Discussion pertaining to the flagship BMW here. |
Audi 22's on a BMW 750i
Buddy said I could have his Forgiato Concavo's cheap if they would fit on my car. Looking advice.
His wheels 22x10.5, 22x9.5 with 25mm offset front and rear....wrapped in 295/265's With Audi to BMWadaprers would these fit???? And not run or look retarded
2008 Jet Black 750i. Sport, Luxury Seating, and Logic 7. <3 ![]() ![]() ![]()
they will look good if the offset is right etc
![]() AFE stage 2 CAI Hifonics 1200.1d 2x Rockford P3 12" Aux Mod ACS spoiler 22's TrueForged Wheels |
Dont do it. Your going to have a high chance of vibrations.
SOLD 2003 745Li Authentic AC Schnitzer Aero Kit inc Front, Side Skirts, Rear, Mirrors, Roof and Trunk Spoilers Gloss Black Grille and Window Trim KW Variant 3 Coilovers 22" Interad Turismo Forged 3-piece wheels |
San...why do you think vibrations?
I mean if the adapter is installed correctly and flush against the hub then theoretically it should be a flush extensions of the hub....no?
And those wheels look good!!!!i think if it would work why not right....just want to know if it can be done and consequences
those will look nice. Just make sure you get hub centric adaptors or rings
Current Lineup: BMW E31: Air suspension,19x10 / 19x11 Trafficstar BMWE38:Air suspension,20x10 / 20x12 Forgiato BMWE65: 20x10 / 20x11 Asanti ELT Lexus SC400: Single turbo, 19" SRR wheels Lexus GS300: VIP , Air Suspension,19" WORK wheels S13 Silvia: WideBody, JDM conversion,SR20det,15" WORK wheels Lexus LS400:Air suspension,MAJOR A/V setup, 19"Leon Hardiritt Lexus LS430: VIP , custom Air Suspension, 19" Amistad (SOLD 2012) ![]()
you ok long as its hubcentric to the wheel i ran adapters before
Is there a set standard for the adapter on siZe????
A wheel guy I'm good friends with took a lot of calculations and said I would need a 28mm in the front and a 41mm in the rear....does this sound about right????
just remember that 28mm spacer is an inch or so. ****most off the shelf pcd conversion adapters are an inch if you dont get them custom made.
Hey drift girl
The wheels are 25mm offset front and rear Any ideas??
My guess is most of the people on this forum don't have much experience with wheel adapters.
I have been running them on multiple cars for years now, and have not had any issues. Everyone on the Audi forums told me I was ruining my brand new 60k car, but I had no issues and was able to run a much more interesting wheel. Adaptec is my favorite company for adapters, custom built to your specs. I think they can go as small as 22-23mm for adapters. I think you may run into rubbing issues with the wheels above, but the only way to know is to measure. Google calculating offset and go from there, but at et+2 front and rear that is more agressive than most people here run. I run a more aggressive offset, something like et 0 front et-4 rear, but my wheels are 20x10 rear 20x9 front. I have no rubbing issues and have factory camber, with my fenders rolled. With camber you may be able to fit them, but if you are new to wheel fitment this may be a bit over your head. |
you should be ok ( +5mm and - 2mm) not much different there. Just make sure the hub centrict are correct. ( same side)
![]() 2001 X5 3.0i 200k miles & counting...( SOLD) Dinan Stage 1 Trans and Engine /SMG M3 Steering wheel/M5 SMG shifter/BMW rear entertainment/4.6IS body kit/4.8is Exhaust/ X-pipe/Turner HP Pulleys/E92 sport seats/Group M Intake/Brembo drilled rotors/Quart projector beams headlights 06 750Li with 19k miles. Bone stock. |
Hey GPDenver
I posted the calculations my wheel guy sent me. He says they should work. Can you double check and let me know what you think????
Anyone else want to double check the numbers and tell me their opinion on fitment????
Sounds good man! Yeah the only thing I wasn't sure of was the space the adapter added l. My wheel guy said with the 28mm from and 41mm rear it'll be just about perfect.
Based on the picture you posted above it looks like your new specs will be 22x9.5 et +8.5 front and 22x10.5 et +8. I don't run 22", but sounds more aggressive than the typical 22" for our cars. Will look great if you don't end up rubbing.
Ask all the 22" guys on the forum to post op their specs, find a set you like and copy the offset. Last edited by GPDenver; 02-24-2013 at 12:38 PM. |
