The X5 SAV Forum
Old 09-06-2013, 12:28 PM
ryan04 ryan04 is offline
Mein Auto: X5
successful DSP integration of aftermarket head unit!
Just giving a bit of hope to those out there contemplating an aftermarket head unit with DSP. I have a 2001 E53 with Stock navigation, and CD changer with the radio in the trunk. I bought an aftermarket metra harness like all the write ups say and hooked in the 5 wires to DSP amp tricking it to stay on. I thought I was hooped and would have to tear out the whole system, but it turns out you don't! Especially because I had ALL the stereo options. Turns out to be a bit easier than most. Seeing as how the radio is in the trunk the dummy harness isn't seen as it's spliced into the DSP amp and the stock radio harness is extended up to the front. My stock navigation screen isn't integral to the system at all. So that's where it's a bit easier and cleaner. Most guys have to relocate the business cd/radio to their glove box, but seeing as how mine was in the trunk already and navigation screen up front is a just a screen and has no bearing on the digital signal it (stock navigation screen) can be removed permanently ( AS LONG AS YOU'VE SET YOUR BASE VOLUMES) Now I have a Eonon head unit that works perfectly, and full sound while retaining steering wheel controls and utilizing the DSP system. I'm finishing up tomorrow so hopefully i can post a video when i'm done. It's much simpler than you think to do. You just can't be afraid of pile of wires. As long as you've got your patient pants on it'll work. Good luck!! woohoo!!!
Old 09-09-2013, 12:35 AM
EononCarDVD EononCarDVD is offline
Past Sponsor
Mein Auto: BMW
Hi ryan04, great job! Thanks a lot for sharing. Look forward to your detailed but simpler method soon! There are thousands of guys are waiting! They will get benefited and appreciate you a lot!
Old 09-09-2013, 07:07 AM
scott740il scott740il is offline
Send a message via AIM to scott740il
Mein Auto: 1999 540iT Wagon
hell yes! post pics :-)
Old 09-10-2013, 10:30 AM
Mein Auto: X5
Sure, I'll try and make a video of what I did on saturday and post the link here.
Old 09-10-2013, 09:39 PM
Past Sponsor
Mein Auto: BMW
Thanks ryan04 in advance! Waiting for you~
Old 09-13-2013, 02:04 AM
skptc skptc is offline
Mein Auto: 03 Z4, 04 X5
Re: successful DSP integration of aftermarket head unit!
04 x5 with cd dsp, no navi. I'm in the process of figuring out how to replace my business cd/dsp head unit with an Eonon..tech support tells me to check whether I have a 17 pin or 40 connector in the back where the radio is but I can't seem to find anything remotely like it. The only 40 pin connector I find is in the dash at the cd player.
Old 09-16-2013, 12:53 PM
cvb cvb is offline
Love the 'Fest
Mein Auto: 2016 M4 (on order)
Thanks! Waiting to see the detail. Eonon says this unit is only for E39s (5-Series), but you have an E53 (X5) and made it work. I want to put this into an E38 (with DSP and existing factory nav)....I wonder why it wouldn't work since all these cars are from the same generation?
Current BMWs:
2016 F82 M4: Alpine White/Sakhir Orange Full Merino 6MT
2000 E38 740iL: Cosmos Black/Sandstone
Retired BMWs:
2011 E93 M3: Convertible Silverstone/Fox Red DCT (via European Delivery)
2008 E60 535xi: Platinum Gray/Black (via European Delivery) ED Trip Report Link
2003 E46 M3: 6MT Steel Gray/Black
2004 E53 X5: Titanium Silver/Black
BMWCCA Member since 2002
Old 09-16-2013, 11:02 PM
Mein Auto: X5
CVB
beats me. should slide right in, After the connections and re routing the stock radio harness of course. Mine bolted perfectly into place, and looks totally stock. Give it a go.
Old 09-16-2013, 11:11 PM
Mein Auto: X5
skptc
That's the plug. In the back of your CD/Business radio. You need to buy a metra harness from ebay for it to be clean. It's about $12 with shipping. In your case you could unplug the cd/business radio and move it to your trunk. (that's where the dsp amp is) From there plug the aftermarket metra harness into your stock cd/business radio and make the appropriate connections. (listed below) After that your eonon unit should plug and play with your factory radio harness that is up front in your dash still. Hope that helps.
