Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > 5 Series DIY
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with!
Old 01-01-2005, 01:13 PM
DeCePtiCzXe39 DeCePtiCzXe39 is offline
Mein Auto: '98 528i E39
How do I change the fog lights on 528i?
I need to change the bulbs in my fog lights but i dont know how to remove the assembly in my 1998 528i. any help??
Old 01-01-2005, 01:35 PM
M.Wong's Avatar
M.Wong M.Wong is offline
E38 E91 (R56 E30 E39)
Mein Auto: The E38
They are different on my E39, but here is what I have seen:
For pre-2001 only with old-style fog lights
-Use a small flat-head screwdriver to move the center pin of the 2 expanding rivets out a couple millimeters.
-Use needle-nose pliers to pull it straight down and out.
-Use the screwdriver again to pry out the body of the expanding rivet if they are still stuck in place.
-When both rivets are removed, the grill section should rotate downwards so pull from the top outwards and it should simply remove.
-Then it's (2) small bolts (6mm?) and the foglight should be free.
Images from http://www.540isport.com/DIYfoglamp.htm#
M.Wong
E38 2000 740iL Orient Blue
E91 2012 328xiT Alpine White
Passed on to new families:
E30 1987 325i Royal Blue
E39 2003 540i/6 Sterling Gray
R56 2010 Mini Cooper S British Racing Green
Old 01-01-2005, 02:33 PM
AsianImage's Avatar
AsianImage AsianImage is offline
aka Turd Ferguson
Send a message via AIM to AsianImage
Mein Auto: Excellence
I just changed my fog lights and maybe its a cheat...but I simply parked on an angle up a driveway and then turn the wheels full lock left or right and just reached in there and removed the bulb. This may work for you too.
So to reach the driver side fog light, I turned the wheel full lock to the right parked half way up the driveway and I was able to reach the light twist and pull out replace and the the same for the passenger side by locking the wheel to the left.
*** THERE IS NO SUBSTITUTE ***
“If I tell you I'm good, you would probably think I'm boasting, If I tell you I'm no good, You know I'm lying.” — Bruce Lee
IMG_4675
Old 01-01-2005, 04:07 PM
M.Wong's Avatar
Mein Auto: The E38
Does your 01 540i have rectangular fog lights? I am not sure if the 98 are the same.
M.Wong
Old 01-02-2005, 12:16 AM
AsianImage's Avatar
aka Turd Ferguson
I have the circular fog lights. Does it make a difference?
I would think access would be the same but I dont know. Sorry if my 2 cents were worthless.
IMG_4675
Old 01-02-2005, 12:35 AM
M.Wong's Avatar
Mein Auto: The E38
Oh no, that's not what I was saying at all... I just wanted to be sure "DeCePtiCzXe39" knew we may be talking about a couple different kinds of fog lights. I think access may be different.
Our 03 540i/6
01 530i (pic from e-bay)
00 540i (pic from e-bay)
M.Wong
Old 12-11-2010, 01:58 PM
mtme34 mtme34 is offline
Mein Auto: e39
thanks this helped me alot. the owners manual does not go into much detail.
Old 12-28-2011, 05:31 PM
o-wow o-wow is offline
Mein Auto: 97 528i bmw
where can i find the blue bulbs for my 5 series fog lights and what number are they
Old 08-26-2012, 11:15 AM
brewski brewski is offline
Mein Auto: 530i (2001)
I just accomplished this on my 2001 530i with round fog lights...works exactly the same.
No need to jack the car, all access is from the front...except for moving the actual light out then in.
Thanks, and 6mm is correct.
Similar Threads
DIY: How to change your belt, thermostat and Waterpump in your 528i GOKOOLJAPAN 5 Series DIY 13 03-11-2009 02:12 PM
FS: 2005 OE fog lights from 325xi mazdaseed FC Classifieds 1 10-04-2004 06:14 PM
Id Like to add M Roadster Fog Lights weoilmen E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) 24 08-06-2004 01:25 PM
A quick Q? about fog lights... Bobby 325i 3 Series / 4 Series 11 04-01-2003 10:19 PM
Rear fog lights on BMWs in the US? FrenchBoy 3 Series / 4 Series 24 11-18-2002 07:25 AM
