Old 06-18-2013, 08:03 AM
jayasanala jayasanala is offline
Mein Auto: 2012 X3 XDrive 328i
A/C air is not cool when temperatures are high
I have 2012 X3 Xdrive purchased 3 months ago from a non BMW dealer. Lately I noticed that when the temperatures or so high(mid 80s - mid 90s) I feel like I’m not getting enough cool air from my car A/C, is it something common or something wrong with my A/C. and if I need fill the gas for my A/C is it covered under BMW Warranty
Old 06-18-2013, 08:14 AM
rdvt4me rdvt4me is offline
Mein Auto: BMW X3
Did you make sure the middle dial in between the vents was turned to the blue section and not the red? It makes a huge diffence in the temp of the air coming out the vents.
I had this problem on my 2013 X3 and that made a big difference.
Old 06-18-2013, 08:24 AM
yes i did made sure that middle dial was turned to blue, as i said if its in the morning or late in the evening its looks like its fine , but in the middle of the hot day when temperatures are peak high that's when i see this problem.
Old 06-18-2013, 08:34 AM
The X Men The X Men is offline
Mein Auto: 2013 X3 35i
Have you try putting the air flow control into recir? Max button on? and Auto start stop off.
Old 06-18-2013, 09:55 AM
what do you mean by putting air flow control into recir, sorry i didn't understand that part.
Old 06-18-2013, 10:33 AM
There is a button to control if you want outside air or recirulated air, or you can set it in auto. When you put it in max, the recir mode will turn on automatically.
Old 06-18-2013, 12:29 PM
Liverman's Avatar
Liverman Liverman is offline
Mein Auto: '14 X3 35i / '03 F350
See page 122 in the manual. Button #8.
Also:
  • Make sure the vent in the dash and the vent in the rear seating area are both turned to "blue".
  • The "Intensity of the Auto Program" (page 123) should be turned to max. This controls the maximum fan speed the Auto program will use. If it is left down low, you do not get enough air circulation. This is different than in the previous gen E83 X3.
In really hot weather, I just hit the MAX AC button which turns intensity to maximum, temp to minimum and recirculates the air inside the car instead of brining in hot outside air.
On hot days when I first get in the car, I crack the roof (press in on the sunroof button) to let the hot air escape.
Greg
Our BMW: '14 X3 35i, Deep Sea Blue, Black Nevada Leather, Fineline Wave Wood, Satin Aluminum Roof Rails, Premium Pkg, Cold Weather Pkg, Navigation System, Driver Assistance Pkg with ALL them cameras, Premium Sound
Our truck: '03 Ford F350, 7.3L turbo-diesel, 4WD, Lariat package, Lear topper, cow catcher, Blue over Grey (Go Rice!)
"Old Faithful's just a fountain compared to the glory of true love" -- John Prine
Old 06-18-2013, 02:48 PM
edbiology's Avatar
edbiology edbiology is offline
Mein Auto: 2013 X3 28i
Why not just open all the windows. I usually use my remote key to open the windows before I get into the car in hot weathers. I don't care about the temperature. But the plastic parts in the car releases benzene, which is a strong cancer causing agent, in hot weather to a concentration thats way above the safety level.
Old 06-18-2013, 03:31 PM
Anfänger Anfänger is offline
_________________
It makes sense to err on the side of caution when considering the merits of any reported health risk, but my understanding it that there is no credible evidence for excessive benzene levels in cars. The most directly relevant study (Buters JT et al (2007) Toxicity of parked motor vehicle indoor air. Environ Sci Technol. 41(7):2622-9.) reached this conclusion: "Our investigations indicated no apparent health hazard of parked motor vehicle indoor air."
Old 06-18-2013, 03:53 PM
edbiology's Avatar
Haha I admit my claim isn't based on any proven or published scientific data. But it's true that benzene is a carcinogen, and plastic under high temperature does release variety of harmful fumes. It is reasonable to assume that these fume would increase concentrate in a parked car in a prolonged time period.
As a scientist myself, I know not every published report can be trusted. For example, tobacco companies have published many papers in the past showing smoking can provide various of positive effect to human health.
Old 06-18-2013, 12:28 PM
i know what you are talking about now, but i never touch that button to control the air and i always not set it in auto.
