver2 is offline
Mein Auto: 1998 BMW 323i
Question Is dual exhaust possible on 1998 323ic?
HI i recently put a new exhaust on my bmw and i just wanted to know if anyone knew if there was a way that i could duplicate this on the other side. Ive seen some e36s on youtube do it but i looked underneath the car myself and found little room due to the gas tank. But people seem to somehow make it work I just wanted to know if anyones done this before i go buy myself another exhaust online! i have a dual ram air setup headers and exhaust so i was looking to make a dual exhaust. Any ideas or suggestions i would greatly appreciate thanks
Old 02-14-2013, 08:36 PM
ReillyM3's Avatar
ReillyM3 ReillyM3 is offline
Mein Auto: 1994 325i sedan
In my opinion the rewards are greatly outnumbered by the drawbacks and needed effort. However, its not my car and "different strokes". To do a dual exit you will need to (just by looking under my car) cut into your spare well, alter or switch rear bumper, have a shop mandrel bend and weld the piping, fabricate hangers and drill holes. I havent done it on an e36 but have on my old porsche... You would be better off doing cams as far as performance but once again its your canvas so paint as you must.
1994 325i (current)
2006 325i (current)
1995 525i
1990 325i
1988 Jetta 8v
1987 Gti 16v
1985 Jaguar Xj6
1984 Jaguar Xj6
1966 Mustang
1965 Falcon Wagon
1961 Buick Special
1962 Buick Special Wagon
1955 Pontiac Cheiftan
1961 Falcon Tudor
1962 Faclon Ranchero
Old 02-14-2013, 09:04 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
The 328 and M3 have totally dual exhaust until it meets way back at the muffler. Unfortunately, the 323 bottlenecks the exhaust ahead of the catalytic converter and then runs a single pipe all the way back to the muffler. There are actually significant power gains to be had with a 323 if you upgrade to the 328 or M3 midpipe with a 328 or M3 cat-back. That's the route I would recommend for this application. As far as having separate dual mufflers, etc., I wouldn't do that. There really isn't room to do it easily due to the spare tire well and it looks silly almost all of the time when people try to do it. Almost universally looks ghetto rigged.
1998 BMW 328is
1966 Pontiac GTO
Old 02-15-2013, 07:48 AM
Hectorml07's Avatar
Hectorml07 Hectorml07 is offline
WYKDBMR
Mein Auto: BMW E39 6 Speed
Dual exhaust belongs in cars that come equipped with it already such as the M5, OR E90 M3. Just by looking at them you can tell deserve dual exhaust! I have seen some e36s with dual exhaust though, just not my cup of tea. It makes me giggle lol. It reminds me of guys that I have seen in their tricked civics with large dual exhaust systems in a little 1.8 four banger sounding terrible to me, but I guess it sounds powerful to them.
All in all its up to you and what you do to your car since you are the owner.
Old 02-15-2013, 07:58 AM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
Karl nailed it about the 323 exhaust. If you decide to go the route he stated, I have a 328 catback in great shape for $50 if you want it. And also a straight pipe midsection.
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2007 328i DD
Old 02-15-2013, 10:15 AM
granlund granlund is offline
Mein Auto: -02 530 & -92 325is
Since the 323 only has one O2 sensor, wouldn't an OBD1 325/M3 midpipe be a better choice?
http://www.realoem.com/bmw/showparts...09&hg=32&fg=30
http://www.realoem.com/bmw/showparts...77&hg=18&fg=10
Old 02-15-2013, 10:20 AM
B1MM3R's Avatar
Jesse Moon Bayne
the straight mid pipe I have is obd1 that comes with the 328i catback.
Jesse
2007 328i DD
Old 02-15-2013, 11:01 AM
HakenTT's Avatar
HakenTT HakenTT is offline
Mein Auto: '91 E30
323ic single exhaust is not restrictive for 2.5L engine. It goes down to 2 1/4 inch in front of the converter, after the converter it goes to 2.5 inch wide pipe. 190 horsepower has no problem with 2 inch exhaust pipe.
328i and M3 mid section is worse. Right after converters the two small resonators, the pipe is only 1.5 inch wide inside on each side
Old 02-15-2013, 12:01 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
I'll be damned. He's right (if his pipe size figures are right).
