E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki |
Head light restoral
I have tried 3M and Diamondite head light restoral treatment on my vehicle with the results ending up with them very clean on the out side and I know that is what those products are designed to do but my headlights seem to have a film of grime on the inside of them . I was wonderng is there an way to clean the inside ?
Ride |
That picture looks like a Camaro that was modified to look like a BMW... by the way.
Check your mirrors as often as it takes for you to know where everyone is around you! |
That picture was of a Camero but I placed a picture of the front of my vehicle to show the headlights after the treatments.
Ride |
You say you have something on the inside though. I would remove each head light, remove all the electronics from the lamps and try washing out, then let dry real good and re-assemble. You must have a bad seal or a missing bulb cap at the rear for stuff to get inside??? |
This pic just looks like you didnt sand the lends down enough to get all of it out. I had mine done by a shop and they used power tools to do the job and my headlights came out brand new. I tried the Turtle wax restore kit on my fog lights and it only took off a little, it looks better but the power tool way works best.
2008 BMW 550i Carbon Schwartz Metallic, 6 Speed Manual, Sport Package, Cold Weather Package, Logic 7, Comfort Access, Active Steering, Sat and HD Radio, Navigation, Comfort Seats and custom coding. |
When i was in Jr high school ( back in 1973 }we used to make projects out of plexy glass,, we used 1500 wet sand paper and then 2000 wet sand paper on the cut edges and it comes out lookin like glass after polishing ..
What Hogie said will work,,, and look like new...
I had great results by using the $10 kit from Harbor Freight, simple sandpaper pad that attaches to a drill, some elbow grease and then the polishing compound and my headlights looked new for over a year (until a carsh meant new headlights were in order anyway)
2008 550 - Carbon Black/Black - M-sport, Cold Weather, Premium, NAV, Comfort Access, Logic 7 (LOADED, every option except night vision) - mods done: RPI GT exhaust, RPI scoop, K&N filter, 20" wheels. planned: ESS tune, CKS coilovers, CF Hamann style lip, RD Sport trunk spoiler, ESS SC kit, Magnaflow headers Previous 3 cars (the 550 is my 38th car): 2005 530i - Prem, Sport, NAV 2006 Jeep SRT-8 2003 Infiniti G35 coupe |
Boramkiv is right, the only way to clean the inside is to open the headlights, but they are VERY difficult to close up again afterward. You will most likely end up with moisture inside the headlights and short circuits later on as the moisture corrodes things.
I had mine done at the BMW dealership. Very pricey ($200) but I wanted to be able to hold them accountable if it didn't work. Complete night and day difference. They look almost new now.
Mike Swing |
You can always buf the outside, that usually improve the condition of the headlamps. I don;t have guts to open it, I heard older headlamps like prior to 2004 can be baked and opened. but my concern is how are you going to regulate the temp(even if you know the exact temp to soften the seal/glue) in home oven, it can be off as much as 10% then cycle up-down, too risky. How about just remove the headlamp, use micro-fiber sprayed with glass cleaner around a tongue and buff it slowly, insert the tongue through the H7/DS1 xenon bulb opening. |
have you guys tried cleaning the headlight cover with plain toothpaste? i have just viewed 2 vieos on you tube showing how to do it and it looked real easy and with good result. i will try it oon my '004 530i today.
Don't think it matters, but I used AIM. lol After the toothpaste I used Plastix X cleaner/polish. They still look good after a year. |
. "Voters will always choose the beautiful lie over the uncomfortable truth" |
This worked for me and it's soooooo cheap: http://www.harborfreight.com/12-minu...kit-65938.html
Just a FYI..
The first time that I cleaned was about 3 years ago and I just taped round the lamps and buffed in place. This past weekend I actually took the head lamps out when I cleaned. For my 04 e60 it was very easy to take out. Just two torque screws on top and then just loosen two torque screws at bottom of lamp's backside. I also had to change a burned out angel lamp. |
Novus Plastic Polish. Works extremely well, follow the direction's carefully with this product for outstanding results. I used this stuff on my 08 528 on headlights and interior wood trim.
www.novuspolish.com/
"I have the simplest tastes. I am always satisfied with the best." Oscar Wilde |
What about tooth decay? Anything on tooth decay? That can be very serious!
