X5 E70 (2007 - current)
Talk about the latest generation X5, codenamed E70, with other BMW owners here. |
What fuel to use for X5
I have been diligently using only 93 Octane fuel for my 3 series. Now upgrading to an X5.
Will a 91 suffice? Thoughts?
Regards AMT 2013 X5 White| Base Model| |
"Suffice" is very subjective. The X5 will run fine on 87 or above but at 87 will be down a little on power, and, some say, MPG. In normal driving it is hard for me to feel or see any difference. These are not race cars, after all. The difference between 93 and 91 is immaterial. The most important thing is to buy "top tier" fuel with decent additives.
What is "top tier" ?
I know my Audi actually lists the brands that Audi suggest for us in my S4 as top tier, I wonder if BMW does the same?
2013 Audi S4 - Glacier White - 6MT 2010 BMW X5 - Black Sapphire |
I will check. The 3 series I had did come recommended with a higher octane though. This was from back in 2005.
"Top tier" is a voluntary industry labeling standard regarding fuel quality, especially additives. It was implemented by several major brands such as Shell at the request of BMW, Mercedes, Porsche and perhaps others to insure that their vehicles had available to them a high quality fuel. Anyone posting the top tier logo has to meet certain specs. Some of the major gas companies refused to do this but still provide high-quality fuel. Google it for more information. The point is that over time a higher-quality fuel is better for your vehicle than a lower-quality one, although you pay more. This has nothing to do with octane rating. I would spend my money there before worrying too much about octane rating, but if the prospect of a little power loss is troublesome to you or, for you, inconsistent with a quality vehicle, then buy the higher octane. I notice no difference on the road in MPG or performance during normal driving. In my race car, where performance really matters, I would never buy less than 110.
Thanks All. Useful info.
The X5 users manual recommends an AKI 91 and a minimum of 89 with an Ethanol rating E10. I will Google to see what these actually corresponds to in terms of Brand.
The phrase "top tier" has absolutely nothing to do with octane. Even the most off-price stations have the octane ratings posted on the pump.
"Top tier" is shorthand for "high quality name brand" like Exxon Mobil, Shell, etc. Unlike the bargain brands ("Joe's Great Gas"), top tier fuels tend to have a better additive package (detergents and anti-foaming agents). These additives cost money, and are largely responsible for the price difference between top tier and cut rate brands. The brand is only part of the equation. You also want to buy fuel from quality, high volume stations. Joe's Great Gas may not sell much premium or mid-grade fuel, so their fuel may sit in their underground tanks longer, picking up moisture. Moisture in the fuel can wreak havoc with modern engines, and the higher the ethanol content, the easier it is for the fuel to pick up moisture. From the Owner's Manual: Super Premium Gasoline/AKI 91 This gasoline is highly recommended. However, you may also use gasoline with less AKI. The minimum AKI Rating is: > BMW X5: 87 > BMW X6: 89 If you use gasoline with this minimum AKI Rating, the engine may produce knocking sounds when starting at high outside temperatures. This has no affect on the engine life. Do not use gasoline below the specified minimum quality, otherwise engine damage can result. Use high-quality brands Field experience has indicated significant differences in fuel quality: volatility, composition, additives, etc., among gasolines offered for sale in the United States and Canada. Fuels containing up to and including 10% ethanol or other oxygenates with up to 2.8% oxygen by weight, that is, 15% MTBE or 3% methanol plus an equivalent amount of cosolvent, will not void the applicable warranties with respect to defects in materials or workmanship. The use of poor-quality fuels may result in drivability, starting and stalling problems especially under certain environmental conditions such as high ambient temperature and high altitude. Should you encounter drivability problems which you suspect could be related to the fuel you are using, we recommend that you respond by switching to a recognized high-quality brand such as gasoline that is advertised as Top Tier Detergent Gasoline. Failure to comply with these recommendations may also result in unscheduled maintenance.