323 exhaust before cat= 3.976 sq. in. cross section
323 exhaust after cat= 4.908 sq. in. cross section
M3/328 exhaust after cat each= 1.767 x 2= 3.534 sq.in. cross section total of two pipes.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 02-15-2013, 12:19 PM
ZeGerman's Avatar
Warm Leatherette
There has to be more to it than that. There is no way BMW would use a more restrictive exhaust on the 328 and M3 than on the 323. Virtually everyone (except Hawken) has said that the 328 and M3 exhausts flow much better than the 323 exhaust. Perhaps overall diameter isn't the whole story, and that by having a larger overall diameter in the 323 exhaust, scavenging and velocity is hampered, thereby reducing power. Everyone says that a 328 or M3 exhaust on a 323 is the single best performance modification in terms of gaining power.
If the 323 exhaust was superior, we'd all be putting 323 exhausts on our cars... Besides, if the 323 exhaust is 2.5 from the cat back, and the 328 has two 1.5" pipes, that's a half-inch more total from the cat back compared to the 323. Am I having problems with my maths? The 323 most definitely does not have a nearly 5" single pipe from the cat to the muffler.
1998 BMW 328is
1966 Pontiac GTO
Old 02-15-2013, 03:49 PM
D'oh, You Kids!
You figure it up. 2.25"/2 (radius)= 1.125" X 1.125" (squared)= 1.265265 X 3.1416 (pi)= 3.976 sq. in area cross section
2.5"/2 (radius)= 1.25" X 1.25" (squared)=1.5625 X 3.1416 (pi)= 4.90875 sq. in. cross section. (NOT diameter).
1.5/2 (radius)= 0.75" X 0.75" (squared)= 0.5625" X 3.1416 (pi) = 1.76715 sq. in. cross section X 2 (two pipes)= 3.5343 sq. in. cross section total.
I really wonder if that 1.5" twin pipe figure is correct.....
Quotes to live by:
BMW-CCA #441426
Old 02-15-2013, 04:12 PM
southpark11235's Avatar
southpark11235 southpark11235 is online now
bimmerfest Supporting Member
Mein Auto: 1999 BMW 323is
While HakenTT seems to be right about the size of the 323 pipe, the 328 pipe is half an inch bigger than he suggest.
ID:	362446   Click image for larger version
ID:	362447   Click image for larger version
ID:	362448   Click image for larger version
ID:	362449   Click image for larger version
Alex//1999 323is - power e46 M3 seats, style 43 rims, 328 exhaust, Z3 rack, Bilstein PSS coilovers
//1992 Mazda Miata - cat delete, power windows, oil filter relocation
“We got about ten minutes before this entire county is up in flames. If you want to live, you’d better step on the gas! Oh wait is this a Tesla? Sh!t! Well, step on the prissy pedal, we're going to die!” – Cartman
Old 02-15-2013, 04:17 PM
D'oh, You Kids!
The real question is what size are the twin pipes coming out of the cats? Or is that one of them? That makes a HUGE difference. That would make the outlet cross section 6.283 sq. in. total , not 3.543
Quotes to live by:
BMW-CCA #441426
Old 02-15-2013, 04:25 PM
The second picture is the 328 pipe after the cat with no bulge.
Old 02-15-2013, 04:45 PM
hey guys. I would like to thank you guys for the responses as the threads got many. I guess a dual exhaust setup is really not worth it for the mods that need to be made. I was looking and just don't seem to see the clearance for the full exhaust. My 323i is restricted like crazy. they restricted my whole exhaust system my headers my air box my computer my intake manifold & im sure other crap as well. I've changed my headers and they actually close off the outlet with a little indentation in the headers themselves to restrict air flow. I've changed my headers exhaust and made a dual ram air setup & it does 0-60 in around 5.6 which is the best time I've got so . (and it is an automatic)As for the 328-m3 exhaust swap im not really sure if I can put dual pipes all the way from the headers back to my exhaust. I just have a single cat & no resonator. I don't think it will fit but I guess you don't know until you try. I don't understand why they also detuned my car from the factory. The 325 has the same motor & I believe less restrictive. I believe the 328-m3 exhaust will be much better even though form this thread you guys say its smaller. I just don't know how 2 cats are going to fit under my car. But I could be wrong I don't know if anyone's ever done this before? or even m50 intake manifold swap for more power? and my car is a OBD2 not OBD1 to whoever stated above. thanks
Old 02-16-2013, 06:21 PM
HakenTT's Avatar
Mein Auto: '91 E30
Originally Posted by ZeGerman View Post
There has to be more to it than that. There is no way BMW would use a more restrictive exhaust on the 328 and M3 than on the 323. Virtually everyone (except Hawken) has said that the 328 and M3 exhausts flow much better .
