The X5 SAV Forum
Old 04-26-2013, 08:01 AM
Duttywineangel Duttywineangel is offline
Mein Auto: 2001 x5 3.0
Unhappy Entire cooling system overhaul, 2001 X5 still overheating, cools when heater is on
Hello everyone,
I have a 2001 X5 3.0i. A few weeks ago, my accessories belt shredded. I took it to the repair shop, and the mechanic said that I needed to replace my water pump, thermostat/housing, pulley and belt. I had this replaced. When this was finished, I took it for a test drive and split the side on the radiator reservoir (due to not bleeding the system of air). I had this replaced and found out that in the process, someone had broken the thermostat for the tranny cooler. I replaced this, along with the fan clutch, and o-rings/clips for the tranny cooler. After this, I bled the lines, and took it for a test run. This is my question. I drove it for awhile and it kept cool. Then, I took it on the interstate, going about 70, and it started to get hot (at the 3/4 line on the temp gauge). I turned on the heat, and it immediately went back to the 1/2 mark on the temp gauge. I am wondering if anyone has any information or clues as to what may be causing this?? I would like to add that after having all of these parts replaced, my car sounds rough, and is making a new noise. (Sounds like a whine of some sort)....any suggestions?
Old 04-26-2013, 09:06 AM
HPIA4v2 HPIA4v2 is online now
Mein Auto: E60, E71, E92
You either have bad thermostat (not fully open when you are at freeway speed) or some more air in the systems that need to be purged.
The noise could be new belt being tight (not broken in) or old tensioner, usually people replace tensioner when replacing belt.
Old 04-26-2013, 09:34 AM
ECSTuning's Avatar
ECSTuning ECSTuning is online now
Instructor of the Stig™
Sounds like when you opened the heater valve by turning on the cabin heat you moved an air pocket, re bleed the system.
Customer Service Hours: M - F 8:00am - 8:00pm EST | Saturday: 10:00am - 7:00pm EST
Sales Team Hours: M - F 8:00am - 11:00pm EST | Saturday: 10:00am - 7:00pm EST
800.924.5172 | OEM BMW Part Number Search
Click HERE to read what people are saying about ECS Tuning
Old 04-26-2013, 12:10 PM
Do either of you know where to find the second bleeder screw? As I have been doing some research, I noticed that I should have been bleeding from two different screws. I was only bleeding from the one next to the reservoir. Also, should the car be running while I am bleeding it, or should the ignition just be on (not started)??
Old 04-28-2013, 08:44 PM
upallnight upallnight is offline
Mein Auto: BMW, Lotus, Porsche
Car needs to be running and the engine need to get to operating temp in order to bleed the engine of all air in the cooling system.
Old 04-30-2013, 04:34 AM
Thank you all for the helpful info!! Here's an update: It worked!! It's not overheating anymore!!!
01 x5, confused, heater on, overheating
