E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki |
BMW Bluetooth Compatible phones; What WORKS?
Find a Compatible Handset - Not all Bluetooth phones will work!
Unfortunately, not all Bluetooth compatible phones will work (partially or fully) with BMW's Bluetooth systems. As such, “Bluetooth” is an ambiguous term and insufficient to ensure compatibility. That is unfortunate, since "Bluetooth" is all that is typically included in the phone's description. My experience is a good example: my do-everything SonyEricsson P900 does not work with my Bluetooth-capable car (the SonyEricsson P900 lacks a "handsfree profile" required to work with the BMW implementation of integration of cell phone and car). Successful 6 Series Bluetoth retrofit, but phone incompatible Even if you have a "BT-compatible" phone with the BT "handsfree profile," there are other features that may or may not work properly. For example, the phone should automatically share its phone book with the car to enable a set of nice features: based on your phone's address book: Calling Name display and BMW Customer Assistance has a short list of compatible phones (SE T68i, SE T610, SE T630, Motorola V600). A more extensive compatibility list is here: More extensive list of BMW-compatible phones What phones work for you? Please share what works for you so that we can all share in your experience and knowledge. Please post your experience: ---------------------------------------------- Phone model: Car model: [ ] ability to make/receive calls [ ] phone book automatically synches to car [ ] dial by name (without verbal training of system) [ ] calling name display (using adddress book) [ ] ability to send/receive SMS ----------------------------------------------
--- 2004 645Ci, Mystic Blue + CreamBeige, Euro Delivery 8.2004 (SMG, Sport Pkg, Cold Weather, Logic7 Sound, PDC) ![]()
Re: bluetooth compatibility
Phone model: HP iPaq H6315 Pocket PC Phone Edition (PDA/phone)
Car model: 2005 545i [x] ability to make/receive calls [ ] phone book automatically synches to car [ ] dial by name (without verbal training of system) [ ] calling name display (using adddress book) [ ] ability to send/receive SMS I have found another glitch. My PDA unfortunately goes into a suspend mode when not in use, to save battery power. When it suspends, everything shuts off except for the cellular phone connection. That means bluetooth shuts off when the phone is not in use. So when an incoming call rings in, the car will not be linked with the phone until the PDA has time to load the bluetooth. This means, the phone will ring a few times before bluetooth can connect..... and you will most likely miss the call while waiting for the pairing to complete. ANNOYING.
My SE P910 works (only partially) with BMW bluetooth. It pairs up quite easily but phone book won't auto transfer. So the new P910 now supports handsfree protocol.
Se 910i
Can you tell me how you send/receive calls, i was be able to send from my SE910i sometime, sometime it did not work, i did not know what seems to be a problems, i don't need to transfer the phone book, all i need is send/received call. I got 05 545i, i think it was same as in 05 X5 system. Thanks in advance. |
Those of you that have the RAZR, who is your provider? Are you happy with the coverage in your area?
I've found verizon's coverage to be quite good but I'm thinking seriously of dumping them to pick up a RAZR. #750 |
2000 528i
I just bought a 2000 528i and I would like to get a bluetooth phone connection. I use a blackberry pearl. please advice
Motorola V551
I purchased the Motorola V551 for my 05' 545i to compliment the BMW BLUETOOTH and it works perfectly in my vehicle. All functions work as they should and I enjoy this option with its clarity. So how does one wire the navigation dvd system to play normal dvds since I see the option in the i-drive entertainment mode?
Re: RAZR
I have the RAZR.
I am using it with T-Mobile. I purchased an unlocked phone on eBay. The reception quality is very good. This is the first phone I've been able to use indoors at my house and work. My others previously never had enough signal. It works very well with Bluetooth. |
7100t and BMW
Please read the attached problem description.
http://www.blackberry.com/knowledgec...80420&vernum=0 There seems to be no reslution for this problem. |
Any definitive info on the Treo 650? I saw some initial reports of problems, but that was prior to the patch that was released by Palm for car kits.
Connecting 7100 Blackberry to BMW
Here is link that acknowledges the issue.
Does anybody (including BMWNA folks reading this) know when or how this issue will be resolved. http://www.blackberry.com/knowledgec...80420&vernum=0 Or search for What Is - Connection problems between BlackBerry handhelds and Motorola Bluetooth car kits in 2005 BMW models |
Blackberry 7290 and BMW Bluetooth
Still a problem with my BB 7290 and a 2005 525i purchased a week ago. Car and phone connect but no operability after that. Don't care about transferring phone book but it would be nice if it worked. Does BMWNA know there's a problem? Any software updates from Blackberry imminent? Any other fixes or alternatives recommended. It's frustrating.
