Audio help from PC person needed - Bimmerfest - BMW Forums
Old 03-07-2013, 09:25 PM
jborchel jborchel is offline
Mein Auto: Porsche Boxster
I would like to copy many of my old audio CD's that I bought to a flash drive that I can run through the USB port in the center consul. I don't have the radio manual with me so I don't remember the formats that are supported. I would like to copy the songs into the best price performer of the formats. In other words, I think lossless would take up to much space but MP3 would suffer too much in audio quality. I have about 20 to 30 favorite albums I want to copy. I have two questions:
1. What format should I copy to that is supported and is the best price performer?
2. What is the best PC program to use to do this copying?
Old 03-08-2013, 02:06 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Mein Auto: 2015 M235xi / 2005 Tacoma
I use 192k or 256k MP3. There's some compression, but you're in a car and I don't find it noticeable. The radio will also support the .wav format.
On the program side, I believe that Window Media Player will do it in Windows 7. That's not what I use, but what I use is no longer available.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/ BimmerTech amp, Enh. BT
Ordered 3/12/15, Off the line 4/7/15, Delivered 5/14/15
Prior 40 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92
Old 03-08-2013, 02:45 AM
lqaddict's Avatar
lqaddict lqaddict is online now
Salz und Pfeffer
Mein Auto: 2014 F22 M235i
I think you can only use mp3 and wav
BMW CCA Member 454031
Save the manuals
Old 03-08-2013, 08:09 AM
What is the quality diff between mp3 and wav? I believe I read somwhere that you can rip to 320kb in mp3. What bit rate is .wav?
Old 03-08-2013, 08:20 AM
ND40oz ND40oz is offline
Mein Auto: 09 135i
WAV is usually uncompressed LPCM and the file sizes are going to be huge. In that format, you're looking at 10 MB a minute for file size, which is why a 740 MB cd typically could hold 74 minutes of music.
17 Volvo XC90 T6 Inscription P* (OSD 7/16)
15 BMW 328d xDrive Sports Wagon M Sport
15 Audi SQ5 Prestige
13 Honda Insight EX
Last edited by ND40oz; 03-08-2013 at 08:43 AM. Reason: typing too fast for my own good
Old 03-08-2013, 08:40 AM
ctuna ctuna is offline
Mein Auto: 325xi wagon
If you are going to a USB stick space in not such and issue
Since you can get a 16gb usb stick pretty cheaply these days(or even more).
If you are going to a CD Disk with your Mp3 's at 320 you can get about 50 tunes
per disk, about a 4 to one compression and I can't tell the difference
between that and a Cd. If you have Itunes you can export as a play list to a usb
stick I believe you can make cd's in any format itunes supports.
I bought a little utility off the net the allows you to copy your itunes playlists to a usb
stick in the format they are in .
I believe the BMW radio cd support both mp3 and wav not sure about the rest but can't see how
it wouldn't do apple stuff.
Old 03-08-2013, 04:07 PM
SD ///M4's Avatar
SD ///M4 SD ///M4 is offline
(prev. SD335is & SDZ4MR)
Mein Auto: 2016 M4 Coupe | 2006 Z4MR
What car does this apply to? Your "Mein auto" indicates a Porsche Boxster, why would any of these answers apply to your Boxster? Are you asking in this forum because you also own a E9x BMW? If so, specify what year and model, as audio options vary almost from year-to-year in an E9x.
- Tom
His: 2016 M4 Coupe | Sakhir Orange Metallic | Black Full Merino Leather | CF Trim | M DCT | Adaptive M Suspension | 19" Black Alloy Wheels | ZEC | ZLP | ZDB | MPE | ED 5/13/16
Hers: 2011 335is Couipe | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | ED 5/12/11
Also His: 2006 Z4 Roadster (E85) | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