Old 06-19-2013, 11:26 AM
poker838 poker838 is offline
Mein Auto: F25 x28 n52 + n20 / B8 A4
I noticed once that the A/C button was not lit, so the compressor was not running. Quite odd considering I've always thought the "Auto" button will put the A/C to on by default and control it as needed.
Old 06-19-2013, 11:37 AM
02420X3 02420X3 is online now
Mein Auto: 2011 X3 35i
The advice that I received from my SA was "Never touch the snowflake. Leave it on all of the time."
Old 06-19-2013, 12:17 PM
You must get that smelly duct work problem from leaving the AC on all the time.
Old 06-23-2013, 10:17 AM
noka noka is offline
Mein Auto: 2013 x35i M-Sport
That's actually how many think you can prevent it because it keeps air paths dry. Not 100% certain of that though. I always leave mine on auto (all seasons) and it does a good job for me whether cold or hot outside.
2013 x35i (Space Gray, MSport, CW/CWII, DHP, Premium, Premium Sound, Technology, BMW-Apps)
Retired:'09 C300 4Matic, '09 GTI, '06 750i, '05 C55, '04 R32, '03 M5, '02 GTI, 01 M5, '00 M-Coupe, '00 540i/6, '99 M3 Coupe, '98 M3 Coupe, '96 328i, ..., '86 4000CS Quattro, ... too many to list
Old 06-23-2013, 03:25 PM
You can keep it dry while its running but when you shut it off, the cold air inside the duct condensate and build up moisture due to the warm temp outside of the duct. Moisture will turn into molds and mildew and soon enough, you will have that smelly gym sock smell.
Old 07-03-2013, 08:55 PM
04prox2 04prox2 is offline
Mein Auto: x3
you should always turn the snow flake button off about a block or two before parking this allows the fan to dry out the evaporator and you don't get that moldy smell, down the road that is hard to remove once it starts growing.
Old 07-07-2013, 04:54 AM
pharding pharding is offline
Mein Auto: 14 550i
Actually just the opposite is true. If you turn off the AC for an extended period of time, even in the winter, you get foul air from the AC system. It is always best just to leave it on even in the winter.
04 Successfully lobbied BMW NA and BMW FS to prohibit dealers from using residual values based upon Euro Delivery MSRP and to use US MSRP saving BMW Enthusiasts several thousand dollars on each lease
17 540i in transit
14 550i Euro Del
14 X3 2.8i
11 550i Euro Del, Retired
08 550i Euro Del, Retired
07 330i Retired
06 330i Euro Del, Retired
04 545i Euro Del, Retired
01 530i Euro Del, Retired
Old 07-07-2013, 06:16 AM
I don't have the foul air problem in the winter. Here in the Northeast, during the winter, the air is pretty dry. I do exercise the AC system at least once a week to keep everything lubricated in the winter, but it gets it share of use from the defrost mode anyways. I do not like to leave my AC on permanently, in the winter, its a waste of energy since the air is dry anyways, in the Summer, it will product mold if you leave it on all the time. I always shut off the AC a few block before I get to my destination.
Old 07-07-2013, 09:37 PM
Mein Auto: x3
I would like to know where you are getting this info? Nothing could be further from the truth. An a/c unit is basically a dehumidifier Which means it collects moisture on it evaporator. In the winter this can aid in keeping your windows fog free. When on defrost mode the compressor cycles to help dry out the air and lubricate the compressor in the winter. It is very hard on the compressor to run when it's below -30. So if you want to run you A/C in the winter go ahead it's great for business someone will be thanking you some day.
Old 07-03-2013, 09:41 PM
mlmetzger mlmetzger is offline
Mein Auto: 2011 X335i
Originally Posted by jayasanala View Post
I have 2012 X3 Xdrive purchased 3 months ago from a non BMW dealer. Lately I noticed that when the temperatures or so high(mid 80s - mid 90s) I feel like I'm not getting enough cool air from my car A/C, is it something common or something wrong with my A/C. and if I need fill the gas for my A/C is it covered under BMW Warranty
On hot days I've noticed that, even on MAX, I don't get really cold air until its been running for maybe 5+ minutes or so. After that it's nice and cold :-)
2011 X335i
Old 07-03-2013, 11:07 PM
drive by72's Avatar
drive by72 drive by72 is offline
I feed trolls
Mein Auto: 3 series
The air con feeling 'weak' is a sign of a low freon charge. If the capacity is 2 lbs, but the car is only holding 1.85, the compressor will still engage and cycle, the car will still cool, but it will not cool to it's full potential.
