7 Series - E38 (1995 - 2001)
Used ECM and new EWS?
I put a new motor in my 740il, and a good used junkyard ecm, car cranks finally with used ecm, but i have no spark, i was wondering if i can just put a brand new EWS module in the car, and align it with the ECM, and not have to replace the key or anything else. I am 100% sure that the EWS module is not coded to the ECM as it is a used junkyard ECM. i do have codes in the ecm for ews antitheft.
All i need to know is if i can put a new ews4 module in the car, and code and align it to the good used ecm i currently have in the car, any help would be awesome! thanks so much! nate |
Dealer reprogram for your car, sorry bro!!
I can programit myself, i have the autologic scan tool, i just wanted to know if a new ews will fix it
No...because EWS uses multiple components...and all have the same ISN (individual serial number) burnt into them. The DME/ECU, EWS control module, transmitter/receiver (on early EWS II models), and the key. They all have to have the same ISN...if not, the starter, ignition, and fuel will be affected.
Q {BMW CCA Member #191509} 2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 97 740iL (Arctic Silver) 3/97 mfg date (SOLD) 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White) 91 735iL (Schwarz Black) <<~>> 85 325e (Bronzit) |