Sorry if this is a done topic... but I didn't have time to read throught the whole post. Below is the official Bluetooth site for BMW. My Treo 650 connects to the 645Ci for placing recieving calls only... no syncing the phone book/log etc. However, it crashes in my '05 X5 while the X5 is trying to sync with the phone book. My suggestion would be to stick with the list of phones they give you. Below is the site... and below that is a really great site for info on cell phones:
http://www.bmwtransact.com/bluetooth/ http://www.phonescoop.com Jeremy |
I can't seem to pair my RAZR with my 2006 325i. I put the razr on find me and the nav says "please activate phone" and it jus sits there. It doesnt seem to find my razr, or maybe i'm doing it wrong and someone can tell me the right way to pair it.
YamED 3/24/05 530i 05 grey/beige/navigation 6spd http://www.bimmerfest.com/forums/sho...ght=march+24th http://www.bimmerfest.com/forums/sho...ght=march+24th ED 3/19/08 528I 08 6spd white/beige interior http://www.bimmerfest.com/forums/sho...d.php?t=272222 |
Treo 650
I test drove and ordered a 530xi and the Palm Treo 650 worked with the bluetooth in the 2006 in about 30 seconds of setup.
Phone model: Blackberry 7250(Verizon Wireless)
Car model: 2006 525i [x] ability to make/receive calls [ ] phone book automatically synches to car [x] dial by name (without verbal training of system) [ ] calling name display (using adddress book) [ ] ability to send/receive SMS The voice command works, incoming and outgoing calling is fine. The address book sync does not work, I had to manually enter phone numbers I use frequently through the voice command method...To dial numbers in my BB, I find them and initiate dialing on the BB, but the bluetooth kicks in and the call is placed through the car system. The audio system automatically mutes to accomodate the call. Not perfect, but good. I am waiting for the address book sync, then I will be in great shape. |
Phones
Pick up Eurodelivery 530xi & 330i. Have bought a Motorola Razor V3. Hope it works when I get to Europe. The BMW bluetooth web site http://www.bmwusa.com/NR/rdonlyres/6...oth_phones.pdf
Indicates it is compatible, but no charging cradle. Check web site BMW is regularly updating it. |
frustrating
I don't know if I'm dumb or what. I have a 2006 525i and I've just bought a Razr V3. It does not seem to sync. And the password-where in the world do I find that? And in case I do get a password how do I enter it in the idrive?
Link to BMW's own bluetooth site. Lastest data
530xi - 2006 Silver/gray Auto,Prem pkg, fold down seats,PDC,HUD,Cold weathr Pkg, Comfort seats, NAV, Satellite, heated rear seats, straighened vertical post between passenger doors from wreck 6/1/2006. 330i -2006 silver/gray- Auto, Sport pkg, Premium Pkg,Cold Wthr Pkg, NAV, Satellite |
Phone model: Treo 650 Unlocked Cingular GSM on T-mobile network (Treo650-1.17-CNG)
Car model: 2006 530i (Sept 05 production) [X] ability to make/receive calls - volume is a little low [X] phone book automatically synches to car - yes but 20 of my speed dials (favorites) only [X] dial by name (without verbal training of system) - yes on simple names [X] calling name display (using address book) [ ] ability to send/receive SMS - haven't tried
ED 2006 530i: Mystic Blue, Beige Leather Interior, Steptronic, Sports Package, Premium Package, NAV, Comfort Seats. |
Motorola Razr V3
MOTOROLA'S RAZR V3 WORKS FINE... SEEMS TO BE FULLY COMPATIBLE...ONLY THING I'VE NOTICED IS THE CALL TIMER KEEP RUNNING AFTER I'VE HUNG UP (AS IF i WAS STILL ON THAT CALL)... I'VE HAD TO RESORT TO PHYSICALLY PRESSING THE "END" KEY ON MY CELL TO SOLVE THIS PROBLEM.... OTHER THAN THAT, ALL'S FINE
530xi bluetooth compat with HP 6945 or Treo 750?
Has anyone had any success get the HP6945 or Treo 750 to worth with the bluetooth. I have a 530xi and have had no luck. Thanks
#25
Palm Treo
i have a palm treo 650 , and it works with my 2005 530i , does not give me the phone book and all features but still works good.
am happy with it , that atleast it works and i dont hv to change my fon. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Which bluetooth BMW 7/5 series compatible phones work in Europe? | neurom | European Delivery | 22 | 04-02-2005 01:15 PM |
| are Chinese language cell phones compatible with BMW bluetooth?? | alsu1983 | 3 Series / 4 Series | 1 | 01-15-2005 02:45 PM |
| BMW Update for S54 Engines | BMWNA | M Series | 2 | 08-13-2003 05:55 PM |