Current BMW's: 2011 535xi M Sport TiAg / Black, ZPP, ZP2, ZCV, ZCW, ZDA, 2TB, 6NR, 465, 5DL, and a Partridge in a Pear Tree 2011 X5 35D Deep Sea Blue / Oyster, PP, SP, PSP, CWP, Tech, 20" 214's Prior BMW's 2008 ///M3 Vert 2008 X5 3.0 2007 X5 3.0 2006 X5 3.0 2006 550iA SP 2003 540iA M-Sport |
BMW-speak for "we won't pay for it, you will," as BMW pays only for scheduled maintenance and manufacturing defects.
If you are buying a premium car, at a premium price, and you want the premium warranty that is included, I think you need premium fuel.... 91 and above is perfectly fine.
And always try to have proof of this, since BMW likes to nit pick to get out of paying (they always have an excuse) for warranty issues. So either get a receipt or use your CC or DB. Good luck!
BMW and Mercedes Build Beta Products! Lexus build Release Candidate Products! Why does this matter? CAUSE EVERY TIME someone says Lexus has better build quality, one should consider what Toyota their Lexus Engine and chassis platform comes out of and how long that part has been tested in the real world! |
Noted folks. Thanks for sharing some good info here. I think I will stick with AKI91 and avoid nondescript gas stations.
BP 93 for me..
2013 X5 35i Premium, Space Gray, Cinnamon Brown Leather, Dark Bamboo wood trim, Conv. Pkg, CWP, Multi-contour seats, Running board, BMW App. Space saver tire. 2010 535i - Deep Sea Blue w/ NBD Leather, Bamboo Anthracite WT, Sport Auto Trans w/ Paddle shifter, Sports Pkg, PP, CWP, Nav, HD Radio, Ipod. - Returned 2007 525i - Black Sapphire Metallic, Black Nevada Leather, Premium package, CWP, 6MT. - Returned |
No warranty could be voided just for using 87. Ever.
i always run 93 but its usually because it was a car that made more power with 93 (turbo, sc, tune, strung-out e46 m3 LOL, etc.). while i can't comment on the x5 specificially, i know that when we had our Q7 3.6Q, it got significantly worse mileage with 87. and not just around town, but on 4 different trips from houston to dallas (250 miles), travelling the same route.
2012 X5 35d | Alpine White w/Cinnamon | Premium | Sport | Premium Sound | 20's Type 214's | Running Boards | Clear Bra | 30% Metalized Tint 2012 S4 Prestige 6MT | Ibis White w/Silver Spectra & Black Nappa | Sport Diff | Rear Shades | Clear Bra | 30% Metalized Tint | Interior LED's | OEM License LED's | APR Stage II+ | 19" Forgestars | H&R OE Springs | AWE Exhaust | Roc-Euro Intake |
I see you either are naive, or unfamiliar with how BMW and other automakers like to pick up part warranty claims. Trust me, legally you may have a case, but in reality the headache of having to prove that to a stubborn SA or BMW rep is time spent that you do not need.
If someone else is pickin up the tab, I`m gonna maintain that vehicle the way the want it to be. I would forget about what I think caz it aint my name on that repair bill. Once the warranty is over I go to town on a vehicle. Before the warranty is up, i maintain said conditions.
The little sticker on the gas door flap says 89
But i am using premium from Exxon (93 in Texas)
2013 X5 xDrive35i 2011 M3 Sedan 2002 Z3M Coupe |
Yes call me paranoid, but my paranoia exists to help me make warranty claims as easy and painless as possible for me.
Even using the best gas around, like Chevron or Shell is not good enough IMO.
Look into Techron, Redline SL-1 or Regane. Or BMW's fuel additive as recommended by the manual. |
Costco started advertising 5x EPA detergent levels at select locations
http://www.costco.com/clean-power-locations.html |
Going back to the OP's question, damage caused by "bad" gas will NOT be covered by the warranty. Hence the recommendation - here and in the manual - to use top tier brands. I always get a receipt so I can build a paper trail of precisely where and when I purchased fuel, "just in case." Sent from my HTC Inspire using BimmerApp
For gas engines, I can find no mention of any recommended additive in my 2011 manual. Could you point us to that? Sent from my HTC Inspire using BimmerApp
#25
Yes diesels are different. |