If the vehicle has ever had air conditioning repair work, you could very likely have a very small leak via O-ring. These systems run at 2-300psi, so if an O ring is not up to par it can leak relatively easily. Another thing too is that AC lines, even though they are aluminum, are prone to corrosion. On a vehicle this new, that is unlikely though. I would have your dealer do a dye check- where they look for a special dye oil under a black light. Because the freon carries the PAG oil, any leak can be detected using this, as the leaking area will be covered in this special dye (which isn't visible to the naked eye unless in large quantities)
RIP Ben "Jever" Doebele, we wont forget you
Please, call me Chadley
1997 328iS... HR coilovers, Brembo F40 calipers, camber plates... I sure do miss you
1990-somethin Chevy K3500... Twin turbo Cummins swapped Chevy, dana 60 front axle swap, 4 link rear, air ride, custom everything. 600+ hp, 1296 ft lbs tq
Old 07-04-2013, 06:44 AM
alex md alex md is offline
Mein Auto: 2014 X5 50 M sport
Amazing answer i had similar issue with new X33.5 M and as it was explained to me by repair shop foreman my a/c function impoved after proper adjustment of freon pressure in a system.Alex
2014 X5 50 Msport
2013 X3 3.5 ZMP,ZCW,ZPP,Carbon black/black/wife/ 2011-2014 550xi M sport/ED/
2007-2011 X5.4.8/E70/
2010-2012 GLK 350/wife/
2008-2011-328XI
2004-2007-CLK55
2007-2010-X3 3.0
2001-2004-A8 4.2
2004-2007 X5 3.0/E53/
1999-2001-SL500
1996-1999-ML320 4MATIC
1992-1995-VOLVO 850 TURBO
1990-1992-525I
1987-1990-OLDSMOBILE CS
1981-1987-LADA/VAZ 2103
Old 07-04-2013, 07:04 AM
BMW have always had weak AC systems. Out of all the brand I have owned, BMW has got to be one of the weakest, even the non-luxury brands were superior. If you guys think the X3's AC is weak, the E90 328i was even worst. On a 90+ day, I can drive in the city for hours and the cabin would not be cool. The only way to really get the AC cold was to drive it on the highway.
Old 07-04-2013, 08:43 AM
RhoXS RhoXS is offline
Mein Auto: Z3 & X3
Assuming all the controls are set correctly, insufficient cooling is probably related to one of the following mechanical issues that you will need a qualified A/C mechanic to deal with.
- Low refrigerant. Contrary to what many people think, it is impossible to determine if the A/C is charged properly by measuring only pressures. Additionally, due to the small size of a typical automotive A/C system, the correct amount of charge can only be determined by "weighing it in" and the amount is usually only a pound or two and is required to be correct to within a single ounce. Even an ounce too much or too little can adversely effect performance. For this reason, any A/C mechanic that states he will just add a little gas should be instantly avoided. Only after carefully checking for leaks, to charge a system, shops use a computer controlled cart. The cart first recovers all refrigerant that is in the system, then establishes an almost perfect vacuum, and then very carefully recharges it by exactly weighing in the required amount. If the system then cools properly it was low on gas and now it is necessary to find and fix the leak (frequently a compressor shaft seal). One more thing, a system low on gas will cool to some extent but left running long enough the evaporator will freeze up and air flow will significantly decrease. In fact, a frozen evaporator is an excellent indication of an inadequate refrigerant charge.
-Bad expansion valve. Even with a proper charge, a bad expansion valve will either cause inadequate cooling or cause the evaporator to freeze up (if it is stuck open).
-Loose or damaged compressor belt or bad compressor clutch (not likely).
-Bad/weak compressor. A gauge set will help diagnose this.
In any case, IMO, you need to find a TRUSTED shop that regularly does A/C work and have them check it. A friend or neighbor that tells you they can fix it is something to avoid as they will have no way of properly charging the system. Unless they have a good gauge set AND an accurate temperature probe, to measure something called superheat (and probably subcooling too) there is just no way to determine if it is charged properly without recovering and then weighing in the proper charge from scratch.