328i/M3 mid section is horrible for flow, converters are only 3 inch wide and there is almost 90 degree angle before them, pipe is only about 1.6 inch wide under the two small resonators after rear 02 sensors. This exhaust was built in mind for quietness and emissions and S52 only makes 240hp, it is not a jet engine. 1995 maxima SE with 3.0L engine makes 230hp and it only has 2 inch exhaust pipe all the way back.
323i exhaust is a single pipe and has bigger single catalytic converter, and the exhaust probably flows as good as 328i duals and weights less.
Old 02-16-2013, 07:51 PM
^Where is your proof? Anyone can post on the internet that the 328 cats are only 3 inches wide, but it does not make it true. If you want people to believe what you are saying, then you must show us evidence that backs up your 328 exhaust size clams. Then you must also provide us with reliable 323 exhaust numbers.
Old 02-15-2013, 04:31 PM
ZeGerman's Avatar
Warm Leatherette
Yeah, it doesn't make sense. Everybody reports power gains with the 328/M3 mid-pipes and cat backs over the 323 units. Haken is literally the only person I've ever heard say that the 323 exhaust is better. His claim doesn't add up, nor should it. BMW would never put a more restrictive exhaust on their higher performing models.
Also, how is cross section different than area? I'm assuming that the terms are not synonyms, but when I calculated the are using Pi*radius squared, it produced the same numbers as your cross section figures. Sorry for being dense...
EDIT: That makes much more sense! Haken said the 328 pipes were 1.5" each, but those photos are showing that they're much bigger than that. I think he was suggesting that they're double-walled, and that the inner pipe is only 1.5" in diameter, but that's not what we're seeing in the photos.
1998 BMW 328is
1966 Pontiac GTO
Old 02-15-2013, 05:02 PM
ZeGerman's Avatar
Warm Leatherette
Uh oh....
1998 BMW 328is
1966 Pontiac GTO
Old 02-15-2013, 06:42 PM
Joe__Sterling's Avatar
Joe__Sterling Joe__Sterling is offline
Fast Cars Suck!
Send a message via AIM to Joe__Sterling
Mein Auto: '13 FIAT 500 '68 BMW 1602
did you happen to put a different set of wheels/tires on your car from stock?
*The I Drove to Both East and West Coast Bimmerfest Club* Member #1
@Joe__Sterling on twitter & instagram (two underscores)
Old 02-15-2013, 07:02 PM
no they are stock rims with bridgestone potenza tires. ?
Old 02-15-2013, 07:09 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Joe asked so that you'd have the benefit of doubt. With larger circumference tires your speedometer would show a faster speed than you're actually travelling because it would show the speed based on the rotation of smaller circumference stock wheels, which is what your speedometer is calibrated for.
Make sense?
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 02-15-2013, 07:12 PM
yes that would make sense but they are stock i dont understand the doubtfulness of my car i will find a way to put on the video if i can figure out how. stock rims just headers dual ram air custom setup and exhaust. pretty quick i believe for a 2.5. thats why i wanted a dual exhaust but it seems not to be possible with the clearance
Old 02-15-2013, 07:51 PM
I know a thing or two about computers and I know why you cannot upload your video. Ready? This might come as a shock, but a video has to exist before you can upload it to YouTube. I know this seems like an unreasonable limitation in the 20th century, but it just cannot be done. Right now only place that take imaginary videos is imaginary YouTube in imagination land. Where you imaginary car does not to 60 5.6 seconds and your posts have capital letters and periods in the right place.
Old 02-15-2013, 08:09 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
well, i don't use caps, seldom proper grammer, fly kites in rainstorms, and *still* can't get cadence to go that fast.
i even used pixie dust.
tinkerbell got mad at me....
for reelz, yo.
df
