E34 (1989 - 1995)
Old 10-27-2013, 02:40 PM
3RZ 3RZ is offline
Mein Auto: E34 530i
530i Door Lock/Keyless Entry faults
The car is a 530i with the build date of 10/1995. The alarm is OEM with the squarish 3 button remote like this:
So, since I've had the car the door locks never worked quite right. If you locked or unlocked the car using the remote, the passenger rear door lock would not work. Pressing the driver door lock peg down while in the car to use the central locking would yield no response from this lock either. Unlocking the car using the key in the driver's door did nothing as well. I assumed the passenger rear lock actuator was dead.
Out of nowhere this all changed. One morning I went out to unlock the car with the remote. The driver's door did not unlock but the passenger rear door did unlock! I manually unlocked the driver's door using the key and got in. I found that using the remote will not unlock the driver's door but will unlock all other doors. Pressing the driver's door lock peg down to use central locking will work on all doors. Manually unlocking the car using the key in the driver's door will unlock all doors as well.
Any ideas? I searched to no avail. Is the alarm box bad?
Old 10-27-2013, 08:34 PM
E34ZombieHunter's Avatar
E34ZombieHunter E34ZombieHunter is offline
Nothin like an E34
Mein Auto: 95 540i B/B
The locks have become unsynchronized. Mine acted a bit like that some would work some not(i have after market system, but it acted the same when using the key in the door) I just re synched the system and no worries since. Should be in your owners book IIRC.
Gotta love an E34!!
If you want to get junkyard parts remember one thing, if it was wrecked you know it was running/driving. You may not know how well, but it was.
READ THE STICKIES AT THE TOP OF THE PAGE!!
STOMP TEST
READ ME IM THE BIBLE
FAN CLUTCH
LOCKS
ANGEL EYES
Audio
E28 v. E30 v. E34
Old 10-27-2013, 10:25 PM
M540FELLA's Avatar
M540FELLA M540FELLA is offline
Josh
Mein Auto: 95 540i m sport
The alpine systems like you have also hold a chip inside the remote. You can remove the chip and insert it in the box to reprogram.
Old 10-30-2013, 01:35 PM
3RZ 3RZ is offline
Mein Auto: E34 530i
I've looked through the manual and searched online but I can't find these syncing instructions. Can anyone hook me up with a link?
Old 11-02-2013, 06:56 PM
Nothin like an E34
Page 515-2
Synchronizing central locking system
After manually locking or unlocking the system, the door
locks may become unsynchronized. To synchronize the
locks, close all doors, trunk lid. and tailgate. Lock the passenger
door by turning the key clockwise into the emergency locking
position (approximately 110" from position 0). Unlock the
driver's door. If any of the locks do not operate, repeat the
locking procedure until the locking system is synchronized.
NOTE
This procedure can also be used if the locks become
unsynchronized. This might happen if a door which is
not completely closed is locked, or a door handle is lifted
before the interior lock button is raised.
Gotta love an E34!!
STOMP TEST
FAN CLUTCH
LOCKS
ANGEL EYES
Audio
E28 v. E30 v. E34
Old 11-02-2013, 11:56 AM
3RZ 3RZ is offline
Mein Auto: E34 530i
Bump
Old 11-02-2013, 05:11 PM
imae34driver imae34driver is offline
Resident e34 Racer
Mein Auto: 1995 540i SPORT /6 spd
My e34 & e38 had sticking rear door locks..
E38 making sure the door panel did not interfere with it solved it..
E34 i swapped doors and with out think about it solved coincidentally..
Bone stock 95' 540i/6 Blk/blk w/ ram style C.A.I / JBR LWFW/ DUDMD tune/ straight pipe /545 SSK /3.15 LSD / Rev-shift motor mounts/stage 4, 6 puck clutch/ K Sport coil overs/Eibach sway bars/ VAC under drive pulleys/weight reduction /sparco 368, Recaro seats, sparco harnesses, NX wet kit, M/T E/T streets.
"Skill can only get you so far, then comes money!"
R . I . P Paul Walker - 1973 - 2013
Old 11-02-2013, 06:58 PM
Nothin like an E34
Syncing the remote, googled how to sync e34 remote got,
Procedure
Phillips screwdriver.
New remote.
1. Remove the rear seat bottom section. You will see an alpine alarm box located on the driver side.
2. Remove the two Phillips head screws that hold the box over and you will see an access door.
3. Open the door carefully: you will see a small black button and a small slot where the remote chip (eprom) is placed.
4. Remove the 2 Phillips head screws from your remote fob. You will see a small circuit board, a battery ad a chip. This looks like a very small ram chip on a PC. Carefully remove the chip from the remote and plug it into the empty chip slot on the alpine alarm box.
5. Put your key in the ignition and turn it to the 1st accessory position (Do not start the car). Go back to the alpine alarm box and hold the black button down for 10 seconds. Remove your key from the ignition.
6. Remove the chip from the alpine alarm box and put it back into the remote fob.
7. Re-mount the alarm box and seat bottom. This is it.
Alternate Procedure from Steward E.
1. Open the remote by removing the two screws and flip the cover open. If the battery comes out of it's position, make sure you put it back with + facing the correct side.
2. Remove the chip that is to be programmed. It has a white label with a serial number on it. The chip might come out easily, or you might have to use a small screwdriver to open the socket. The small plastic socket has a front end that can slide out if you pry gently with a small screw driver. This will make it easier to remove the chip.
3. Remove the back seat of the car (because the alarm unit is under it). The seat cushion is removed by locating the securing clamps, one on each side, roughly in the middle behind the front seat and at the lower end on the front of the back seat. Once you've located the clamp (you can feel where it is, but you can't see it), grab the lower end of the back seat at that point and pull hard up.
4. The alarm will be under the beck seat behind the driver's seat. Use a 7mm wrench to loosen the two screws on the bracket in front of the alarm. When the alarm is loose, turn it upside down. Open the small plastic panel. Now you will see a socket identical to the one in the remote. Insert the chip in this socket. Be careful and make sure it is inserted correctly. Turn on the ignition on the car. Go back and press the small button to the upper left corner of the chip you just installed. Hold the button down for just a few seconds.
5. Turn off the car's ignition, remove the chip and install it into the remote. The remote should now work.
6. Install the alarm unit and back seat and you're all set.
Gotta love an E34!!
STOMP TEST
FAN CLUTCH
LOCKS
ANGEL EYES
Audio
E28 v. E30 v. E34
