The X5 SAV Forum
Old 07-12-2013, 12:37 PM
jhamm18 jhamm18 is offline
Mein Auto: BMW X5
Exclamation I Need Help! My X5 won't start
Ok. I have a 2003 BMW X5. It'll start in the mornings and then after I drive it for a while and turn it off, it won't turn back on. It doesn't turn over at all, but all the electronics come on. It only does this when it is hot outside and it isn't ever a problem in the winter. And, I have to let it sit for a few hours before I can start it back up. But... as of yesterday it doesn't start at all, no matter how long I let it sit. The battery is only a year old and jumping the car doesn't do anything, also the alternator was replaced about two years ago because we thought it wasn't charging the battery but that wasn't the problem, and the starter was replaced last week and that wasn't the problem either. I have no idea what else could be wrong someone please help.
Old 07-12-2013, 01:48 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
If you can get the car started...turn on the radio and headlights, then reach over and pull down the passenger sun visor and open the cover to the mirror. If a bunch of odd electrical things occur (interior lights come on, steering wheel moves on its own, radio turns off, etc)...then the issue may be your ignition switch.
Not saying this IS the culprit...but a failing ignition switch can cause a lot of weird issues...do the test to see if you can initiate any electrical weirdness.
An example:
Q {BMW CCA Member #191509}
(SOLD)
Old 07-12-2013, 02:05 PM
Mein Auto: BMW X5
An example:
OK so i went out to try all of that and all the electronics work but the car didn't turn over at all. and then I tried putting it in neutral and it started right off the bat no problem, so I put it in park and then turned it off and immediately back on and it started. So, now I'm still really confused
Mein Auto: BMW X5
Old 07-17-2013, 04:07 PM
When it doesn't start and you have the gearshift in P does the indicator on the dash shows "P"?
help advice needed, please some insight, problem starting, x5