Connect pin 16 from the round pin plug - - with the wire from pin 4 on the Big AMP Plug
Connect pin 9 from the round pin plug - - with the wire from pin 8 on the Big Amp Plug
Connect pin 15 from the round pin plug - - with the wire from pin 15 on the Big Amp Plug
Connect pin 5 from the round pin plug - - with pin hole 5 on the DB25 plug
Connect pin 7 from the round pin plug - - with the IBUS wire on the smaller plug on the amp (should be white with yellow spots)
/Users/ryanbatke/Desktop/BMW1.jpg
you
Old 09-18-2013, 01:00 AM
Past Sponsor
Mein Auto: BMW
skptc
Thanks ryan04 for your sharing. And still waiting for your own video.
Old 09-18-2013, 10:19 AM
Mein Auto: X5
That actually wasn't my video, but it was similar. I'll still be doing one because i had factory navigation as well. It's basically the same, with minor changes.
Old 09-17-2013, 08:05 AM
Awesome... just to be sure I got it.
1. Eonon plugs right into the 40 pin connector that now goes to factory radio/cd in dash
2.MID remains connected as is but relocated to glove box.
3. Factory radio/cd moves to trunk rewired per your post
4. Factory radio cage gets sawed off to make room for eonon unit.
Do I have it?
Old 09-17-2013, 09:01 AM
no dude, do NOT cut the cage, it comes out, 8 screws, and some wiggling.
getting the radio back in with all the connections has been the hardest part. Im going
outside to try and get it done since I had to go buy the antenna connector.
Old 09-17-2013, 10:27 AM
You sure that is the case on an 04 e53? Because it looks like it extends beyond the radio housing area in all directions
Old 09-17-2013, 01:50 PM
Ryan04
Found lots of harnesses individually for less but this kit is the only one that specifically refers to e53. Looks right
http://rover.ebay.com/rover/1/711-14...21_PM536746717
Old 09-17-2013, 11:08 PM
Mein Auto: X5
i have the 17pin connector. So i bought this one to plug into the radio.
I think you need the reverse harness. You need to be able to plug into the stock radio with the aftermarket harness (middle) then only wire in the 5 connections. Then the stock radio harness which is identical to the aftermarket one you plugged into the radio, plugs directly into your eonon unit. So you have 2 of the same harnesses in use. The 17pin is the left, the 40 pin is the middle and then the wiring diagram of course on the right.
ID:	397475   Click image for larger version
ID:	397476   Click image for larger version
Old 09-18-2013, 04:19 PM
Well,.have a replacement MID.and reverse harness ordered on eBay. Hoping to have both in time to finish this weekend. We'll keep everyone posted, take pics along the way and hopefully be able to call on everyone specially ryan on the wiring...
PS, not holding my breath on any useful input from eonon...those guys owe everyone on this board a huge commission for troubleshooting their untested product. Even the low price doesn't in my opinion make up for their misleading advertising and total failure to even try to install on one of the vehicles they claim their product to be a diy...
Old 09-19-2013, 01:54 PM
Ryan, the diagram seems to be for the 17 pin connector. How do I cross reference to my 40 pin?
Old 09-20-2013, 10:39 AM
The reverse harness I just got and the three connectors on the amplifier in the cargo area... now on to find the right wires
ID:	397868   Click image for larger version
Old 09-20-2013, 11:49 AM
Mein Auto: X5
So these are the wires i conected.
This is the wiring for the 17 pin, so i'll try and find the 40 pin wiring diagram for your radio so you can locate these wires to connect to.
Old 12-18-2016, 09:57 PM
7aP2Q 7aP2Q is offline
Mein Auto: M5
Reversed amp 15-pin diagram?
Is the diagram for the amp 15-pin backwards? I found this diagram that is reversed.
http://www.m5board.com/vbulletin/e39...ml#post5006602
Old 09-24-2013, 06:20 AM
Any luck with the 40 pin diagram?
Would matching wire colors work?
Old 09-26-2013, 11:13 AM
Mein Auto: X5
try this. man its hard to finf this stuff!!
picture below
Old 09-26-2013, 11:15 AM
Mein Auto: X5
this is easier.
Old 09-26-2013, 11:59 AM
Thanks I'll give it a try. Here's an update.
Got a replacement MID, connected red ilumn wire to orange wire in EONON harness and unit turned on, was able to access functions although still no sound as I still need to move factory radio to the back.
However my excitement was short lived as, with the unit still on I moved the harness slightly and the unit shut off. Wiggling make out come on again but that was short lived as the slightest touch to the harness wires made it shut off.
I'm thinking defective harness dune the built in fuse is good. Have contacted EONON through eBay for a replacement harness but have not heard back. This should be interesting, I'll keep everyone posted
